  1. Oct 28, 2016 at 2:14 PM
    DonXavi01
    DonXavi01 Well-Known Member
    Xavier
    2014 BLK Tacoma TRD Offroad DCSB
    A.R.E. Camper Shell w/Thule rails, PrinSu Design Roof Rack w/40" led light bar, Pelfreybilt IFS skid, PBO Mid skid plate, Precision LED interior & license plate, in-rail bed mounted 60" Hi-lift jack, TRD Pro front grill, redline tuning hood struts, 6K Cree LED headlight kit 7600LMS, T1 eyelids, BLK towing flip-up mirrors, red smoked LED taillights, taillights brush guards, TRD catback exhaust w/chrome tip, Volant cold air intake w/Power core tech filter, HD UCA's w/uniball stainless steel ball joints, Allpro Exp leaf springs w/U bolt flip with thimber stops.
    Full bed. What's all u got back there?
    ChadsPride likes this.
  2. Oct 28, 2016 at 2:18 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Looks like 4 tires and 4 rims in boxes to me!
    ManBeast and ChadsPride like this.
  3. Oct 28, 2016 at 2:21 PM
    DonXavi01
    Xavier
    They looked the same to me, just making conversation mr. :wave:
  4. Oct 28, 2016 at 2:39 PM
    philwill
    philwill Well-Known Member
    Phillip
    Atlanta, GA
    '07 TRD Offroad
    '12-'15 front end swap, 255/80/17s on stock suspension
    Installed my CB and 3' Firestik using a BAMF mount and a heavy duty spring so it doesn't smack against the camper.
    The console lid closes fine with the mic connected but I'm going to install an extension so the mic can connect near the cup holders and I don't have to open the console to talk.
  5. Oct 28, 2016 at 3:12 PM
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    I did not tape off that section when I did my BHLM and those lights were very dim. I solved it by putting some much brighter LED bulbs in
    ChadsPride[QUOTED] likes this.
  6. Oct 28, 2016 at 3:17 PM
    Berniebikes
    Berniebikes Well-Known Member
    Bernie
    Williamsburg, VA
    2015 White TRD OR Double Cab
    Dude, it used to be 10th Engineer Batallion, part of the 8th Infantry Division there along with a nuke capable Nike Hercules missile battery. I was there in 1977 and 78 and then to Bad Kreuznach (8th ID HQ) as the Assistant Division Engineer. Brings back some old memories. I also was in Wiesbaden with the 222 Infantry Batallion before I transferred to engineers. Wore my Engineer brass while commander of an Infantry Company just to piss off the Infantry guys....great times over there.
  7. Oct 28, 2016 at 3:22 PM
    Berniebikes
    Bernie
    Williamsburg, VA
    I was part of the first Army units to move to Wiesbaden in 1976. prior to our arrival it was the USAREUR AF HQ. Germans got used to the Air Force guys, had a fit when the Army arrived. There were posters all over town showing kids being run over by tanks, locals were not too happy. Took a few years by things calmed down. I could tell quite a few stories about the annex bar in the Wiesbaden Arms (transient billet facility and Bachelors Officers Quarters). There was still quite a large us civilian population there cause the hospital (air force) and a lot of the logistical stuff remained even though the AF moved to Kaiserslautern. Wish I had back every deutsch mark that I spent drinking beer there......
  8. Oct 28, 2016 at 3:42 PM
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Pittsburgh, PA
    2013 Black Baja Access Cab
    I had my exhaust cross-over relocated, went up a tire size to 265/75/16's, and had a Wheeler's 1.5" life add-a-leaf set installed. I'll provide more details and pics later, but I'm having a problem with the springs and need some advice. The Wheeler set advertises a 1-1.5" increase in height. I have a Baja with the factory 1.75" lift in front, and in stock form the truck sat dead level. To get rid of rear end squat when carrying anything, I added these springs. This should have resulted in a rake that was very close to a factory OR truck, just about an inch-and-a-half higher all around. However, the rear is now 2.5 inches higher! Do these things settle, and is a 1 inch settling realistic? I'm worried about my rear brake lines and shocks - which can take an extra 1.5 inches, but not 2 or more. The rake is also pretty extreme and I have no idea how the thing is going to handle at speed now. Help!!!
