  1. Apr 17, 2016 at 11:11 AM
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    '10 Tundra TRD RockWarrior
    Yes.
    New HF radio installed. Replaced the Kenwood TS-480Sat with an Icom IC-706Mk.II g
  2. Apr 17, 2016 at 11:18 AM
    Ae7mj
    Ae7mj Member
    Alex
    Washington - the dry side
    2013 DCSB TRD OR BRM
    Washed, oil and filter change, shafts lubed :jerkoff: and then moved the diff breather into side cubby.
  3. Apr 17, 2016 at 11:21 AM
    Allstar780
    Allstar780 Well-Known Member
    Colin
    Alberta, Canada
    15 TRD Trail Teams Sport
    3" Lift, 32" Goodyear Duratrac, XD Series Hoss Rims
    @Ae7mj This is where I put mine as well... Why so many people put them in the gas door is beyond me
  4. Apr 17, 2016 at 11:22 AM
    Ae7mj
    Ae7mj Member
    Alex
    Any problems with RF intrusion? I tried three setups but every time I got RF into the ECU. Kept setting off codes. Especially 40m.
  5. Apr 17, 2016 at 11:24 AM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    been stuck at home for the last 2 weeks recovering from surgery. i've been posting little things i've done. i finally figured out how to post some pics so here goes nothing special. first was at dealership in december the others are now.
  6. Apr 17, 2016 at 11:27 AM
    Ae7mj
    Ae7mj Member
    Alex
    I don't have the small cubby behind the gas door.... and it gets wet in there! So it was here or behind the taillight. I've seen too many taillights filled with water to be comfortable with that spot, so big cubby it is :thumbsup:.
    If I get too deep, I'll be changing more than diff lube anyways.
  7. Apr 17, 2016 at 12:14 PM
    InTheRough
    InTheRough Well-Known Member
    Kolt
    Gig Harbor, WA
    '20 Tundra Platinum
    Rock Warrior wheels
    Used it for our baby girl announcement photo.
  8. Apr 17, 2016 at 12:14 PM
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    Yes.
    I haven't had any troubles at all so far.
    I've gone through and bonded everything though with 1" braided ground strap. Also I think running 4awg power and ground direct from the battery into the cab has helped.
    Ae7mj[QUOTED] likes this.
  9. Apr 17, 2016 at 12:16 PM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
  10. Apr 17, 2016 at 12:27 PM
    Cr47524
    Cr47524 Well-Known Member
    Chase
    Savannah GA
    2015 Tocoma 4WD TRD OR
    Full 3in OME lift, level 8 bully pro wheels, 285/70/17 Bro's, avid front guard, Anti-theft tailgate mod, tailgate reinforcement skin/cap, relocated the 7pin, door sill covers, snug top,blacked out tail pipe, a-pillar ram mount, 35% on the front,and stubby antenna.
    image.jpg Installed this today.
  11. Apr 17, 2016 at 12:33 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Washed,waxed and changed the rear diff fluid......
  12. Apr 17, 2016 at 12:47 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Took my Weathertech 's out of it and power washed a winters worth of filth off of them.
    Kuntrykid likes this.
  13. Apr 17, 2016 at 12:49 PM
    floodedkiwi
    floodedkiwi Well-Known Member
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    Installed US Offroad winch bumper package.
    Cr47524, el topu, TOYTONKA and 5 others like this.
  14. Apr 17, 2016 at 12:53 PM
    IPNPULZ
    going to be fun!
    That looks awesome!!!
  15. Apr 17, 2016 at 12:57 PM
    Jawa
    Jawa Well-Known Member
    Georgia
    2007 DCSB 4WD TRD Off-road
    image.jpg Swapped out the spark plugs on my new to me 2007 Tacoma. With 87k on the odometer I was not expecting to find the original plugs but that's exactly what I found. NGKs on the drivers side and Denso's on the passenger side. Replaced the originals with Denso's and it runs like a completely different truck!!!
    As has been documented on TW many time before the Denso's held up better than the NGK's.
  16. Apr 17, 2016 at 1:18 PM
    Beltfed762
    Beltfed762 Well-Known Member
    Virginia
    2011 DCSB TRD Offroad
    6" lift, 35x12.50R20 Firestone m/t, 20x10 XD Spy wheels, Fox shocks/coilovers, dif breather mod, SAIS delete, Alcan +5 leaf springs, U-bolt flip kit, Superbump bump stops, cab mount chop, poly performance leaf bushings, taco tabs, all-pro cam tab gussets, diy fender trim, fender flare delete, pinch weld smash, cloth seat delete + factory leather swap, seat heaters, remote start, 20% tint, ARE camper shell, ... im sure im forgetting something.
    Installed my sPod. Changed engine oil and filter plus the gear oil in the diffs and transfer case.
  17. Apr 17, 2016 at 1:48 PM
    NKYTaco
    NKYTaco Well-Known Member
    Brandon
    South Eastern Indiana
    2014 MGM TRD Pinstripe Edition
    had to get to the range
  18. Apr 17, 2016 at 1:49 PM
    Ohiophil
    Ohiophil This space intentionally left blank
    Phil
    Central Ohio
    2015 Tacoma PreRunner
    Give me some money so I can fill in this info
    That's the most handy thing to have that I hope you never get to use
    sapperguy, yote and jwctaco like this.
  19. Apr 17, 2016 at 1:50 PM
    Cr47524
    Chase
    Savannah GA
    That's the truth.
  20. Apr 17, 2016 at 1:50 PM
    Ohiophil
    Phil
    Central Ohio
    Mine is mounted in pretty much the same spot
