  1. Jan 12, 2017 at 12:44 PM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    ^^^ This is why I would never buy a white truck.
    That plus it would make me look like an exterminator/contractor
  2. Jan 12, 2017 at 12:47 PM
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Pittsburgh, PA
    2013 Black Baja Access Cab
    ChadsPride likes this.
  3. Jan 12, 2017 at 12:52 PM
    BigMacMcCoy
    BigMacMcCoy Cajun In Vienna
    Braedon
    Vienna, VA
    Silver 2010 Tacoma Access Cab
    All the dumb choices in one vehicle
    It probably helped that the Hilux is everywhere overseas. In most countries you can't take two steps without seeing one.
    ChadsPride and PaulK[QUOTED] like this.
  4. Jan 12, 2017 at 1:11 PM
    Ret CB
    Ret CB Builder Bee
    Anthony
    SC
    2015 AC Pyrite Mica
    De-badged , Grillcraft grill , SCS Stealth 6 , BFG AT KO2
    Christmas present number two arrived today !
  5. Jan 12, 2017 at 1:25 PM
    Npizano
    Npizano Well-Known Member
    Nick
    salt lake city
    2012 TRD Off Road Double Cab
    KATZKIN LEATHER SEATS. 6 INCH FABTECH LIFT, BFG KO2S
    Alright, finally got my TRD Shift nob in. Feels nice and heavy. I had my Mopar shift knob that just felt cheap, this feels much better. It is smaller than the stock shift knob, but I am sure I will get used to it. Love the way it makes the interior look IMO.
  6. Jan 12, 2017 at 1:29 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Changed my bulbs in my headlights from LED back to stock halogens yesterday. Pleased with the difference.
    Does anyone know if they make a trd style shift knob for the five speeds that is similar to the style of the 6spd knob? heres a pic of the 6spd one.. im looking for something similar to this but for my 4 banger
  7. Jan 12, 2017 at 1:34 PM
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    Base v6 models have same rear end as the sport. I don't know about the 4 bangers.
    The third member is that whole pumpkin part with the gears in it. You need to tap it for the air line, but ECGS can do that for you too!
    ChadsPride and Kuntrykid[QUOTED] like this.
  8. Jan 12, 2017 at 2:11 PM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    Do any 2nd gem Tacos come with a completely open diff? My 2012 prerunner Sr5 even has a auto LSD. I tried to get stuck in the deep snow the other day, just to find its limits. I was unsuccessful.
    ChadsPride and Kuntrykid like this.
  9. Jan 12, 2017 at 2:15 PM
    BassAckwards
    05-08 non trd sports/offroads should come with a completely open diff
  10. Jan 12, 2017 at 3:03 PM
    tacabode
    tacabode Well-Known Member
    Ohio
    '14 MGM DCSB TRD OR
    Uh... o_O
  11. Jan 12, 2017 at 3:11 PM
    AugustaTaco
    AugustaTaco Well-Known Member
    Josh
    Augusta, GA
    2015 DCSBXSPX4X4 2017 GX460
    "Getting out of hand" - Wife
    Added and moved some switches
  12. Jan 12, 2017 at 3:11 PM
    tacabode
    Ohio
    '14 MGM DCSB TRD OR
    I think you have this backwards. The newer years are an open diff and electronically controlled (brakes) limited slip and the earlier years are mechanical. Maybe it's a year range... can't quite remember
  13. Jan 12, 2017 at 3:35 PM
    PaulK
    Paul
    Pittsburgh, PA
    So can a mechanical limited slip 3rd member from an "older" 2nd gen TRD off-road with an e-locker be installed in a later open "auto LSD" rear end in a newer 2nd gen TRD off-road with an e-locker, giving the new truck real mechanical limited slip? If it fits, would it cause problems with any of the brake controlled traction and stability aids? Are the e-lockers the same?
  14. Jan 12, 2017 at 3:46 PM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    Thats a whole nother situation.
  15. Jan 12, 2017 at 3:46 PM
    ChandlerDOOM
    ChandlerDOOM International tent trafficker
    Chandler
    STL
    Truck
    37s yo
    Using both a mechanical lsd probably isn't bad but maybe counter productive, when the mechanical kicks in the brakes might kick in at the same time causing the mechanical to disengage. Air locker and be done is my only advice
  16. Jan 12, 2017 at 3:52 PM
    99kx250
    99kx250 Taco Bell king
    Joshua
    Arizona
    22 TRDOR
    Deaver+Icon AAL OME 885 springs Bilstein 5100s
    Washed my 2 favorite machines :bikewhoops:IMG_2759.jpg
  17. Jan 12, 2017 at 3:58 PM
    PaulK
    Paul
    Pittsburgh, PA
    What if the brake controlled auto-LSD was never activated? Easy enough to disconnect the switch. An air locker would be little change from the current e-locker setup unless the ARB carrier is a limited slip unit - acknowledging that the air locker is by definition an anytime system while the e-locker is factory limited to 4-lo. If the ARB 3rd member specified for later 2nd gens IS limited slip, wouldn't that prove that brake controlled traction and stability system interference is not an issue? I'm interested in real limited slip performance before I have to lock up. The brake controlled auto LSD has not impressed me in snow and ice conditions. It would probably be fine in low speed off road applications, but sometimes you need to spin both rear tires when you're not in 4-lo.
  18. Jan 12, 2017 at 4:13 PM
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    anytime locker mod, or air locker. If you have a locker then why want an LSD?
  19. Jan 12, 2017 at 4:14 PM
    Kuntrykid
    Kuntrykid Tacoholics R Us
    Jon
    Sharpsburg, MD
    2015 tacoma 5spd access cab 4x4 red
    https://www.tacomaworld.com/threads/kuntykid-builds-a-taco.406341/
    This is something I was thinking bout doing to my taco as well someday... Or something similar...
    PaulK[QUOTED] and ChadsPride like this.
  20. Jan 12, 2017 at 4:15 PM
    freddy2923
    freddy2923 Well-Known Member
    Freddy
    Phoenix, Arizona
    2015 Barcelona red Tacoma trd or
    Pretty much stock, just a light bar and a avid off road bumper guard
    So after 2 years and roughly six trips to glamis sand dunes my stock shocks were pretty much done haha installed my 5100's yesterday set at .85 stock spring and got me some wheelers super bump stops, can't wait to try them out at glamis. Might do the gm bumpstops for the rear IMG_0367.jpgIMG_0362.jpg IMG_0336.jpgIMG_0331.jpgIMG_0366.jpg IMG_0361.jpg
