  1. May 26, 2016 at 6:08 AM
    sapperguy
    sapperguy Well-Known Member
    craig
    09 SR5 DCLB
    I plastidipped mine, but didn't take it off. I taped off the plastic on top and took the plastic piece on the bottom off. Then after doing it, I realized the plastic then looked like crap compared to the rest of the bumper, so I taped the tailgate and the lights off (as seen in the picture) and put a couple of coats on the plastic to make it look better. I did it over the course of the day to let the separate coats dry.
    ChadsPride likes this.
  2. May 26, 2016 at 6:32 AM
    phx13
    phx13 Well-Known Member
    Rob
    2015 DCSB TRD O/R
    MT stuff, RTT stuff, the usual.
    Rear diff breather behind taillight, put on a sticker, and then cleaned it out for a 3.5 - 4 week road trip we're leaving on today
  3. May 26, 2016 at 6:58 AM
    whiskeytacos
    whiskeytacos Well-Known Member
    New York
    '14 DCSB Off Road MGM
    OME 886 springs on 90000 struts Total Chaos UCA OME Dakar + AAL energy suspension steering rack and sway bar bushings SCS SR8 wheels Cooper ST Maxx 285/85r16 Pelfreybilt IFS skid plate Pelfreybilt hidden winch mount broken ass winch Softopper All Pro Off Road OTT pack rack
    I hope there's a trip report in the works. Safe travels.
    Holloman, phx13[QUOTED] and Kuntrykid like this.
  4. May 26, 2016 at 7:55 AM
    Jocoma
    Jocoma Well-Known Member
    Jo-mama
    Olympia,WA
    08 Prerunner SR5 Rugged Trail
    Home made satochi trd grill BFG AT 265 75 16 Dipped badges TRD stub antenna More to follow : spindle lift,Halo lights, Kicker sound sytem ,Slotted rotors TRD Seat covers When the cash starts flowing
    It took me about 20/25 mins to take the bumper off you don't need to drop the hitch the bumper will slide off with the right bolts.Yep dipped it that was actually the longest part dry time.
  5. May 26, 2016 at 8:07 AM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Put more gas in it than the tank is supposed to hold...
    QChawks, Holloman, j_strength and 3 others like this.
  6. May 26, 2016 at 8:23 AM
    pruchai
    pruchai KAMA3
    Igor
    San Diego, CA
    '14 TRD TX Baja
    Not enough...
    Got rid of the stupid Salex organizer and replaced it with a napkin tray. So much better.
  7. May 26, 2016 at 8:24 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    I don't know where or why, but i heard you aren't supposed to do that for some reason :notsure:
    j_strength likes this.
  8. May 26, 2016 at 8:26 AM
    simplehuman
    simplehuman Well-Known Member
    I did this same mod. Nice and organized... until about 6 hours later it looked like this:
  9. May 26, 2016 at 8:26 AM
    pruchai
    pruchai KAMA3
    Igor
    San Diego, CA
    '14 TRD TX Baja
    Not enough...
  10. May 26, 2016 at 8:28 AM
    simplehuman
    Pressure buildup in the tank. The tank can hold more than the advertised capacity to allow for expansion.
  11. May 26, 2016 at 8:33 AM
    la0d0g
    running for the hills
    For crawling not hauling
    It also means you depleted most of the gas out of the tank which isn't grand for the pump.
    Thesandaddict and ChadsPride like this.
  12. May 26, 2016 at 8:43 AM
    simplehuman
    This, too.
  13. May 26, 2016 at 9:05 AM
    08TRDOFFROAD
    Dan
    I need to get out of the habit of driving on the bottom end of my tank. I used to fill up every week and it was never below half, but now that money is tighter, for some reason psychologically I feel like it is cheaper to drive it to and past the gas light each time. Maybe because I drive less when I know it is almost out of gas to try to stretch it to payday.
    ChadsPride[QUOTED] likes this.
  14. May 26, 2016 at 9:13 AM
    simplehuman
    My rule is 1/4 tank. I never go below 1/4 tank just in case of emergency, caught in traffic, running late for work, etc., plus it's bad for the pump.
  15. May 26, 2016 at 9:13 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    x2
    I try to do the same
    Kuntrykid likes this.
  16. May 26, 2016 at 9:16 AM
    pruchai
    pruchai KAMA3
    Igor
    San Diego, CA
    '14 TRD TX Baja
    Not enough...
    That won't fly with a ScanGauge. That thing is pretty dumb. You have to re-calibrate it every time you fill up when your tank is not pretty much empty.... and you calibrate it by using a full tank of gas.
  17. May 26, 2016 at 9:24 AM
    SC2TAHOETACOMA
    SC2TAHOETACOMA Well-Known Member
    Josh
    Santa Cruz
  18. May 26, 2016 at 9:24 AM
    Kuntrykid
    Kuntrykid Tacoholics R Us
    Jon
    Sharpsburg, MD
    2015 tacoma 5spd access cab 4x4 red
    https://www.tacomaworld.com/threads/kuntykid-builds-a-taco.406341/
    1/4 tank means time to fill up to me. That's like a gas light to me. Only once have I let gas light come on just to test his far it can go. :D
    Cativelense and ChadsPride like this.
  19. May 26, 2016 at 9:40 AM
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    '10 Tundra TRD RockWarrior
    Yes.
    I drive it to about 1/4 tank most of the time and then fill up. This week I've been rolling around with an extra 10 gallons of fuel in the back seat though. Soon to be an extra 20 gallons in the bed once I check out of this hotel room.
    ChadsPride and Kuntrykid like this.
  20. May 26, 2016 at 9:58 AM
    THE CALICO
    THE CALICO Well-Known Member
    Colton
    Nashville
    Black 2014 TRD SPORT ACCESS CAB
    Did this yesterday but added a front parking/spotting camera and wired it to an AirOnBoard switch.
    938E51B6-2A9B-495A-8F36-FEF58ADAA60D_zps_8c64339abb7f29c06a5e30abfaec8e08d209a418.jpg
    6E039F56-6F82-4CD7-BA5A-DCAC36B8015A_zps_d24f80988f930722184eac2361de992123a17a32.jpg
    Also swapped out all my silver trim pieces with black ones.
    Before:
    DEA2691F-2E21-4164-AC52-BA8BF7CCD75A_zps_2548c1db6e58b2935d199466e51eab344cf1ec41.jpg
    After:
    C894F4D7-B3D2-40CE-A182-C7FC8C9FD225_zps_923d7806bacd69b8361c31b5e3b68d423c17ddb4.jpg
    And finally installed the heated mirror kit I got from a member here.
    172F0E62-9FC7-46AE-B5B9-EB51D7EFA1FC_zps_b30bed992fa2a17eb2b5f991b70c7f05be0ade7a.jpg
    Today I'll hopefully get my rear wet okoles on.
