  1. Feb 1, 2016 at 5:42 PM
    Night Eagle
    Night Eagle Aka Mountain Goat or mr. Clean
    Leo
    Steamboat Springs, Co
    2014 TDR Off Road
    Enough to make it a lot of fun!
    Incorrect the gauge of affects the amperage that a wire can carry with out burning up. If you want less voltage drop you want to up size the wire and you will loose less voltage. The bigger the wire the less resistance you get. Which translates into less heat.
    TownvilleTim likes this.
  2. Feb 1, 2016 at 5:48 PM
    NeedmoreTaco
    NeedmoreTaco Garage full of white Toys...
    Eric
    Travelers Rest, SC
    2012 Super White DCSB Prerunner
    LEDs and stuff
    Length of wire also affects resistance as well as voltage drop. You have to take into consideration both length and gauge when sizing wire not just gauge.
  3. Feb 1, 2016 at 5:48 PM
    Night Eagle
    Leo
    2014 TDR Off Road
    The only way you will trip the circuit is if you put a device on the cord that needs to pull more than 4 amps. The circuit will not trip if it does have the right voltage. The device that you are trying to power will just not work right.
  4. Feb 1, 2016 at 5:50 PM
    THE CALICO
    THE CALICO Well-Known Member
    Colton
    Nashville
    Black 2014 TRD SPORT ACCESS CAB
    I was thinking like a 20' cord. I don't think the drop would be too harsh to render it useless, you could also just tap in a permanently fixed outlet next to the retractable.
  5. Feb 1, 2016 at 5:50 PM
    Night Eagle
    Leo
    2014 TDR Off Road
    I never said it was. That is why I was saying up sizing your wire size, which is awg ( which stands for gauge), because the resistance will go down because there will be more surface area for everything to move.
  6. Feb 1, 2016 at 5:56 PM
    udy2554
    udy2554 NORTHERN RED-NECK
    Naples, NY
    '06 Tacoma TRD Sport
    Toytec ULK, Light Racing UCA's, OME Dakar rear leaves, ARB Bumper with XRC8 winch, Good Year Duratracs 285/70/17's on 17x9" Level 8 Strike 6's. Leer cap in the winter. Pioneer Double Din with BT, iPod, etc. Boston Acoustic components in all 4 doors with a Sony amp, powered 8" sub. Ultra gauge, Tom Tom...
    Finally got my "spare" mounted on a factory SPORT wheel so I can rotate 5!
    I also got the IBS-DBS Battery setup,ATO box, and Bluesea fuse block in place! No pics till I neaten up the wiring a bit!
  7. Feb 1, 2016 at 6:02 PM
    NeedmoreTaco
    Eric
    Travelers Rest, SC
    LEDs and stuff
    Then how is what I originally said incorrect? The inverter only produces 4 amps, odds are the cord will be rated for much more than that so there will be very little resistance and amps do not drop over a length. The wire can over heat and burn up but that's it. Longer lengths require heavier gauge wire to carry the same amps as a shorter length. Right? That's what I originally said.
  8. Feb 1, 2016 at 6:07 PM
    Night Eagle
    Leo
    2014 TDR Off Road
    The way you wrote it stated that the wire would no effect anything. At least that that is how I read it. It could have been just a misunderstood on how you worded it.
  9. Feb 1, 2016 at 7:24 PM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    Installed my rear bilstein 5100's. Have to wait for the weekend to do the fronts with 885's and rear aal.:annoyed:
    kgarrett11 and ChadsPride like this.
  10. Feb 1, 2016 at 7:30 PM
    Houston Kid
    Houston Kid Badges, we don't need no stinking badges
    Houston Texas
    2012 White Tacoma TRD 4x4
    Yes you are. You get more MPG and HP gains by adding it to the right side.
    You get only .0000001259745 HP and 0 MPG improvement because it does not have TRD on it somewhere. If it had TRD on it you would get at least .0000001259744 HP and .49874 MPG improvement.
  11. Feb 1, 2016 at 7:32 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    HAHA:amen: @Houston Kid is funny af :rofl:
    Houston Kid[QUOTED] likes this.
  12. Feb 1, 2016 at 8:13 PM
    bledsoe3
    bledsoe3 Well-Known Member
    Portland
    '15 DCLB Limited
    SnugTop, Air Lift bags, Bilstein 5100's up front, AAL in rear, 275/70/18 BFG AT TA KO2, URD TCAI, URD Cat Back
    Taco77[QUOTED] likes this.
  13. Feb 1, 2016 at 8:49 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    I like the grill. :thumbsup:
    :pout: but i need a snorkel
    kgarrett11 likes this.
  14. Feb 1, 2016 at 8:56 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    Need, or want? :D
  15. Feb 1, 2016 at 9:30 PM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    I used a piece of 1/8th thick, 1.5 inch wide aluminum flat stock. Drilled two holes for stainless steel bolts to slide through and painted the aluminum black. A few washers were needed to allow everything to mount up nice and snug. No more rust and it isn't going anywhere.
  16. Feb 1, 2016 at 10:56 PM
    GRrallye
    GRrallye Member
    Installed a power rear-view mirror with compass/outside temp readout I got out of a junked GM , and got a dump run in with my new cargo net
    NeedmoreTaco likes this.
  17. Feb 2, 2016 at 2:47 AM
    whopper
    whopper 2016 MGM 4x4 double cab
    wayne
    north carolina
    2016 tacoma double cab 4x4 MGM
    On going
    I'm sure they would look great for $20 for the reflective
  18. Feb 2, 2016 at 3:36 AM
    NeedmoreTaco
    Eric
    Travelers Rest, SC
    LEDs and stuff
    Wow...yeah I did word it weird, that was not what I was trying to say. It even confused me when I read it this morning. I'm not a night person at all.
  19. Feb 2, 2016 at 4:37 AM
    whopper
    wayne
    north carolina
    On going
    I installed the 4D on a friends 2015 he loves it so I got me one ordered should be here this week
  20. Feb 2, 2016 at 5:37 AM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
