  1. Feb 11, 2017 at 8:36 AM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    Got some rocky mount bed rail bike fork holder things from @glandnut and some weathertech in channel window deflectors! No pics till sunday.
    Kuntrykid likes this.
  2. Feb 11, 2017 at 8:36 AM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Canadian tire special.
    It's hard to see but I split the clamp at the end of the bendy rod thing and zip tied it to the roll bar inside the dash. Motherfucker is solid. Then zip tied inside the top of the trim
    Left overs...
    Kuntrykid and Sleipnir[QUOTED] like this.
  3. Feb 11, 2017 at 8:51 AM
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
  4. Feb 11, 2017 at 8:54 AM
    ManBeast
    Zach
    Orange Park FL
    @JdevTac as for the scent in my truck if its been sitting in the sun for a while it has a very mild smell of the stuff. But it goes away or i get used to it. Its uber faint. The only place the scent has the ability to come from is the very edges of the peel and seel and thats all covered up by carpetting anyhow. Im sure itll fade as time goes by.
  5. Feb 11, 2017 at 8:57 AM
    Ano'ai808
    Ano'ai808 HoloHolo Kalaka
    Ano'ai
    Kahului
    2019 TRD sport
    2.5 fox 3-4in front/rear Dirt king fab LCA/UCA Locked rear bumps OME leaf pack ARB air 15%-5%tints
    Toyo open country's looking at it to be my next set? Noise and grip wise?
  6. Feb 11, 2017 at 9:01 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Might rub with the 285s
    Kuntrykid[QUOTED] likes this.
  7. Feb 11, 2017 at 9:02 AM
    ManBeast
    Zach
    Orange Park FL
    I have the at2, it has good grip, and just a mild road noise, got a bit louder in 25k miles but still have ALOT of life left.
  8. Feb 11, 2017 at 9:04 AM
    ManBeast
    Zach
    Orange Park FL
    In my defence i never hear it as im slamming 2 15s on 2k watts so its usually always about 140 or so dbs in the cab as is. Havent used a termlab to check dbs yet
  9. Feb 11, 2017 at 9:19 AM
    TA 4
    TA 4 Well-Known Member
    Ontario, Canada
    2015 SSM Taco access 4x4 2.7
    Cruisin offroad bumper, RCI front skid, Bakflip Tonneau Cover, Westin Running Boards, door molding, Blazer Led lights, Bed Lights, DIY Bed/rear cab mats, 3M Clear Bra (Hood and Fenders), Husky front floor mats, re diff relocated, Coverking seat covers
    Just ordered some new speakers for the front doors, get rid of those things pretending to be speakers with magnets the size of a peanut hehehehe
    RugglesTarlek and Holloman like this.
  10. Feb 11, 2017 at 9:24 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    The way olfactory sense works is by detecting change in smells. What you smell as soon as you step into the truck is what it actually smells like. From what I've read the peel and seal doesn't do too well in vertical applications. I'm planning on doing my floor and maybe behind the rear seats with it. Please post updates on this stuff every once in a while.
    ManBeast[QUOTED] likes this.
  11. Feb 11, 2017 at 9:29 AM
    Kuntrykid
    Kuntrykid Tacoholics R Us
    Jon
    Sharpsburg, MD
    2015 tacoma 5spd access cab 4x4 red
    https://www.tacomaworld.com/threads/kuntykid-builds-a-taco.406341/
    Would it be fender trimming or cab chop? & If cab mounts rub can that be fixed w/ wheel spacers?
    Lord Helmet[QUOTED] likes this.
  12. Feb 11, 2017 at 9:31 AM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    No, you'll rub the cab mount most likely.
  13. Feb 11, 2017 at 9:32 AM
    ZachPrerunner
    Southeast TN
    Both most likely. And no, wheel spacers make the rubbing worse. Only a CMC will fix it.
    DonXavi01 and Kuntrykid[QUOTED] like this.
  14. Feb 11, 2017 at 9:37 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Youll rub plastic fender & Liner.. Also the cab mount. Wheel spacers will make it worse.. But if you have stock wheels or wheels with 5"-5.5" BS then you'll need wheel spacers anyways in order to run the 285's. You will hit the UCA if you don't.
    DonXavi01 likes this.
  15. Feb 11, 2017 at 9:43 AM
    Kuntrykid
    Jon
    Sharpsburg, MD
    I have 6lug steelies. Fenders should be good. I have mobtown bumper that I'm putting in a week or 2 so the only rubbing issue if I'm understanding correctly is the cab mount? & To what extent would the rub be? Only @ full turn?
  16. Feb 11, 2017 at 9:47 AM
    ManBeast
    Zach
    Orange Park FL
    10.4 , it definetly took care of a good bit of road noises. And alot of the bass rattle. I still need to get 3 doors. And the front half of floor. My fingers got very sore from pressing into the corners and nooks so took a break lol
    trdsport6 and Kuntrykid like this.
  17. Feb 11, 2017 at 9:49 AM
    Lord Helmet
    Nick
    '24 X3 M40i
    Depends if you have aftermarket wheels or not. Also the backspacing of the aftermarket wheels too.
  18. Feb 11, 2017 at 9:55 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Get a 3" paint roller and a pestle from a pestle and mortar for all the nooks and crannies
  19. Feb 11, 2017 at 9:58 AM
    un par de tenis
    un par de tenis Member
    2010 Black Tacoma Prerunner SR5 V6
    My headlights were all cracked and foggy so I recently installed these. They're the same style as the stock headlights, but they're sort of "blacked out." They look 100 times better than the stock ones in my opinion. I'm really satisfied with them and I'll probably get the matching fog lights soon.
    Lord Helmet and Kuntrykid like this.
  20. Feb 11, 2017 at 9:59 AM
    ManBeast
    Zach
    Orange Park FL
    I was using the back end of of my box cutter as it was round smooth plastic. But even that was wearing on my fingers lol
    Thyces[QUOTED] likes this.
