  1. Jan 17, 2017 at 11:11 AM
    nazlax10
    nazlax10 Check out my build thread for any products used!
    David
    Woodstock, GA
    '21 Toyota Rav4 LE... At least it's a Toyota
    https://www.tacomaworld.com/threads/nazlax10s-build.408318/
    It should work no problem, and anytime man!
  2. Jan 17, 2017 at 11:34 AM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Later baby.... Later.
  3. Jan 17, 2017 at 11:47 AM
    Thenews24
    Thenews24 Active Member
    2012 2.7L 4x4
    OME 884, dakarr
    Blacked out emblems with plastdip
    20170117_134122.jpg 20170117_134107.jpg 20170117_134200.jpg 20170117_134514.jpg
  4. Jan 17, 2017 at 12:20 PM
    Buffdeez
    Buffdeez Well-Known Member
    Hamilton, Ontario, Canada
    2008 DCLB SPORT
    hinges rusted up. would stay closed. ripped it off, taped off tank and plasti dipped it.
  5. Jan 17, 2017 at 12:50 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Zero fucks given!
  6. Jan 17, 2017 at 12:56 PM
    will.carroll7
    will.carroll7 Well-Known Member
    2023 DCSB TRD OR 4x4 LR
    I have that pump. Be careful the tubes like to fly out of the fittings if you build up too much pressure and it sprays oil on your entire life and everything you own I'm not angry.
  7. Jan 17, 2017 at 1:02 PM
    la0d0g
    Synthetic for the diffs? o_O
    ChadsPride likes this.
  8. Jan 17, 2017 at 1:09 PM
    scottyryan13
    scottyryan13 Member
    Scotty
    2013 Toyota Tacoma Limited
    What's up guys. Just recently got a new tire and rim setup on my 2013 Tacoma. Thought I'd share:
    No lift - falken wildpeak 265/65/18 on pro comp 7032 18x9 rims. Just put on an all black grill to get rid of the limited chrome grill.
    Rick_Taco, mrlee, DonXavi01 and 7 others like this.
  9. Jan 17, 2017 at 1:18 PM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    Looking good! The AT3Ws are a good budget friendly AT tire. I haven't had any problems after 10k and they are wearing nicely.
    Kuntrykid and ChadsPride like this.
  10. Jan 17, 2017 at 1:24 PM
    scottyryan13
    scottyryan13 Member
    Scotty
    @Chase8059 ya, I've had mine for about 5k miles. No complaints yet, we're going through the snowiest winter since the last 5 years here in northern Utah and these tires are awesome in the snow. Very affordable, and aggressive looking!
  11. Jan 17, 2017 at 1:32 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    Is there a write up on these black Hondo knobs? Or is it just straight forward.
    Mine didn't come with instructions
  12. Jan 17, 2017 at 1:34 PM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Straight forward.
    Grab the stock ones, pull them out. Put the new ones on and then tighten them with the super duper tiny wrench it came with.
    ChadsPride[QUOTED] likes this.
  13. Jan 17, 2017 at 1:35 PM
    ChadsPride
    Thanks dude! :thumbsup:
    Mine say entune plus on them...hope they work lol
    Cativelense[QUOTED] likes this.
  14. Jan 17, 2017 at 1:36 PM
    Cativelense
    Nuno
    CT
    Can't remember if mine did or not to be honest.
  15. Jan 17, 2017 at 1:37 PM
    CaptainReverso
    CaptainReverso Well-Known Member
    Cory
    Gardena
    2015 TRD off road 4x4 DBL cab Magnetic Grey
    Off Road Stuff
    Something's in the works more on Instagram @ CaptainReverso IMG_20170115_154453_781.jpg
    gkomo, DonXavi01, Tacoturtle and 2 others like this.
  16. Jan 17, 2017 at 1:38 PM
    ChadsPride
    This wasn't today!!!!
    :D:D:D
    :fistbump:
  17. Jan 17, 2017 at 1:40 PM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    Boom, headshot.
    Pat_Sajak and ChadsPride like this.
  18. Jan 17, 2017 at 1:47 PM
    Blunn
    Blunn Member
    Alec
    Alberta
    SR5
    I put on a new bumper :thumbsup:
  19. Jan 17, 2017 at 1:47 PM
    CNORRIS13
    CNORRIS13 Well-Known Member
    Corey
    Oak Harbor, WA
    2015 Super White Tacoma base 4x4
    Doug Thorley header, Magnaflow exhaust, K&N air filter, and more to come.
    Just got my half birthday present today. I'm going to make my neighbors mad this weekend.
    bogginator, Kuntrykid and ChadsPride like this.
  20. Jan 17, 2017 at 1:57 PM
    ChadsPride
    Got my Hondo black machined radio knobs on.
    In the top 3 for quick, easy, and awesome mods in my book!!!
    mrlee, DonXavi01, Tacoturtle and 14 others like this.
