  1. Jun 20, 2016 at 7:28 PM
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    Don't need leaf spring recall.
    Kuntrykid likes this.
  2. Jun 20, 2016 at 7:30 PM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    It's.....SO.........Clean!
  3. Jun 20, 2016 at 7:33 PM
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    Sang q
    ChadsPride likes this.
  4. Jun 20, 2016 at 7:36 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    [QUOTE[/QUOTE]
    should look like this though
  5. Jun 20, 2016 at 7:36 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
  6. Jun 20, 2016 at 7:36 PM
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    should look like this though[/QUOTE]
    I wouldn't be able to sleep
  7. Jun 20, 2016 at 7:37 PM
    njcoma
    njcoma Well-Known Member
    California
    2017 Accord Sport Special Edition
    Previous: 2006 Tacoma SR5 Prerunner: 2010 4Runner sr5 Rims, TSB rear leafs, Wetokole neoprene seat covers, JVC LED color matched head unit, scanguage II, Flowmaster 40 cat back exhaust, hankook dynapro atm tires, Class 4 Uhaul Hitch. Kicker 12 inch sub and amp. Focal speakers. jba offroad UCAs.. Detroit truetrac rear end... bilstein 5100 rear and 6125 front coilovers. Nfab front bumper with KC apollo lights, bed lights, bluesea systems fuse box....lots of painted stuff.
    Wheeled her out in Otay...
  8. Jun 20, 2016 at 7:40 PM
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR/W-UpGrade Package.
    The clips are a Toyota part I purchased from the Dealer. They had to order them. The part# is in the photo. If you can push in the bezel on either side of the radio and it has a decent amount of play this might help. Also make sure the yellow retaining clips are on the bezel.
    EDIT: Clip Part# 90467-A0001-C0
  9. Jun 20, 2016 at 7:45 PM
    njcoma
    California
    My dash squeaked after I did my radio too... I ended up pulling the whole unit out.. wrapped it in that thin packing foam that you see around new TV's... shoved it back in.. bolted it in... no more squeek :)
  10. Jun 20, 2016 at 7:47 PM
    njcoma
    California
    I feel like spiders are leaping out from your dash :D
  11. Jun 20, 2016 at 7:59 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    If I had a HC bumper it would be. :thumbsup: just one more reason to get one.
    That too. I modded this pack before I knew I was getting an RTT and going full retard.. So now I need to remedy that sag. 2nd overload and re-arch.
    Check out his build! He's thought of everything.
    :cheers: :thumbsup: that was our thoughts as well. Lol
    I kept checkin the mirror and watching it.. It pulls soooooo good.. The new setup is tits! No sway, doesn't jerk you around... Forget it's there. Perfect.
  12. Jun 20, 2016 at 8:11 PM
    Bot_Chu
    Bot_Chu Du Ma
    Nate (Bot)
    Corona, Ca
    2007 ACLB Prerunner
    Enkei RPT-1, ADS 2.5 F/R, 4" Spindles, Toyo RT 315/75/16
    Well here she is made sure she was torqued and align before i took any photos. . . . Shes done! New front bumper coming soon and fender flares!
  13. Jun 20, 2016 at 8:11 PM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Gotcha. I'll double check on the yellow clips, just in case, and might purchase some of those clips too. Thanks!
    Interesting. Might try that as well. Thanks!
  14. Jun 20, 2016 at 8:14 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Put some time into finishing up the engine bay.
    F085A903-F7E1-4E51-8E85-DF120CCA203F_zps_006cc294afc73707dae46f8003e9eda344ff5dd1.jpg
    Then I started on the interior.
    I still need to vacuum the seats/carpet then start on the fenderwells/undercarriage.
    Really not looking forward to doing the underside of the truck
  15. Jun 20, 2016 at 10:18 PM
    1madmnky
    1madmnky Well-Known Member
    Tony
    Kansas via Fullerton 714
    2010 Tacoma 4X4 DCLB
    Hella Supertones
    Anything to keep my wife from driving my truck! :D
    Kuntrykid and ChadsPride like this.
  16. Jun 20, 2016 at 10:32 PM
    twalchlii1
    twalchlii1 Tacotraitor
    Tom
    Wa
    2018 GC Trailhawk
    Are floor mats a mod?
    FIFY!
  17. Jun 20, 2016 at 10:38 PM
    Tayoflor
    Tayoflor Well-Known Member
    Taylor
    Woodinville
    2013 DCSB MGM
    Leer topper BAMF weld on sliders BAMF LCA skids Icon stage 4 SCS F5s wrapped in 285/75r16 Cooper Stt Maxx
    Got some 285/75/16 cooper STT maxx installed on SCS F5s today! Also took my canopy off for a little cleaning and to lay down some new seal tape. Definitely looks a little meaner without the grandpa canopy but I like having safe dry stuff too much to leave it off for good.
  18. Jun 21, 2016 at 4:27 AM
    simplehuman
    simplehuman Well-Known Member
    "Little yellow birdie with a little yellow bill, landed on my window sill...." (Marines will get it)
    EDIT: Just saw that you're a Marine.. S/F!
  19. Jun 21, 2016 at 5:22 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Home depot or Lowes has pins like that
  20. Jun 21, 2016 at 5:23 AM
    Cativelense
    Nuno
    CT
    Interesting. I'll have to pop in and check it out then first. Thanks for the info!
