  1. Aug 1, 2015 at 6:21 PM
    XCDave
    XCDave Well-Known Member
    David
    2015 TRD 4X4 long bed dbl cab
    None at this time.
    Just some stickahs
    Lord Helmet and T4RFTMFW like this.
  2. Aug 1, 2015 at 6:23 PM
    XCDave
    David
    None at this time.
    What's the best way to get these emblems off ? (De badge)
  3. Aug 1, 2015 at 6:25 PM
    truckyeah
    truckyeah Active Member
    Apopka, FL
    2015 MGM V6 MT AC OR
    got my catch can installed
    lonewolf1911 likes this.
  4. Aug 1, 2015 at 6:27 PM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    Im a newb to catch cans, whats it do
  5. Aug 1, 2015 at 6:33 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Fishing line
    XCDave[QUOTED] likes this.
  6. Aug 1, 2015 at 6:35 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Keeps oil out of intake runners
  7. Aug 1, 2015 at 6:35 PM
    truckyeah
    Apopka, FL
    When combustion occurs, some amount of pressure passes the pistons and enters the crank case. The PCV valve releases this pressure and a hose usually directs it right back to the intake. Unfortunately, this air contains some oil mist as well. The oil catch can catches the oil mist allowing only air to go back into the intake instead of air plus oil mist. Over many many miles, this oil spraying back into the intake creates a buildup that increases drag on the air going into the cylinders causing reduced efficiency (i.e. less horsepower and mph) although not a huge difference. If you are looking to keep a truck for a really long time and want it to run it's best as long as possible, it's one of the little things you can do to help out a little bit.
    This is the intake on my last truck after 200k+ miles due to this.
    PatrickR and Lord Helmet like this.
  8. Aug 1, 2015 at 6:40 PM
    DougsGraphics
    DougsGraphics Duck Hunter!
    Doug
    Northern New Mexico
    2015 Pyrite Mica DCSB TRD OR
    3" Revtech Level, ARB Deluxe Bull Bar front bumper with WARN 9.5XP Winch and KC Pro-Sport LED Driving Lights, black Diamond Back HD tonneau cover, 4 cameras through Entunes display with capacity for two more, LED interior lights with map lights tied to dome, Bussman auxiliary fuse/relay box with 100 amp breaker/disconnect under hood.
    Took all day, but I got my fuse/relay block built and installed and all the existing add-ons rewired, despite the constant rain. I have lot of extra capacity pre-wired at this point. Now I can move forward with the CB install, then the extra cameras...
  9. Aug 1, 2015 at 6:43 PM
    Larry
    Larry CARL
    CARL
    She's a beaut...Clark
    Mr. Ed's taco likes this.
  10. Aug 1, 2015 at 7:24 PM
    packers15
    packers15 Well-Known Member
    I got it off ebay for $227 shipped, the seller was lexusofnorthmiami and it was the cheapest I found.
    mahaloTaco[QUOTED] likes this.
  11. Aug 1, 2015 at 7:34 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    The flag sticker is crooked :p
    RileyLAFD likes this.
  12. Aug 1, 2015 at 7:36 PM
    Mr. Ed's taco
    Mr. Ed's taco Well-Known Member
    New color matched grill, Barcelona red emblem, and LED DRLs all done over a couple days. 9ff847f76d71683960a0466bceb393a9_818c0a17b43046d255c987f5b493eb3004e20e7c.jpg
    JustinL likes this.
  13. Aug 1, 2015 at 7:37 PM
    ManBeast
    Zach
    Orange Park FL
    How much did you pick up leds for
  14. Aug 1, 2015 at 7:37 PM
    Lord Helmet
    Nick
    '24 X3 M40i
    Nice place for the catch can (I have the same one and color :thumbsup:) It's a shame my volant air scoop would block access to it. BTW it's pretty far from the PCV IMO unless you plan to run dual catch cans?
  15. Aug 1, 2015 at 7:38 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I like the placement!
  16. Aug 1, 2015 at 8:05 PM
    XCDave
    David
    None at this time.
    What can I say, I'm a Marine.
    IPNPULZ and pruchai like this.
  17. Aug 1, 2015 at 8:06 PM
    r2oh
    r2oh Well-Known Member
    Denver Colorado
    2010 white tacoma trd sport
    Fox 2.5 factory series dsc coil over Fox 2.0 dsc Total chaos uca Total chaos lower control arms Ome dakar Toytec extended break lines Scs stealth 6 gunmetal grey wheels bfgoodrich a/t ko2 tires 285/70/17 Quick stop drilled & slotted rotors Trd cold air intake (1st gen) Trd exhaust Optima yellow top battery Rigid 40" led bar and 4 pods & 20" Retrofit masters custom headlights Rci front,transmission,transfer case skid plates Pilfreybuilt front bumper single hoop Smittybuilt 9000xrc comp winch Factor 55 fairlead InSain fabrication cmc and sliders Total chaos weld on cam tab guests U bolt flip kit Prinsu roof rack Cvj axels Jersey hubs wheel bearings Ecg needle bearing Cvj rack and pinon
    IMG_20150801_195716.jpg Finished installing bpf grill and skid plate
  18. Aug 1, 2015 at 8:16 PM
    Mr. Ed's taco
    $200 on Amazon. I have a second set for sale that were unpainted and I painted black. Just slightly different wiring.
  19. Aug 1, 2015 at 8:41 PM
    lonewolf1911
    lonewolf1911 Where's my wolf pack?
    JT
    WA
    12' DCSB TRD OR 6SPD
    I lost track...
    Nice install, this is going next on my list. Link for catch can? How did you mount it and what lines get tapped into?
  20. Aug 1, 2015 at 9:03 PM
    Tacoma Off Course
    Tacoma Off Course Well-Known Member
    Austin
    Houston, KS
    2005 DCSB Prerunner SR5
    Stuff
    Finally got around to re-doing the raptor style satoshi mod with a new black grille from rock auto after my original color matched grille surround flew off and got ran over :mad: Also derped the letters red. What do y'all think? still deciding if I like it.
    And I installed a truck tool box from wally world. lol ignore the dirty truck
    I also made a mount for my firestick that goes between the space on the side of the tailgate. No pics yet as I am installing the cb radio tomorrow and hooking everything up
