  1. Oct 2, 2016 at 6:57 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I say go for it. Even if you wait on getting it color matched, silver isn't far off from white. The deciding factor is if you want the higher topper or not.
    ChadsPride likes this.
  2. Oct 2, 2016 at 7:09 AM
    SilverJack
    SilverJack no one
    Edit: I mean seriously? Did Ford have some 1980's Taurus front ends laying around, and they said "hey let's put that on the Raptor".
    kgarrett11 and ChadsPride like this.
  3. Oct 2, 2016 at 7:14 AM
    SilverJack
    SilverJack no one
    Spray, rub, done
  4. Oct 2, 2016 at 7:39 AM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I had an old set of courtesy lights left over from my old BMW. I flush mounted them in the kick panels and installed some Philips Vision LED bulbs.
    I also installed my bed light kit. I have them wired to the dome light circuit so they fade the same way. I also added a pin switch to the tailgate so the bed lights turn on automatically.
    Planemec, DonXavi01, jtweezy and 9 others like this.
  5. Oct 2, 2016 at 7:43 AM
    SilverJack
    SilverJack no one
    Well done Sir! Clean and tight.
  6. Oct 2, 2016 at 8:34 AM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    Diggin the foot lights!
  7. Oct 2, 2016 at 8:49 AM
    VaGlock
    VaGlock Well-Known Member
    Kevin
    central virginia
    14 DBLC / Sport / Blue Ribbon Metalic
    Weathertech mats and wind deflectors, Bak Flip cover, CB Radio,Clazzio seat covers,Scan gauge,Uni filter,LED interior lights, Redline hood struts
    What bed lights did you use, and where did you tap into the dome light circuit? My strip bed lights wont stay attached and want to try something different.
  8. Oct 2, 2016 at 9:14 AM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Thanks, I dig them too. I'm going to do the same thing in the rear when I get time to figure out where I want to mount them.
    I used the OEM set. Part number 00016-34089. The instructions show you the exact wires to tap into:
    http://toyotaofmcdonoughparts.net/products/00016-34089-toyota-tundra-led-bed-lights
  9. Oct 2, 2016 at 9:28 AM
    VaGlock
    Kevin
    central virginia
  10. Oct 2, 2016 at 9:31 AM
    j_strength
    j_strength Well-Known Member
    Joe
    AZ
    2007 Toyota Tacoma TRD Sport 4x4 DCLB
    Looks like I need to get a tailgate seal.
  11. Oct 2, 2016 at 9:45 AM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    They'll work. Mine is a 2014 also.
  12. Oct 2, 2016 at 9:48 AM
    VaGlock
    Kevin
    central virginia
    Great thanks for letting me know.
  13. Oct 2, 2016 at 9:53 AM
    onedivinetaco
    onedivinetaco Well-Known Member
    botolphston
    '05 dcsb 4x4
  14. Oct 2, 2016 at 10:01 AM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I especially appreciated the cut out templates on the last couple of pages. I have a bit of OCD when it comes to mounting things evenly so having the templates made quick work of drilling the holes. The only thing that took time was that I had to go down to Harbor Freight real quick for some 7/64" drill bits since both of my drill bit sets were missing that size.
    A word to the wise though... If anyone one installs these lights, its a good idea to stock up on zip ties before beginning the install. They really don't give you enough in the kit to secure the cables properly. I am always installing stuff in my vehicles so I already had a huge bag of them.
    scottalot and ChadsPride like this.
  15. Oct 2, 2016 at 10:38 AM
    cmartinez95
    cmartinez95 Well-Known Member
    Houston
    2014 TSS DCab 4x4
    2.0 SAWS, 2.0 Icon Rear Shocks, 1.5" Icon AAL, USOFFROAD Winch Mount, Warn M8000S, HID Retrofit Headlights, Custom made sliders, Fab Fours rear bumper, LED Fogs, Heated Mirrors, Auto Dimming rear view with temp and compass, BAMF antenna mounts, LED Interior lighting and Undercover SE Tonnea.
    For the bed lights did you tap into the wires inside the cab like the instructions say or did you tap into them outside the cab?
  16. Oct 2, 2016 at 10:54 AM
    Jamart5
    Jamart5 HoeRunner
    Juan
    SETX
    '16 4Runner TRD
    Almost done with my grill, just need to glue mesh..
  17. Oct 2, 2016 at 10:54 AM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I tapped into the black plug at the fuse box like it shows in the instructions. But I also added the tailgate pin switch which I ran to the driver kick panel. I used some diodes to isolate the dome light wire and the pin switch wire. So basically with the way I have the diodes installed:
    (1)The interior light wire CAN activate the bed lights.
    (2)The pin switch wire CAN activate the bed lights.
    (3)The pin switch wire CAN NOT activate the interior lights.
    The diodes probably were not necessary, but when I'm out doing something at the tailgate area, I don't want to run the interior lights. Just for battery conservation.
  18. Oct 2, 2016 at 12:33 PM
    SilverJack
    SilverJack no one
    Pulled the grill so I could redo the LED wires (and swapped from white to yellow). Blacked out the radiator supports (super easy and damn nice).
    Tried to derp the grill but after 7 coats the stuff still peeled off. Back to the drawing board.
  19. Oct 2, 2016 at 1:39 PM
    Nickaa42
    Nickaa42 Member
    Nick
    SoCal->Tucson,AZ
    best speaker upgrades quality and price wise? i have the upgraded stock jbl system and 2 speakers are blown out
  20. Oct 2, 2016 at 1:43 PM
    RS874903
    RS874903 Well-Known Member
    Ohio
    4x4 Tacoma 4L V6 Pyrite Mica
    Gutted the fender-well and removed swaybar.