  9. Oct 28, 2016 at 3:44 PM
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    add-a-leaf will settle a bit. Maybe not a whole inch though?
  10. Oct 28, 2016 at 3:58 PM
    r2oh
    r2oh Well-Known Member
    Denver Colorado
    2010 white tacoma trd sport
    Fox 2.5 factory series dsc coil over Fox 2.0 dsc Total chaos uca Total chaos lower control arms Ome dakar Toytec extended break lines Scs stealth 6 gunmetal grey wheels bfgoodrich a/t ko2 tires 285/70/17 Quick stop drilled & slotted rotors Trd cold air intake (1st gen) Trd exhaust Optima yellow top battery Rigid 40" led bar and 4 pods & 20" Retrofit masters custom headlights Rci front,transmission,transfer case skid plates Pilfreybuilt front bumper single hoop Smittybuilt 9000xrc comp winch Factor 55 fairlead InSain fabrication cmc and sliders Total chaos weld on cam tab guests U bolt flip kit Prinsu roof rack Cvj axels Jersey hubs wheel bearings Ecg needle bearing Cvj rack and pinon
    285 70 17 bfgoodrich ko2 on stealth 6 gunmetal grey wheels
  11. Oct 28, 2016 at 5:48 PM
    Kuntrykid
    Kuntrykid Tacoholics R Us
    Jon
    Sharpsburg, MD
    2015 tacoma 5spd access cab 4x4 red
    https://www.tacomaworld.com/threads/kuntykid-builds-a-taco.406341/
    Can't wait to see!
  12. Oct 28, 2016 at 5:49 PM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    :eek: :thumbsup: :drool: :jellydance:
  13. Oct 28, 2016 at 5:51 PM
    r2oh
    Denver Colorado
    I'm at work right now but I'll post as soon as i get home
  14. Oct 28, 2016 at 5:53 PM
    Kuntrykid
    Jon
    Sharpsburg, MD
    Didn't realize you already had them on being they were in bed of your truck
  15. Oct 28, 2016 at 6:05 PM
    r2oh
    Denver Colorado
    Well technically they're not on the truck yet I'll be doing the cmc this weekend and if i get some time next week I'll have the cam tab guests welded so i can throw the new pilfrey bumper and rci skid plates on at the same time
  16. Oct 28, 2016 at 6:07 PM
    Kuntrykid
    Jon
    Sharpsburg, MD
    Kool.........
  17. Oct 28, 2016 at 6:27 PM
    trekker
    trekker I like tacos
    Brandon
    Pocatello, ID
    '14 DCSB TRD OR MGM
    floor mats and a beer switch
    I did this...
    I had help with the photo, no reckless driving here.
  18. Oct 28, 2016 at 9:30 PM
    r2oh
    Denver Colorado
    Not on but here is one of them next to the bumper
  19. Oct 28, 2016 at 9:37 PM
    Silverspool
    Silverspool Come at me Bro!
    Frank
    DFW
    18T4RORP 17GT350
    Anyone seen my wallet?
    White side out crew... true bro now
    DirtyB, Nimble9, Cmurder and 3 others like this.
  20. Oct 28, 2016 at 10:38 PM
    DC-USAF
    DC-USAF Well-Known Member
    Dale
    WNC
    2015 SR5 Access Cab 4x4 V6
    TRD PRO Grill, mobtown offroad recovery bar, SCS Ray 10's
    Make sure you post some pictures on how you mount it and please tell us what mounting brackets your going to use. I may have to put this on my list of mods to do.
