  1. May 24, 2016 at 4:11 AM
    PvilleJohn
    PvilleJohn SVT Raptor
    Powdersville SC
    SVT Raptor
    If you've never tried Paint Protect by meguiars, id recommend it. I had a 2013 Ford Fusion before I bought my 2015 Tacoma. The fusion was bought as a demo with 30,000 miles on it and covered in swirl marks. One application of paint protect and the swirl marks were pretty much all gone. It makes your paint feel like it was just cleaned with a clay bar. It's so slick, when you're driving in the rain...the dirty water from the road mostly rolls right off and the vehicle stays mostly clean. The best part is you can put it on everything but the glass and mirrors so apply it to your rubber trim...it darkens it back down, apply it to your headlights and taillights and itll help keep the sun from fading/oxidizing them. It's much easier than wax to apply also. Just make sure you use a microfiber towel to wipe it back off.
    stbear, Soul Surfer and Kuntrykid like this.
  2. May 24, 2016 at 4:43 AM
    iK0NiK
    iK0NiK Insert custom title here.
    West
    Columbus, GA
    2015 DCSB V6 TRDOR 4WD
    Bil 6112/5160's etc.
    Is the durability even close to what they claim it to be? I've been using liquid wax combined with spray wax for the past 8 months and even that combination begins to lose its beading properties after a couple months.
  3. May 24, 2016 at 5:29 AM
    simplehuman
    simplehuman Well-Known Member
    AKA the military HMMWV (Humvee) mod. Great for deep water situations and the 'DO NOT USE FOR' cruise control.
    ChadsPride likes this.
  4. May 24, 2016 at 5:54 AM
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Pittsburgh, PA
    2013 Black Baja Access Cab
    Can you provide a link for the outlet you used? The labeled cover is both safe and clean.
    NosiBaLasi likes this.
  5. May 24, 2016 at 6:18 AM
    Joelev
    Joelev Well-Known Member
    Took the kids to the petrified forest.
  6. May 24, 2016 at 6:44 AM
    Kuntrykid
    Kuntrykid Tacoholics R Us
    Jon
    Sharpsburg, MD
    2015 tacoma 5spd access cab 4x4 red
    https://www.tacomaworld.com/threads/kuntykid-builds-a-taco.406341/
    How is this done exactly? Is there a write-up on this MOD?
  7. May 24, 2016 at 6:50 AM
    simplehuman
    You'll have to ask these guys if they have a writeup. As for the HMMWV, there is a throttle control on the dash that allows the driver to set the throttle so they can drive with no foot on the accelerator. They are supposed to be used for fording water, but we usually used them as a cruise control.
  8. May 24, 2016 at 6:54 AM
    Kuntrykid
    Jon
    Sharpsburg, MD
    Can it be used it a gas pedal itself so that feet can use clutch & brake pedals? Like a throttle on a ATV of some kind. Srry just extremely curious bout this
  9. May 24, 2016 at 7:01 AM
    simplehuman
    Yeah, you pull the lever to adjust the throttle in the same way you push the gas pedal except the lever stays in place and doesn't return to zero. So you set your throttle to whatever RPM/speed you want then take your foot off the brake to go. Down side is that it doesn't adjust for torque or speed changes or disengage automatically like the cruise control.
    Kuntrykid[QUOTED] and ChadsPride like this.
  10. May 24, 2016 at 7:05 AM
    Kuntrykid
    Jon
    Sharpsburg, MD
    So it's like a clutch that can't stall? That sounds a lot like my dads old power king tractor. If you remember them... Lol
  11. May 24, 2016 at 7:08 AM
    simplehuman
    More like the tractor, but less of a clutch since it doesn't adjust on its own. The HMMWVs are all automatics so there's no clutch to factor. Just throttle or more appropriately, the stead stream of gas into the engine.
  12. May 24, 2016 at 7:11 AM
    Kuntrykid
    Jon
    Sharpsburg, MD
    Kool. How would that work on a 4banger? Also saw a MOD before to convert 1st gear to granny gear. Like that as well.
  13. May 24, 2016 at 7:14 AM
    simplehuman
    Engine size doesn't matter, but I would be careful with the MT vs. AT. When I had my MT Ranger I used the hand brake to control the brake and my feet to control the clutch and gas. Safer, but you only control one wheel. There's also a hand brake mod on here somewhere.
  14. May 24, 2016 at 7:18 AM
    Kuntrykid
    Jon
    Sharpsburg, MD
    MT vs AT. Which is better I have MT
    scottalot likes this.
  15. May 24, 2016 at 7:19 AM
    simplehuman
    Asking that question could cause a :crapstorm:.
  16. May 24, 2016 at 7:19 AM
    Kuntrykid
    Jon
    Sharpsburg, MD
    LMAO!
  17. May 24, 2016 at 7:54 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Watch out for that grippy tape when you're wearing shorts. I took the tape off of mine after only a few months.
    ERMB and ctsnow13[QUOTED] like this.
  18. May 24, 2016 at 8:04 AM
    Pigpen
    Dan
    Northwest Montana
    search "hand throttle"
    It doesn't work like an ATV throttle. You have to set the accelerator with your foot and this just holds it. For off road use only.
    Kuntrykid[QUOTED] likes this.
  19. May 24, 2016 at 8:14 AM
    ctsnow13
    ctsnow13 Well-Known Member
    2014 Magnetic Grey TRD DCSB
    Lol. I wish you would've told me that the first time I got out....already tore out a patch of leg hair and my wife's legs looks like she got mauled by a raccoon. I guess I'll see if we end up keeping it
    IronPeak and mach1man001[QUOTED] like this.
  20. May 24, 2016 at 8:22 AM
    TacoAC
    TacoAC Well-Known Member
    Cali
    DCSB In Progress
    Has anyone ever installed fiberglass fenders?
    Mr.PowerTrays and ChadsPride like this.
