  1. May 26, 2016 at 1:48 PM
    THE CALICO
    THE CALICO Well-Known Member
    Colton
    Nashville
    Black 2014 TRD SPORT ACCESS CAB
    The kit from camerasource.com was the most expensive part. I think it was $270. There's got to be something cheaper out there I was just growing impatient. The camera was only $14 and I think the switch was around $30. More planning than time actually spent doing the work. I'd say if you were completely ready about 2hrs.
    ChadsPride likes this.
  2. May 26, 2016 at 3:10 PM
    Kuntrykid
    Kuntrykid Tacoholics R Us
    Jon
    Sharpsburg, MD
    2015 tacoma 5spd access cab 4x4 red
    https://www.tacomaworld.com/threads/kuntykid-builds-a-taco.406341/
    Gave the Taco a much needed bath! Still got wheels to do though.
    0Taco6 and ChadsPride like this.
  3. May 26, 2016 at 4:00 PM
    Jamart5
    Jamart5 HoeRunner
    Juan
    SETX
    '16 4Runner TRD
    Got a tool box for the ole' taco. Tractor Supply has them 20% off.
  4. May 26, 2016 at 4:22 PM
    Sith Taco 15
    Sith Taco 15 Well-Known Member
    Myrtle Beach, SC
    2015 tacoma xspx
    Installed front and rear whether techs and front seat slipcovers:dancingbacon:
    Holloman, ChadsPride and Soul Surfer like this.
  5. May 26, 2016 at 4:27 PM
    badmonkey
    badmonkey Active Member
    Bryan
    NW NC
    2015 Taco
    None, yet.
    Looks wicked! What LEDs did you use?
  6. May 26, 2016 at 4:38 PM
    j_strength
    j_strength Well-Known Member
    Joe
    AZ
    2007 Toyota Tacoma TRD Sport 4x4 DCLB
    Received and installed my AAL.
    ChadsPride, Kuntrykid and el topu like this.
  7. May 26, 2016 at 4:40 PM
    el topu
    el topu Well-Known Member
    Juan
    SLC, Ut
    Tundra Limited CM TRD Off-road
    Where did you get the Deaver's? I want to do the same to mine
  8. May 26, 2016 at 4:49 PM
    beavis87
    beavis87 Well-Known Member
    El Paso
    '10 Silver TRD OR
    Went to dealer for leaf spring recall and drivetrain noise. Apparently they think the deceleration noise from 45-30mph is from the leaf springs. Maybe they are just finding me a reason to get new leafs for me. Also they gave me a new Corolla S to drive while they fix timing cover leak covered under my EasyCare warranty. I'm fine paying $250 deductible for a $1000 job.
    ChadsPride and Kuntrykid like this.
  9. May 26, 2016 at 4:57 PM
    j_strength
    Joe
    AZ
    el topu[QUOTED] and ChadsPride like this.
  10. May 26, 2016 at 5:46 PM
    el topu
    Juan
    SLC, Ut
    j_strength[QUOTED] likes this.
  11. May 26, 2016 at 6:09 PM
    txtaco308
    txtaco308 Member
    2007 White PreRunner
    2.5 inch front lift 1.5 inch block in rear
    I have a question for you guys. I am new to taco world and just need some help. I ordered bilstein 5100's for the front and I'm going to set them at 2.5 inches and for the rear I got a 1.5 inch block. My question is what is the biggest tire I can get on there? I have 16 inch wheels with an off set. The tires are going to be KO2's. Thanks
    Holloman and ChadsPride like this.
  12. May 26, 2016 at 6:10 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Are you staying on stock wheels? Are you comfortable with trimming stuff?
  13. May 26, 2016 at 6:11 PM
    G.T.
    G.T.
    CONUS
    Welcome to TacomaWorld, check this section for tons of information that will help you decide.
  14. May 26, 2016 at 6:13 PM
    txtaco308
    txtaco308 Member
    They are made by mb wheels and are 16's and yes I wouldn't mind trimming. I was thing 285/75/16
  15. May 26, 2016 at 6:13 PM
    THE CALICO
    Colton
    Nashville
    Copied these from my build page.
    Steering wheel controls - 84250-04040-C0
    shifter / cup holder trim - 58805-AD010
    stereo surround with 4x4 switch knockout - 55405-04090
    Edit: The Stereo surround without the vents is 55412-04090. It should be a bit cheaper than the other number listed.
  16. May 26, 2016 at 6:14 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Looks like it might just fit between the wheel humps.
  17. May 26, 2016 at 6:15 PM
    txtaco308
    txtaco308 Member
    They are made by mb wheels. They're 16 inch and stick out further than stock wheels. I was thinking 285/75/16. Comfortable with trimming
  18. May 26, 2016 at 6:19 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You can fit those, but be prepared for some serious cutting. At that point it's past trimming plastic, and you're cutting up metal. Look into the cab mount chop as well as hammering the pinch weld.
    If you want to avoid that (I would) then aim for 265/75r16. It's a little smaller so no trimming necessary and lighter, so your mpg won't take quite a hit. Here's my truck on a 2.5" lift running the 17" equivalent size.
  19. May 26, 2016 at 6:22 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    This truck looks sick!!! What sliders are those?
  20. May 26, 2016 at 6:26 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Thanks man! Those are the All Pro Apex sliders and they're line-x'd. I got a GREAT deal on them from a local.
