  1. Dec 30, 2016 at 5:58 PM
    SGT
    SGT Member
    2010 TRD Sport 4x4 DC
    1Shifter[QUOTED] and ChadsPride like this.
  2. Dec 30, 2016 at 6:11 PM
    Camo23
    Camo23 Well-Known Member
    Drew
    Fallbrook, CA
    08 DC 4x4
    Not much yet
    Installed my Bestop that I picked up off of another TW member, then the wife and I went to the Muir Woods National Park.
  3. Dec 30, 2016 at 8:04 PM
    Toyotrd07
    Toyotrd07 Member
    Kenrick
    North Carolina
    07 black tacoma TRD
    Thanks a lot man just got it done
    ChadsPride and 1Shifter like this.
  4. Dec 30, 2016 at 10:01 PM
    MattB77
    MattB77 Well-Known Member
    OR
    2013 AC TRD Sport
    New license plate bulbs
  5. Dec 30, 2016 at 10:16 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    It will be interesting to see if you have any trouble with flickering. I bought some cheap leds from a member on here and they went in the garbage because they flickered like they belonged at a disco or rave...
    ChadsPride, AZ2013 and Silverspool like this.
  6. Dec 30, 2016 at 10:28 PM
    Theloraxcross
    Theloraxcross "He's Got the Crazy Eye"
    Joseph
    San Angelo Tx
    08 AC TRD OR
    Is that grill insert the one that's avail on Amazon?
    ChadsPride likes this.
  7. Dec 30, 2016 at 11:05 PM
    MattB77
    OR
    2013 AC TRD Sport
    Lol they better not for what they cost. These where 27 bucks thru the retrofit source. I've had issues as well with eBay leds
  8. Dec 30, 2016 at 11:20 PM
    06taco4.0
    06taco4.0 Mullet Magic
    Jacob
    Washington
    2006 Tacoma v6 4.0l 4WD
    2006 Tacoma V6 4.0L 4WD Dual K&N CAI Cherry Bomb glass pack +3 inch OME coils 3/4 inch toytec spacers Deaver 1.5 inch AAL iDelta toolbox Cree LED 7.5 inch lightbars on a bullbar 33in SVT Radial Wild Country
    Colormatched the gauge rings and re charged my k&n filter
    ChadsPride and Kuntrykid like this.
  9. Dec 31, 2016 at 12:09 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    I've been busy tonight. Look at the size of these spring perches compared to stock:eek:
    I'm swapping an e locker axle into my truck while I build my lsd with arb and 4.88s
    Got perches and mounts welded on, gonna do drum brakes in the morning and see if I can't swap it out really quick.:D
    PaulK, ChadsPride, Kuntrykid and 2 others like this.
  10. Dec 31, 2016 at 2:49 AM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
  11. Dec 31, 2016 at 4:42 AM
    Ted Yoder
    Ted Yoder Well that didn't work
    06 DCLB
    In Progress
    No problem.
    Toyotrd07[QUOTED] and ChadsPride like this.
  12. Dec 31, 2016 at 7:04 AM
    binderline
    binderline Well-Known Member
    2019 TRD OR MT Cement
    Had a similar inclination. I love my Bestop. Had to add a pair of nerf bars to "complete" the look. Not bad. 20161230_143216.jpg
  13. Dec 31, 2016 at 8:30 AM
    sy272004
    sy272004 Well-Known Member
    West Chester
    15 TRD V6 4x4 DC
    3" lift. 33" tires. Headlight Retro, intake, exhaust
    ordered 5100 and uca with 887 spring, need to find aal
    Silverspool, ChadsPride and Kuntrykid like this.
  14. Dec 31, 2016 at 9:26 AM
    SKULLY
    SKULLY Well-Known Member
    Dave
    San Diego
    06 DCSB
    Nice! How close are those new beefy spindle gussets to the tire/wheel? Spindles turned out killer but man that looks tight!
  15. Dec 31, 2016 at 9:27 AM
    08TRDOFFROAD
    Dan
    Well, after nearly ten years in service and almost 100k miles, my TPMS system had a malfunction due to a failed sensor (I suspect). The light would flash for 60 seconds and then stay on solid after every start up. It was more than my OCD could handle! I hate idiot lights being illuminated on the dash. So I did the least permanent version of the TPMS delete. I pulled my dash apart and taped on the back side of the cluster display to block the light with a small piece of electrical tape.
    In progress...
    Success!!!
    While I had everything in the dash apart, I killed two birds with one stone and plugged in the data cable to my Hypertech Speedo calibrator and ran it to the kick panel to avoid having to pull the dash apart again should I change tire size in the future.
    I also reconnected my trailer brake controller pigtail I removed after I hit a deer this summer and worried the truck might be totaled and completely cleaned it out before the tow truck picked it up.
    Pretty productive morning for it being 15 degrees outside!
  16. Dec 31, 2016 at 12:00 PM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Ky
  17. Dec 31, 2016 at 12:05 PM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    That's funny dar aye
    Thyces[QUOTED], ChadsPride and mrlee like this.
  18. Dec 31, 2016 at 1:20 PM
    Awsome57
    Awsome57 Well-Known Member
    Kevin
    The tire pressure light was on today and I was going down the highway and heard a crunch noise. I know I didn't hit nothing but when I looked at my cluster that tire pressure light was out??? Anyone expirence this.
  19. Dec 31, 2016 at 1:40 PM
    Ted Yoder
    06 DCLB
    In Progress
    Me thinks coincidence
    :boink:
  20. Dec 31, 2016 at 1:56 PM
    Kuntrykid
    Kuntrykid Tacoholics R Us
    Jon
    Sharpsburg, MD
    2015 tacoma 5spd access cab 4x4 red
    https://www.tacomaworld.com/threads/kuntykid-builds-a-taco.406341/
    Drugs are bad for you!
