  1. Feb 1, 2017 at 10:06 AM
    Greg617
    Greg617 Well-Known Member
    Greg
    New England
    2010 5-speed 4x4
    Dents and scratches... Fox 2.5 Factory
    Thanks, good eye. I'm planning on getting my annual pass on the first day possible this year, April 10th.
    ChadsPride likes this.
  2. Feb 1, 2017 at 10:08 AM
    Greg617
    Greg
    New England
    2010 5-speed 4x4
    I've done all of my doors so far (including the small access cab ones) and plan on doing the back wall this spring/summer when i can work in the driveway again.
  3. Feb 1, 2017 at 10:26 AM
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Pittsburgh, PA
    2013 Black Baja Access Cab
    Assuming that you didn't change anything else, I would like to hear your assessment of the new speakers vs. the factory units. I have an access cab with the base radio. I'm not interested in swapping the head unit or adding any other system components, but if better (not great, but better) sound can be had by simply swapping the speakers I would probably do it. Also, are you swamping the high-mounted door tweeters too?
  4. Feb 1, 2017 at 10:39 AM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    I am lucky that my parents have a house in town so I get out to the backside and hatches harbor quite a bit.
  5. Feb 1, 2017 at 10:40 AM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    Yea I used a hair dryer and fishing string and then removed the excess goo with an adhesive remover that my brother uses where he works. I don't think it was anything I could have done that chipped the paint. I think the badges may have been applied too early before the paint cured properly.
    My truck came from an assembly line in new Mexico and apparently that's out of the ordinary for the toyotas around here. Maybe bad QC
  6. Feb 1, 2017 at 10:41 AM
    99TacoDriver
    South Louisiana
    Cmon Chad you didn't even read it before you liked it!
    orezona and ChadsPride like this.
  7. Feb 1, 2017 at 10:42 AM
    ChadsPride
    Sponsored by TacomaWorld.com
  8. Feb 1, 2017 at 10:49 AM
    orezona
    orezona title unspecified
    satan's skillet
    2006 TRD OR DCSB OMGWTFBBQ TL;DR
    WARRANTY VOIDED
    You didn't ask me but this is the internet so here comes an opinion...
    Biggest difference in sound will happen not from speakers changed, but getting rid of the stock head unit. I thought I read somewhere that the OEM (non JBL) h/u is rated at 17 watts.
    The C-note ghetto fab BOSS audio 6" touch screen h/u I got off Amazon is rated at 80 watts. Even with the stock speakers in the difference was quite noticeable.
    I'm not an audiophile nor very technical when it comes to wave forms and RMS and fancy-schmancy terminology but my crappy 38 year old ears for sure could tell the difference.
    For what it's worth, I have NOT replaced the OEM tweeters yet but the other four in my doublecab are non-stock as of this last Sunday and overall I'm pleased.
    I am going to eventually add a sub and amp but because I'm a n00b at car audio, I'm taking my time to choose my set up and save up probably 200-300 bucks which hopefully will effectively even out the lows that I'd like to hear.
    /I'm timing Chad to see how long it takes to like this... ready... GO! :burnrubber:
  9. Feb 1, 2017 at 10:51 AM
    orezona
    satan's skillet
    WARRANTY VOIDED
    0 to like in 40 seconds!
  10. Feb 1, 2017 at 10:51 AM
    ChadsPride
  11. Feb 1, 2017 at 11:26 AM
    HABOOBS
    HABOOBS Well-Known Member
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    Finally have air again!!! Pic from IG...
    pacoft, 06taco4.0, WetTaco and 6 others like this.
  12. Feb 1, 2017 at 11:42 AM
    Greg617
    Greg
    New England
    2010 5-speed 4x4
    So with the stock head unit I've noticed a significant improvement in sound quality. I haven't swapped the tweeters yet, but i'm planning on doing that in the next couple of months. Totally worth swapping out the stock 6x9s, especially for under $80 in my case.
    That being said, replacing the head unit and speakers will give you the best results. I can tell at times that my speakers are under-powered. They can apparently handle 400w each or something like that.
    Kuntrykid and ChadsPride like this.
  13. Feb 1, 2017 at 11:58 AM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Tacoma has the smallest magnet on a speaker I've EVER seen. Its slightly larger than a quarter. I agree with everyone about the head unit but even just swapping out speakers will make a huge difference. I haven't changed out my tweeters but am planning on it. If you don't change head unit buy component 6x9s with a crossover.
  14. Feb 1, 2017 at 12:10 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I think the biggest improvement in sound is switching to better speakers and using an amp to efficiently run those speakers. The head unit just puts out a signal and does not have enough clean power for aftermarket speakers and so the when you turn up the volume, the sound degrades.
  15. Feb 1, 2017 at 12:13 PM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    Peanut butter JEALOUS!! :yay:
    Mother of God... :drool::drool:
  16. Feb 1, 2017 at 12:28 PM
    la0d0g
    running for the hills
    For crawling not hauling
    I'm jelly of your lift!
    Lord Helmet, Kuntrykid and ChadsPride like this.
  17. Feb 1, 2017 at 12:52 PM
    Silver taco 09
    Silver taco 09 Well-Known Member
    2009 silver Tacoma
    Gave the Taco a bath today to get all the salt off
    Minny Taco, Kuntrykid and ChadsPride like this.
  18. Feb 1, 2017 at 1:03 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
  19. Feb 1, 2017 at 1:28 PM
    99TacoDriver
    South Louisiana
    I agree that upgrading the speakers will improve the sound quality but honestly to get even better quality would be to upgrade the head unit like the guy said earlier.
    Actually when I upgraded my head unit the two rear speakers couldn't handle it and I had to upgrade them. For whatever reason my rear door speakers blew and not the front ones. But I have wayyyyy more control of where the frequencies go and how much I want certain frequencies amplified. Just my 2 cents
    orezona, ChadsPride, ManBeast and 3 others like this.
  20. Feb 1, 2017 at 1:30 PM
    99TacoDriver
    South Louisiana
    Gave her a bath today and added another layer of wax to the hood and bumper 20170201_152040.jpg
