  1. Jan 3, 2017 at 10:23 PM
    Mr.PowerTrays
    Mr.PowerTrays Well-Known Member Vendor
    Maverick
    Colorado
    2011 dcsb trd or
    yeah the website is ************** the main focus of their products are dual battery systems for toyotas, but They offer a lot more as well. like i said before if you're interested in the power panel you can either email Matt through the website or shoot @HeliMedic a PM, because i don't believe their going to put them up on the site due to there being so many different combinations you can run.
    ChadsPride likes this.
  2. Jan 3, 2017 at 10:26 PM
    austinrauh
    austinrauh Well-Known Member
    Nevada
    05 AC OR
    Good info, I didn't know he technical side but I was trying to think of an idea to seal it up...
    ChadsPride and Kuntrykid like this.
  3. Jan 4, 2017 at 1:00 AM
    2DaMtns
    2DaMtns Well-Known Member
    2011 TRD Sport DCLB in MGM
    Lift, tires, stuff
    I had a set on an old f150. They were fabulous in snow. I lived down a hilly, twisty one lane road and I got in and out in over a foot of snow without ever even having to hit any of it twice. They a great tires.
  4. Jan 4, 2017 at 2:42 AM
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    15 TRD Sport (DCLB-BRM) - 88 ///M3 (Zinnoberrot)
    OME 887/Dakars/NV305s/33" Duratracs/+
    Link to the wiring please
  5. Jan 4, 2017 at 2:53 AM
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    Via @Norton
    I referenced several threads and did a lot of multi-meter testing to complete the project, but I'm far from the first/only one to do it.
    The parts required are:
    1 x PT297-35070-AS AUXILIARY SWITCH FJ
    1 x 9098010933 HOUSING, CONNECTOR, FEMALE
    2 x 8299812340 TERMINAL, REPAIR W/ WIRE
    1 x Add-a-Circuit Fuse Tap (to grab a Switched 12V source)
    Resources you might find useful include:
    https://www.tacomaworld.com/threads...-gen-tacoma-today.6499/page-3030#post-9937618
    https://www.tacomaworld.com/threads...de-not-led-or-hid.435419/page-6#post-13680690 (Posts #108-119)
    Note that, in the end, I found THIS to be the best way to wire the new switch.
    As shown, I tapped pin 6 to pin 3, and pin 5 which requires a +12V source, to the ACC fuse panel on the driver side using the add-a-circuit fuse tap.
  6. Jan 4, 2017 at 2:59 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Removed low budget Cobra ULTRA III CB....Installed Cobra 25 XLT Classic CB! Moved antenna rearward away from cab. Tuned SWR @ new antenna location. Previous best range of reception/transmission was around 3 miles. Was talking with a truck driver last night that was 23 miles away.
    Win!
    JaxJim, frejil, canopycarl and 2 others like this.
  7. Jan 4, 2017 at 3:08 AM
    ChadsPride
    Sponsored by TacomaWorld.com
  8. Jan 4, 2017 at 3:42 AM
    Dimestore55
    Dimestore55 Well-Known Member
    William
    Richmond, VA
    2007 TRD OR Prerunner DCSB
    $1097 for the headstrong order - free shipping / no tax.
    The brakes were on sale for $150 + $31 shipping from Autoanything.com. If you're a prime member get the same thing from Amazon.
  9. Jan 4, 2017 at 5:44 AM
    Kuntrykid
    Kuntrykid Tacoholics R Us
    Jon
    Sharpsburg, MD
    2015 tacoma 5spd access cab 4x4 red
    https://www.tacomaworld.com/threads/kuntykid-builds-a-taco.406341/
    Why does your switch have a pic of a jeep on it?
  10. Jan 4, 2017 at 5:48 AM
    newmarkettaco
    newmarkettaco Well-Known Member
    2009 tacoma 4x4 v6
    @Kuntrykid I couldn't find one with a tacoma/truck on it on the site. i just bought it sincr it said off road lights . and didn't want it say sasquash lights or something dumb like that. I thought the same then said f it who cares lol. If income across a better one I'll swap it eventually
    Kuntrykid and ChadsPride like this.
  11. Jan 4, 2017 at 7:02 AM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    Caja Del Rio plateau west of Santa Fe. Off FR24 in an undisclosed location :spy:
  12. Jan 4, 2017 at 9:00 AM
    Rambo54
    Rambo54 TacomaBob
    Robert
    Eustis,FL
    2013 Nautical Blue Metalic Tacoma PreRunner DCLB
    Many !
    I performed my 5,000 mile change today,Drain and Refill with 5.5 Qts AMSOIL Signature Series Synthetic Motor Oil 5W-30 and a Toyota OEM TRD Oil Filter. Replace Drain Plug Gasket with Toyota OEM Part . Runs as usaul as Good as new the day I bought her on Show Room Floor on Oct.20th 2012.SAM_0470.jpg
  13. Jan 4, 2017 at 9:02 AM
    StubaccaTaco
    StubaccaTaco Active Member
    Stubacca
    Pacifica, CA
    2009 Matte Black DCOR TRD
    Customized
    Installed SCS SR8's 16x8 on 285/75R16 BFG KO2's
    Installed Cab Mount Chop brackets
    Trimmed fender plastics
    I've now installed TC UCA's as I was still getting some rubbing on the front (cab-side) fenders, and will be doing the pinch weld mod shortly.
  14. Jan 4, 2017 at 9:47 AM
    smcgill
    smcgill Well-Known Member
    Sean
    South Easton Mass. not enough time in Cocagne NB
    Camry and Ram 1500 with a "HEMI "
    You should add this in pink!
    Welcome to the Madness!
    Rambo54 and ChadsPride like this.
  15. Jan 4, 2017 at 9:55 AM
    Kuntrykid
    Jon
    Sharpsburg, MD
    @ChadsPride
  16. Jan 4, 2017 at 9:56 AM
    ChadsPride
    Kuntrykid[QUOTED] likes this.
  17. Jan 4, 2017 at 10:26 AM
    Denk
    Denk Well-Known Member
    PNW
    '13 Spruce TRD Sport DCSB
    Was doing some cleaning under the good then noticed that the headlights are brighter across the top than the bottom. Is this normal? The lense is clean. This looks the same in the daytime, from close up or further away. Could be my failing memory but i always thought the brightness was even throughout.
  18. Jan 4, 2017 at 10:28 AM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    Should be pretty even if you halogens in there.
  19. Jan 4, 2017 at 10:48 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    City horns installed. Hopefully my new air tank and compressor will be here tomorrow to hook up the air horns again.
  20. Jan 4, 2017 at 10:52 AM
    Zanone_taco
    Zanone_taco Tacoma bruhhh
    Blane
    Humboldt county
    2010 white access cab Trd off-road
    Need more...
    Well first "mod" or add on to the truck:cool: rims leveling kit and muds to come one within the next month or so
