  1. Oct 17, 2016 at 7:24 PM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Thanks man! For a split second I thought the trim pc just snapped off, because it looked like it had clips, so I pushed one and it broke. FML. Then realized that the black "mesh" pc actually clips/unsnaps off, so took that off. Have some plastic sheets from when I put down pergo flooring a while back, so basically wrapped the door in that, made a hole with the tweeter is, then with the painters tape cut small pcs and little by little got then in the "crack" in between the ring and the door panel. Hope that made sense.
    Guess we'll see how it works out when I'm done!
    Stay tuned fellas.
    ChadsPride likes this.
  2. Oct 17, 2016 at 7:28 PM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    I wonder how it reduced drone just cutting it?
  3. Oct 17, 2016 at 7:36 PM
    nazlax10
    nazlax10 Check out my build thread for any products used!
    David
    Woodstock, GA
    '21 Toyota Rav4 LE... At least it's a Toyota
    https://www.tacomaworld.com/threads/nazlax10s-build.408318/
    Makes perfect sense to me man. I would definitely try to apply all your paint tonight and let it dry all day tomorrow. Since it's not plasti dip it should naturally separate itself once all the coats dry. To finish projects the right way I've went without door panels, grills, tailgate lol. At the base gate the gate guards know me because my truck always has something missing for a project lol
  4. Oct 17, 2016 at 8:03 PM
    Cativelense
    Nuno
    CT
    LOL. So far I only have the passenger's door panel out. Want to see how it goes before I attempt the driver's side. Only thing that "worries" me is if somehow a bit of paint gets on the door panel itself... Then I'll have to try and figure out a way to get it off.
  5. Oct 17, 2016 at 9:03 PM
    Cativelense
    Nuno
    CT
    Tweeter ring coming out crappy. Got a bit of paint on the door panel, so in an attempt to clean it off, getting paint off the ring, and it's all cracking and chipping. FML.
    Gonna have to try something different... Or just break them off and then glue them back on.
    TacoMan33 and ChadsPride like this.
  6. Oct 17, 2016 at 9:38 PM
    tacticaltaco85
    tacticaltaco85 Well-Known Member
    blake
    Dinwiddie va
    2008 TacomaTRD OR dcsb
    Have you thought about wrapping them in matte black vinyl?
  7. Oct 18, 2016 at 2:54 AM
    Cativelense
    Nuno
    CT
    Not really to be honest. I've read about peeps doing that, but never really looked into it, and figured I'd try the painting approach first.
  8. Oct 18, 2016 at 3:11 AM
    aggietaco
    aggietaco Well-Known Member
    Texas
    2021 2500hd custom
    No clue. I just happened to stumble across a thread somewhere on here where a few people chopped it and they said it helped.
  9. Oct 18, 2016 at 5:48 AM
    keith88lx
    keith88lx Well-Known Member
    Mount Prospect
    15 DCSB TRD Sport 4x4
    Ordered new tires. Did I need them? nope. But, the Falken Wildpeaks ATW3 have peaked my interest for a while and the $100 off on ebay was too good to pass up. You only live once, right?
  10. Oct 18, 2016 at 5:55 AM
    Cativelense
    Nuno
    CT
    So I ended up doing what @nazlax10 did for the tweeter rings, and basically broke them off. He told me how he did it, so I did the same thing.
    Took a razor blade to it, cut where the glue spots are, and bam, it came off. Also slapped a coat of paint to it before heading out for work this morning. Will put on another later when I get home, and hopefully tonight I'll glue it back on, maybe with some Gorilla glue, and put the door panel back on. If all goes well, and I do it quickly, will attempt at doing the driver's door as well later.
    Choco_Taco and ChadsPride like this.
  11. Oct 18, 2016 at 6:29 AM
    ChiefManyWrenches
    ChiefManyWrenches Well-Known Member
    Florida
    '11 Silver DCSB TRD Off Road 4WD
    I got my CB installed over the weekend, pretty happy with the outcome even though I couldn't mount the unit where I originally wanted. I went with the Uniden Bearcat 980SSB with their wireless mic and a 5ft firestik antenna.
  12. Oct 18, 2016 at 7:21 AM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Took her camping at the lake and caught this huge bass!IMG_3439.jpg IMG_3447.jpg
  13. Oct 18, 2016 at 7:25 AM
    la0d0g
    running for the hills
    For crawling not hauling
    FTFY :)
    trekker, scottalot and ChadsPride like this.
  14. Oct 18, 2016 at 8:13 AM
    OSUTacoma
    OSUTacoma Well-Known Member
    OHIO
    2023 Lunar Rock TRDSport DCSB
    Took down my banana tree for the winter , its a monster .PhotoEditor-1476803441999.jpgPhotoEditor-1476803594763.jpg
    That was the first trip
  15. Oct 18, 2016 at 8:24 AM
    la0d0g
    Now all I can think of is kalua pig :drool:
  16. Oct 18, 2016 at 8:36 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    dammit, me too now.............
  17. Oct 18, 2016 at 11:54 AM
    Kuntrykid
    Kuntrykid Tacoholics R Us
    Jon
    Sharpsburg, MD
    2015 tacoma 5spd access cab 4x4 red
    https://www.tacomaworld.com/threads/kuntykid-builds-a-taco.406341/
    I don't see anything.....
  18. Oct 18, 2016 at 2:42 PM
    99TacoDriver
    South Louisiana
    :redxfall:
    scottalot likes this.
  19. Oct 18, 2016 at 2:46 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Drove my Tacoma to the court house and waited in line 50 min to early vote.:oldglory:
    ChadsPride, Kuntrykid and scottalot like this.
  20. Oct 18, 2016 at 3:17 PM
    Wic07001
    Wic07001 Well-Known Member
    Matthew
    Idaho
    2014 White TRD Sport
    5100's front, Icon 2.0RR rear, Icon AAL, OME 885, Camburg UCA, retrofit headlights,
    Finally got my truck where. Want it to be until I get new bumpers. Let's just say I can't go down the road without being noticed now. And now driveline vibrations!
    5100's front with 885 spring set at 2.5
    Icon 2.0rr rear with icon aal
    SCS wheels with toyo at2's 265/70/17
    Caliraised stealth bumper light bar and ditch lights.
