  1. Jul 15, 2015 at 3:56 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Mine went out at 21k miles.
  2. Jul 15, 2015 at 4:14 PM
    scaddude
    scaddude Active Member
    Los Angeles, CA
    V6 4x4 6-Speed Manual TRD Off-Road
    Thanks for sharing! I'm starting to look at the KO2s, and going to the 285 (I have the 265 now), now I can see what it'll look like.
  3. Jul 15, 2015 at 4:52 PM
    texvet61
    texvet61 Well-Known Member
    Ocala, FL
    09 Tacoma TRD Sport
    Lighting: Phillips LED headlights, BD's S2pro fog lights, LP4 pro and LP9Pro Racing LED's, Black OaK IR cubes. COMMS: Cobra WSX75 CB, Icom 7000 Ham Radio, antenna; Alpha MotoSS HF 80m-40m, CA-2x4SR tri-band 2m/70cm/ - AUDIO: ALPINE ILX-W650, KTA-450 Amp, S-A60M 300Wt mono amp, F/R door speakers, JL Audio C2-650X, JLAudio Micor 8" sub. C4 Fab Hybrid Bumper, Warn VF12000S, Locking Rear seat Gun Vault. Locking Console Gun Vault, FPV winch Camera,
    warn
  4. Jul 15, 2015 at 4:57 PM
    texvet61
    Ocala, FL
    09 Tacoma TRD Sport
    I weighed my options and you have a chance of tearing up a cable on either one, I just liked the cleaner look than the rollers and this one works on both steel and synthetic (as long as I don't burr it up with the steel cable).
  5. Jul 15, 2015 at 5:01 PM
    Allstar780
    Allstar780 Well-Known Member
    Colin
    Alberta, Canada
    15 TRD Trail Teams Sport
    3" Lift, 32" Goodyear Duratrac, XD Series Hoss Rims
    Finally got around to doing my fluid film undercoating today... I've had the product sitting around for a month or more so it feels good to have it done
    jmich2001 likes this.
  6. Jul 15, 2015 at 5:23 PM
    CamoNBlaze
    CamoNBlaze Well-Known Member
    Zach
    '09 V6, 6 speed
    What are your thoughts? Would it be worth spraying in the frame?
  7. Jul 15, 2015 at 5:33 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Wow that soon?
    Mine did too and I did the same and it came loose again then I left it off...
    21k? That's really early
  8. Jul 15, 2015 at 5:49 PM
    la0d0g
    running for the hills
    For crawling not hauling
    You're late :D
  9. Jul 15, 2015 at 5:53 PM
    NCTacoma
    NCTacoma Rather be in the mtns
    Caleb
    CLT, NC
    Sold- Searching for 1st gen
    I've got 45k on mine. Had a p2440 & p2442 code going in this morning. Kept me around 35-40 mph. Secondary air injection system switching valve stuck open bank 1&2. Reset it and so far nothing yet, but have only put 15 miles on it since. :fingerscrossed:
  10. Jul 15, 2015 at 5:55 PM
    T4RFTMFW
    I know. No CELs either. Rattled for about 2 weeks and then was replaced. The honeycomb structure failed and the pieces were rattling around like a baby toy. Drove me nuts.
  11. Jul 15, 2015 at 6:05 PM
    Allstar780
    Colin
    Alberta, Canada
    We use it on machines at work and it seems to hold up well, several other guys on here swear by it.
    For the cost and time and the apparent benefits I would say do it! It took me less than an hour to get the frame all cleaned up with the pressure washer and let it air dry to the point of not dripping water in my face... it took maybe a half hour to do the actual coating
    CamoNBlaze[QUOTED] likes this.
  12. Jul 15, 2015 at 6:19 PM
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
  13. Jul 15, 2015 at 6:21 PM
    T4RFTMFW
  14. Jul 15, 2015 at 6:24 PM
    raggedphoto
    raggedphoto Well-Known Member
    Oregon
    DCSB 07 Desert Sand Mica
    For long haul vs short crawl
    finished up my hi-lift, shovel and axe mounts for the bed! shitty phone pics but you get the pointimage1.jpg image2.jpg
    T4RFTMFW likes this.
  15. Jul 15, 2015 at 6:29 PM
    Larry
    Larry CARL
    CARL
    Ouch
  16. Jul 15, 2015 at 6:33 PM
    raggedphoto
    Oregon
    ooops
  17. Jul 15, 2015 at 7:36 PM
    hg3
    hg3 Well-Known Member
    hg3
    kingsville, texas
    2011 tx pro 4x4
    6 inch bds db lift kit with Fox 2.0 coil overs and Fox 2.0 rear shocks 18x9 xd grenades with 4.52 backspacing and -12 offset 35x12.50 toyo mt's Pioneer 5600 7 inch touchscreen Rockford Fosgate tweets and rear Alpine front 6x9 Rockford p500 for sub Pioneer 4 channel for doors Halo's Westin bull bar custom paint with mounted piaa lights Led interior lights Rugged ridge floor liners Stainless Steel 6 rod holder Overhead DVD player Road armour rear bumper w/ shackles and led lpl Dipped red emblems
    1. Got rid of the horrible squeaks coming from the leafs that had been annoying me for weeks.
    2. Dipped emblems
    3. Cleaned and painted my piaa fogs
    4. Added some color to my trd lic. plate frame
    .... Got too dark for pics :(..
  18. Jul 15, 2015 at 7:37 PM
    T4RFTMFW
    My leafs squeak like crazy. Which fix did you use?
  19. Jul 15, 2015 at 7:39 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    X2
  20. Jul 15, 2015 at 7:45 PM
    hg3
    hg3
    kingsville, texas
    2011 tx pro 4x4
    I found the exact spot when I jacked up the frame in the rear and moved around the leafs. I noticed there is a metal round spacer where they rub on either end by pulling the leafs apart. Put some auto grease on it n that's it. Did the other side without having to Jack, but needed a prybar. I don't know if this has been explain in other forums but that's how I'd explain it
