  1. Feb 11, 2017 at 11:08 AM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Will do!!!!
    Can it be the same good samaritan waiver or should my lawyer draft a specific one for restaurant liabilities?
    Kuntrykid likes this.
  2. Feb 11, 2017 at 11:18 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Like others were saying, you'll rub the fenders and the cab mount, and possibly the pinch weld. If you're running steelies, then you will also rub the UCAs unless you get wheel spacers.
  3. Feb 11, 2017 at 11:21 AM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    So ive tossed around the idea of 1 day vinyling my truck in matte olive green. Thoughts
  4. Feb 11, 2017 at 11:24 AM
    Kuntrykid
    Kuntrykid Tacoholics R Us
    Jon
    Sharpsburg, MD
    2015 tacoma 5spd access cab 4x4 red
    https://www.tacomaworld.com/threads/kuntykid-builds-a-taco.406341/
    Cab mounts rubbing would that only be full turn?
    Lord Helmet likes this.
  5. Feb 11, 2017 at 11:38 AM
    dino41
    dino41 Well-Known Member
    San Diego, California
    2015 Sky Silver Crew Cab V6 SR5 Prerunner
    The whole concept is a great idea, but please heed my warning as I have seen my share of over pressurized tanks and containers. Please bare in mind that these types of containers are "not" meant to be pressurized even at at 10 PSI. Plastic fuel and water containers unlike FRP (fiberglass reinforced plastic) and metal tanks are plastic seam welded containers and have very weak joints when put under pressure. Just my two cents as I would not want anyone to get hurt while attempting such builds.
  6. Feb 11, 2017 at 12:11 PM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    I MAY do KM2's. No interest in KO2's. Because mud.....
    Kemosabe likes this.
  7. Feb 11, 2017 at 12:12 PM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Someone did this.... Looked pretty good
  8. Feb 11, 2017 at 12:13 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    More like half turn probably. Go out and turn your wheel all the way and look at where your cab mount is in relation to how far the wheel gets tucked in. That'll give you a good idea.
    Kuntrykid[QUOTED] likes this.
  9. Feb 11, 2017 at 12:14 PM
    HABOOBS
    HABOOBS Well-Known Member
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    Yeah agreed... The 10 PSI range is a good one to stay within... I went up to 20 PSI just to see and it definitely didn't feel comfortable...
  10. Feb 11, 2017 at 12:16 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    DJEMZSRAUC likes this.
  11. Feb 11, 2017 at 12:20 PM
    CrashN'Burn
    CrashN'Burn I used to have a life
    Joshua
    Union City, CA
    '13 TRD Sport MGM
    Hands down best mod thus far...
  12. Feb 11, 2017 at 12:24 PM
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
    Congratulations!
  13. Feb 11, 2017 at 12:25 PM
    un par de tenis
    un par de tenis Member
    2010 Black Tacoma Prerunner SR5 V6
    Been doing a good bit of research and I think I'm gonna pull the trigger on the ultra gauge
  14. Feb 11, 2017 at 12:27 PM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    I replaced the wipers with Bosch Icons, and also did my first oil change (first 4 courtesy of Toyota). The local dealer service department is closed on Saturdays so I settled with a fram filter and Royal Purple 5w30!
    I can't believe our trucks take 5.2 Qts and jugs are 5qt. I need to go pick up a small bottle and top her off.
  15. Feb 11, 2017 at 12:28 PM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Last hearing test, I have 70% hearing loss in right ear, 55% loss in left. Grew up on farm tractors before cabs were common, Army artillery, dirt bikes, and loud car stereo's. Just about every 4wd I've owned had mud tires.....First dozen were in the bias ply/"Gumbo Mudder" days. I'm used to it and consider tire noise part of the full effect.
    That said, it's one set of tires....No street set and off road set. I want a decent street tire, but do NOT want a ton of "give up" when the pavement ends. Duratracs have done pretty well and they're still a consideration, but I'd like to have something different. I had KM2's on my Dodge. They were meh on wet roads, but downright scary when loaded heavy.
    Which keeps bringing me back to the Cooper STT Pro's.....
  16. Feb 11, 2017 at 12:31 PM
    tacoma909sport
    tacoma909sport Well-Known Member
    So Cal
    14 DoubleCab Sport
  17. Feb 11, 2017 at 12:33 PM
    Justanotherhemi
    Rick James
    That looks really cool. Great job
  18. Feb 11, 2017 at 12:35 PM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Congrats! Those added accents to the truck look great as well!
    TACOVRD likes this.
  19. Feb 11, 2017 at 1:03 PM
    Ano'ai808
    Ano'ai808 HoloHolo Kalaka
    Ano'ai
    Kahului
    2019 TRD sport
    2.5 fox 3-4in front/rear Dirt king fab LCA/UCA Locked rear bumps OME leaf pack ARB air 15%-5%tints
    Link?
    ChadsPride likes this.
  20. Feb 11, 2017 at 1:04 PM
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    Do tell, what did you get? Mine is foggy.
    (2013 Tacoma)
