  1. Jan 23, 2017 at 9:38 PM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    Or not. It's not enough lean for me to worry about it on my truck.
    ChadsPride and Kuntrykid like this.
  2. Jan 23, 2017 at 9:41 PM
    Crodliner
    Crodliner Well-Known Member
    DFW
    Finally got around to this. Front is a bit high, but still need to mount winch & eventually skids. Also will need to fill that huge gap in the wheel well :eek: which means bigger tires of course :cool:
    @HeadStrong Off-Road @EddyRRT
    Before:
    After:
  3. Jan 23, 2017 at 10:03 PM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    Every time I back up to a block wall or garage door I check the tailgate & have never noticed a lean. Both on stock suspension & my current AllPro leaf/Icon shock travel setup. There are tolerances at the factory, some trucks are textbook while others push the limit. Don't feel left out if you don't need the spacer :thumbsup:
    ChadsPride likes this.
  4. Jan 23, 2017 at 10:34 PM
    docloco
    docloco Well-Known Member
    Ron
    Florida
    2015 MGM DCSB 4x4 TRD OR
    ChadsPride and G.T. like this.
  5. Jan 23, 2017 at 11:06 PM
    MRJ
    MRJ Well-Known Member
    Bucky
    Kent, WA
    '12 pyrite mica 4x4
    Snugtop SuperSport
    Warranty delete mod (surpassed 60k). With two payments left, the pay-it-off mod is next.
  6. Jan 24, 2017 at 2:53 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    I've watched him do it, and helped.... most recently was when we put on my light bar. Seems easy, but I think I'd rather leave it to the professional. :D
  7. Jan 24, 2017 at 5:59 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Tried to fit it in the garage...will have to rearrange a few things. It almost fits...
  8. Jan 24, 2017 at 6:36 AM
    Cativelense
    Nuno
    CT
    Just bought one of these, and now waiting for it to come in the mail:
    https://www.diodedynamics.com/store...arttap-cf18-lm449-flasher-relay/#!prettyPhoto
    In case you don't want to read it, it's a flasher relay for your blinkers. Long story short, you know how some new cars if you just flick the blinker bar real quick, it'll blink 3-4 times and shut off without you actually having to flip the lever?! Well, this thing will make it do that!
    It replaces your OEM one.
    Can't wait!
    Hawco636, Nedrolls, Cr47524 and 11 others like this.
  9. Jan 24, 2017 at 6:50 AM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Big 4 upgrade and proper power to my jl 10w7.... Coming soon.. Screenshot_2017-01-24-09-45-48.jpg
  10. Jan 24, 2017 at 6:55 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Just put LEDs in my high mount brake light. A bit brighter, and it's a good thing I changed the bulbs when I did, since all 3 of the regular bulbs were "smoked" looking, or slightly burnt looking, so they might not have had much life left. Going to get my new driving light and light bar switches installed tomorrow, along with all the dash switch bulbs. I just can't get under there myself to do it, and I'm a mechanical klutz anyway. Will post pics when installed...
    DC-USAF, Kuntrykid and ChadsPride like this.
  11. Jan 24, 2017 at 6:57 AM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    Nedrolls, Msmith80, smcgill and 2 others like this.
  12. Jan 24, 2017 at 7:43 AM
    nazlax10
    nazlax10 Check out my build thread for any products used!
    David
    Woodstock, GA
    '21 Toyota Rav4 LE... At least it's a Toyota
    https://www.tacomaworld.com/threads/nazlax10s-build.408318/
    Ordering that now! I miss that feature from my 14 corolla I had before my Tacoma. Let me know how it works once you get it!
  13. Jan 24, 2017 at 7:45 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Dang it!!! Now I HAAAAAAAAVE to have that lmao
  14. Jan 24, 2017 at 7:45 AM
    Cativelense
    Nuno
    CT
    Nice!!!!!!!!! And will do sir!
    From what I've read, it plugs in behind the fuse panel, so seems like we'll have to get to that and take it off.
  15. Jan 24, 2017 at 7:46 AM
    Cativelense
    Nuno
    CT
    DDDOOO EEETTT!!!!!!!!!!!
    Kuntrykid and ChadsPride[QUOTED] like this.
  16. Jan 24, 2017 at 7:46 AM
    ChadsPride
    I cant right now lol.
  17. Jan 24, 2017 at 7:46 AM
    Cativelense
    Nuno
    CT
    :mad:
  18. Jan 24, 2017 at 7:49 AM
    ChadsPride
    :annoyed:
  19. Jan 24, 2017 at 7:54 AM
    nazlax10
    David
    Woodstock, GA
    Dang it, I just had my fuse panel off about two weeks ago haha.
  20. Jan 24, 2017 at 7:55 AM
    Cativelense
    Nuno
    CT
    LOL
    Guess you'll have to do it again! :D
