  1. May 12, 2016 at 1:10 PM
    mrbedgood
    mrbedgood Isaiah 6:8
    North Carolina
    '11 MGM DCSB TRD Off Road 4x4
    Total Chaos +2" Long Travel Kit; King/TC 2.5 LT C/O w/ 16"x600; TC/CVJ Extended Axles; TC Spindle Gussets; King 2.5 RR shocks; All-Pro Expendition Leaf Pack; Pelfreybilt Sliders; Anti-Dark LED Hood Light mod; LED map and dome light mod; Bed lights; TRD Cold Air Intake; KB Voodoo Tailgate cap system; HomerTaco Thin Lip "Raptor" grille; sPod SE System w/ LCD Touchscreen; Baja Design OnX6 40"; Baja Design S2; Rigid Industries LED Rock Lights; Front Runner Slimline II Roof Rack; A.R.E. Z Series Camper Shell Projector BHLM Headlights (with custom wiring); Method Racing NVs 17"x 8.5; and Nitto Terra Grappers 265/60/17
    Thanks
  2. May 12, 2016 at 1:15 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Dd
    Hey do you have pics of ths setup i.e. where outside edge of tires are in relation to fender flare/mudflaps?
    ManBeast likes this.
  3. May 12, 2016 at 1:23 PM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    Yes got the stock size. I am liking them early on.
  4. May 12, 2016 at 1:28 PM
    09BlueBeast
    09BlueBeast Well-Known Member
    Cody
    Denver
    09 Speedway Blue TRD Sport 4x4
    You can't just turn it off? My '09 u can cycle through the gauge cluster and select beep off
    drknsurfur likes this.
  5. May 12, 2016 at 1:30 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    I'll post up some pics in a couple weeks when I do the tire swap. I ended up buying some used center caps on ebay for $18 set shipped from a reputable seller so I'll have a couple extras (I was missing one cap). I assume when you say "yours don't work on the 2nd gens" you are talking about the center caps as the wheels should fit as they are pretty much the same specs as the 2nd gens. As for the center caps, you would think they would be the same, but some are 5.5 od and some are 5.25 od. If they have metal clips they should work on the older wheels, if they have plastic clips with the circular metal spring type ring they most likely fit the newer wheels. The 17's on the Tundra are the larger ones.
  6. May 12, 2016 at 1:36 PM
    mcdee
    mcdee Well-Known Member
    mike
    Northern Cal
    12 PreRunner OffRoad TRD
    TRD center cap, quick bed mat, Gatekeeper, WTs, TRD skid plate from bpfab, plastidip emblems, security slider bar, interior LEDs, AFE Pro Dry air filter
    Did my bi-annual interior/exterior full detail. Use Klasse All In One cleaner/protector then Klasse sealant for body and windows; 303 for interior, exterior trim, and tires. I am getting old, it used to be fun, now in the category of labor of love. It takes me a day and a half; wash, 303 tires and trim the night before then I get up early AM for wax/sealant. Now that I'm done I ordered a lug nut brush and some Duragloss 253 from autogeek. Got it all ready for my soon to be delivered shift knob from the AJT group buy! Considering the black TEQ grill badge I noticed on yazmatic's truck.
  7. May 12, 2016 at 2:05 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    tell me if this helps or if you need something else. i chose the bs and offset because i wanted the tires to stick out a little with no spacers and theres a good bit of room behind them.
    IronPeak[QUOTED] likes this.
  8. May 12, 2016 at 2:06 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    here sorry o hit the wrong button
    IronPeak likes this.
  9. May 12, 2016 at 2:14 PM
    IronPeak
    AuggieX
    Back to Back
    Looks great, I had 285s on my 07 and rather than buying new wheels I got spacers to get my tires off my UCAs which turned into a headache, I'm gearing up to lift, etc my 2015 and getting wheels with offset is high on the list thx for the pics
  10. May 12, 2016 at 3:41 PM
    DC-USAF
    DC-USAF Well-Known Member
    Dale
    WNC
    2015 SR5 Access Cab 4x4 V6
    TRD PRO Grill, mobtown offroad recovery bar, SCS Ray 10's
    If you get regular household carpet and you trim it close to the walls of the bed you will not need double sided tape, velcro, or spray adhesive plus if you need to haul something that will get the carpet dirty it is easy to remove and install.
  11. May 12, 2016 at 3:52 PM
    iamtallerthanu
    iamtallerthanu Well-Known Member
    Jim
    Marietta, GA
    07 PreRunner SR5
    My bikes were mounted in the rail. They whistled and wobbled back and forth because I could never tighten the mount to the rail well.image.jpg
    I used a 6x2 board and routed out holes for my d rings to stick through. Routed out a rail to put these big nails I had in the garage to hold the board. image.jpg
    Loaded it up and works great. Sits lower than top of cab and doesn't wobble at all. image.jpg
    mightym, Ex-MA Hole, ManBeast and 3 others like this.
  12. May 12, 2016 at 4:02 PM
    texred73
    texred73 Trailrunner07dsm
    brian
    Houston
    07 Prerunner SR5 DC DSM TRD Offroad
    Only the maglight mod,mounted on floor drivers side, billet antenna and have lined all storage under rear seats with rubber to keep the rattling to a minimum.
    And to get taller tire you need a lift so yeah. Hand in hand they go. Haha.
  13. May 12, 2016 at 4:05 PM
    asuchemist
    NONE
    I like that setup. Discount didn't have those tires available. Looks good
    LivinLoud[QUOTED] likes this.
  14. May 12, 2016 at 4:09 PM
    Ajak
    Ajak Well-Known Member
    ATX
    '07 DCSB Indigo Ink
  15. May 12, 2016 at 4:10 PM
    Pigpen
    Dan
    Northwest Montana
    Wrong. You need a sawzall to fit taller tires properly. You could do 37s with zero lift.
    Kuntrykid and la0d0g like this.
  16. May 12, 2016 at 4:19 PM
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    Link to what you used?
  17. May 12, 2016 at 4:20 PM
    la0d0g
    running for the hills
    For crawling not hauling
    No, to get taller tires you need to be willing to cut. I run 315s with a little over 2" of lift.
  18. May 12, 2016 at 4:24 PM
    ajdillon
    ajdillon Well-Known Member
    Andrew
    2015 Tacoma PreRunner SR5
    Took the lawn mower into the shop for a tune up
    ajdillon
    ChadsPride likes this.
  19. May 12, 2016 at 4:38 PM
    Baggerboy11
    Baggerboy11 Member
    CA
    Where did u buy this ?
  20. May 12, 2016 at 4:50 PM
    RogerRZ
    RogerRZ Well-Known Member
    New Brunswick, Canada
    White '14 DCLB TRD Sport
    Installed a Back Rack, gave me a spot to mount antennas, and a couple of backup/work lamps.
    Colon3lcrunch and Black Taco like this.
