  1. Nov 4, 2015 at 10:09 AM
    scocar
    scocar Patron of the Farts
    Well both I guess. I meant the steering wheel, but both. From what I have seen most pieces on 2nd gens are like Lego, but I just came from a 1st gen, that uses actual fasteners like screws that you can see, LOL.
  2. Nov 4, 2015 at 10:16 AM
    docloco
    docloco Well-Known Member
    Ron
    Florida
    2015 MGM DCSB 4x4 TRD OR
    For the steering wheel, there are two access covers on either side. The left is by itself, and the right is around the cruise control arm. Pop those off with a trim tool. Then you will have access to the two bolts that hold the airbag. Its a torx screw (don't remember the size off hand). They will screw out, but have a plastic piece that prevents it from completely being removed. After you've loosened those up, the airbag unit is free. I just moved it out of my way. Now that thats out of your way, there are several screws now exposed to remove the spokes. After you take those off, they are still attached to the radio and phone controls. There are 3 screws to separate these. then you can go paint them and reverse the process.
    scocar[QUOTED] likes this.
  3. Nov 4, 2015 at 10:18 AM
    docloco
    Ron
    Florida
    The radio head unit was a little more of a pain because it connects into the dash on the left side and I couldn't find any other instructions on here or youtube so I winged it. This got me half way there.
    LamzTaco and scocar[QUOTED] like this.
  4. Nov 4, 2015 at 10:25 AM
    RileyLAFD
    RileyLAFD Well-Known Member
    Riley
    City of Angels
    '14 DCLB Magnetic Grey
    I guess I've got to start this very soon....
    2014 DCLB CAB Mount chop and cut some fill plates.
    Going to wait to fill... Once I put the 35s I'll check for rubbing and either cut more or fill.
    Crom likes this.
  5. Nov 4, 2015 at 11:16 AM
    scocar
    Nice, thanks. I still have yet to do the first oil change or even install my Redline hood struts. A lot of time has gone into trying to unfuck Entune, too.:rolleyes:
  6. Nov 4, 2015 at 11:21 AM
    docloco
    Ron
    Florida
  7. Nov 4, 2015 at 11:26 AM
    iK0NiK
    iK0NiK Insert custom title here.
    West
    Columbus, GA
    2015 DCSB V6 TRDOR 4WD
    Bil 6112/5160's etc.
    Took her across the scales. 4,740lbs with a full tank of gas and 2 passengers.
  8. Nov 4, 2015 at 12:24 PM
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    Must be stock? I was 1200lbs heavier with me, the dog, and an empty tank
  9. Nov 4, 2015 at 12:34 PM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    I just changed my Entune radio on my 2014 to a 2015 unit with Nav. It was a bit difficult to get out. I can try to help if you need info since I just did mine last weekend, so it's still a bit fresh in my mind.
  10. Nov 4, 2015 at 12:46 PM
    diverdale
    diverdale #sosconceptscrew
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Fox 2.5 Coilovers, Fox 2.0 Rear Resi, Icon 3 Leaf AAL
    I just swapped my 15' entune...the climate controls pop out (no screws) ... 2 plugs on the back. Then the 4x10mm bolts at the bottom of the head unit/bezel (need socket extension). then it has 2 prongs (left/right) on the bottom and 3 across the top. Best to use nylon pry tool at the sides on the bottom then pry from the top.
  11. Nov 4, 2015 at 12:46 PM
    iK0NiK
    West
    Columbus, GA
    Pretty much. Alloy wheels and step bars are the only thing that'd really cause any weight difference.
  12. Nov 4, 2015 at 12:53 PM
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
  13. Nov 4, 2015 at 1:02 PM
    la0d0g
    running for the hills
    For crawling not hauling
    You're missing one :eek:
    RileyLAFD, omaguz and Acerwin[QUOTED] like this.
  14. Nov 4, 2015 at 1:08 PM
    Cmurder
    Cmurder 2011 TX TRD Offroad
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
  15. Nov 4, 2015 at 1:09 PM
    Cmurder
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    New tires. Didn't need aggressive off road tires. I'm a city slicker image.jpg
    George P. Burdell likes this.
  16. Nov 4, 2015 at 1:20 PM
    Oregon TRD
    Oregon TRD "GO DUCKS" Edition
    Ross
    Steel Panthers bathroom floor!
    2005 Mall Krawler
    6" Fabtech Lift, 35" Fierce M/T 17" Eagle Alloy Sim bead locks Naked girls in the bed 10.1" DVD head unit Two 7" Headrest Monitors PS2 in glove box
    What size?
    Acerwin[QUOTED] likes this.
  17. Nov 4, 2015 at 1:37 PM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    If it's any help you need to be within 3 years or 60,000km or have the extended warranty to get it fixed.
    Tried getting mine replaced due to the dtrl causing the lens to crack. No Bueno. Even though the issue was the cause I was over. Kinda pissed but that's the way she goes.
  18. Nov 4, 2015 at 1:52 PM
    tyfoon11
    tyfoon11 Raguel
    J
    Where bald eagles roam, Ca
    garden shed
    work in progress...
    been staring at my AP leafs waiting to go on when I get the rest of my suspension and noticed that despite never being installed and sitting in my conference room they have a fair amount of rust on them already :mad:. since rust in leafs prings tends to mean squeaking I decided to do some pre-emptive maintenance....
    the plan was pulling them apart, sanding rust off and spraying rust inhibitive paint, then fluid film, then generous amounts of lithium grease before reassembly
    starting to wonder what the f#@K I've gotten myself into... :(
    BudMan, omaguz and Crom like this.
  19. Nov 4, 2015 at 2:08 PM
    Link6
    Link6 Well-Known Member
    Lansdale, PA
    2015 Black DCSB SpoRt! 6-spd
    New wheels and tires :) TRD Matte Black Wheels & Cooper ST Maxx 265/70/17.
    [​IMG] [​IMG] [​IMG]
    Also, the shop managed to break one of the TPMS sensors, so come Monday, I'll have a new one of those.
  20. Nov 4, 2015 at 2:20 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    @tyfoon11 Jay, I've never seen an All pro leaf pack apart before. I see they have enough sense to put the leaf spring isolators in there to help keep them quiet. Whether you paint them or not, I'd recommend dry moly lube, instead of a wet grease. It helps keep debris from getting stuck in the leaves. And rust looks normal to me. Better than my Dakars were when I took them apart. :D
