  1. Mar 3, 2017 at 3:24 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    orezona likes this.
  2. Mar 3, 2017 at 3:28 PM
    orezona
    orezona title unspecified
    satan's skillet
    2006 TRD OR DCSB OMGWTFBBQ TL;DR
    WARRANTY VOIDED
    Got pretty much all the pieces together to do the ABS kill switch mod... Have many people done this without getting a t-splice connector and just done it with solder...?
  3. Mar 3, 2017 at 3:36 PM
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Pittsburgh, PA
    2013 Black Baja Access Cab
    That's how I did it. I used a razor blade to cut away about an inch of insulation without cutting the wire, then soldered in a tee-wire that grounds via the switch. I got a push-button switch from aironboard.com and put it into one of the two center switch blanks.
    http://www.aironboard.com/online/pu...toyota-oem-replacement-abs-off-led-green.html
    I just wired it to ground the locker - no relay to make the switch lights work. It's painted similar to the other non-lighted factory switches, and since you get multiple dash lights when it's on I didn't see the need for the switch to light up too.
    I also added dual USB power ports while everything was apart. Came out good and works like a charm.
  4. Mar 3, 2017 at 3:42 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Put the tires on.
    Before
    After
    BadlandsTACO and oliver1539 like this.
  5. Mar 3, 2017 at 3:44 PM
    orezona
    satan's skillet
    WARRANTY VOIDED
    I have a USB port as well but no Add-A-Fuse so I'll have to wait on that mod.
    Probably going to mount a little round rocker switch down and out of the way for now. Don't care how it looks, just that it works!
    Thanks for the help, by the way :cheers:
    Soul Surfer likes this.
  6. Mar 3, 2017 at 3:53 PM
    SC2TAHOETACOMA
    SC2TAHOETACOMA Well-Known Member
    Josh
    Santa Cruz
    Wish I had a parking spot that big...
    ManBeast likes this.
  7. Mar 3, 2017 at 4:04 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    What gauges are those? Don't think I've ever seen any like them before.
    DonXavi01 and oliver1539[QUOTED] like this.
  8. Mar 3, 2017 at 4:13 PM
    Nimble9
    Nimble9 visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    I have two! Lol
    ChadsPride likes this.
  9. Mar 3, 2017 at 4:15 PM
    Yota Bucket
    Yota Bucket Well-Known Member
    Mt. Shasta CA xX
    2009 TRD TACO
    Turning some heads today, Threw on the CaliRaised ditch brackets and lights , got them running on my lunch break. Pretty happy with how they turned out
  10. Mar 3, 2017 at 4:29 PM
    Tacomalx4x4
    Tacomalx4x4 Well-Known Member
    Corey
    Wv
    07 6spd DCSB silver
    3inch ultimate, straight exhaust, XD's 285's, grill, lights, fog mod, jvc unit. Rear cam mod, pioneer 3ways
    What are your thoughts on the supercharger?? I wanna pull the trigger on one bad!
    oliver1539[QUOTED] likes this.
  11. Mar 3, 2017 at 4:39 PM
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Wheel spacers to space my spare out!
    DonXavi01 and NorthCountryTRD like this.
  12. Mar 3, 2017 at 5:24 PM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    Re floated solder for temp/compass display. Painted shifter trim satin black, would like to switch out centre stack for newer black version as I don't like the silver.
    cproc, Nimble9, orezona and 1 other person like this.
  13. Mar 3, 2017 at 5:34 PM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    One plus and one minus. Manufactured 8/16/16.
    Heavy ##ckers!
    KCTaco77 and LivinLoud like this.
  14. Mar 3, 2017 at 6:04 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    Changed my oil and discovered my passenger side fog light is cracked x_x
    kgarrett11 likes this.
  15. Mar 3, 2017 at 6:29 PM
    Camels20
    Camels20 Active Member
    Dave
    2009 Tacoma TRD
    Single piece driveshaft. Tom Woods Custom Driveshafts. Double cardan cv up front single rear. 3.5" tube with 1310 universal flanges to adapt to Toyota T4 flange. Carrier bearing is like $230 plus install, or your time. Less than $500 out the door with shipping. 1310s can be found anywhere. Fully greaseable. I figure in another year I would end up destroying another CB anyway, so $500 ain't bad...and...no more vibes!!!! Did need 3 degree axle shims, but I am a happy camper/wheeler.
    Nimble9 and kgarrett11 like this.
  16. Mar 3, 2017 at 6:30 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Wheeler's front bumbstops.... butter smooth ride :thumbsup:
    kgarrett11 and Soul Surfer like this.
  17. Mar 3, 2017 at 6:32 PM
    Lord Helmet
    Nick
    '24 X3 M40i
    Installed the All Pro U-bolt flip kit with Wheeler's bumpstops:
  18. Mar 3, 2017 at 6:55 PM
    spiralout462
    Eastern Shore VA
    2015 4x4 dclb
    Which leaf pack?
  19. Mar 3, 2017 at 7:00 PM
    Lord Helmet
    Nick
    '24 X3 M40i
    Bocsy44 and kgarrett11 like this.
  20. Mar 3, 2017 at 7:39 PM
    nazlax10
    nazlax10 Check out my build thread for any products used!
    David
    Woodstock, GA
    '21 Toyota Rav4 LE... At least it's a Toyota
    https://www.tacomaworld.com/threads/nazlax10s-build.408318/
    Over the past few weeks.
    Swapped my factory head unit with a nav equipped one that I got from @JD'STaco! Thanks again man!
    Took off my a pillar ram mount since all I used it for was GPS.
    ...that's right, all nat-u-ral!
    Man I love factory looks with features!
    Also drove nearly 2,500 miles from Omaha Nebraska to Anchorage Alaska!
    Here's some pictures from the ferry! The coast of Canada and Mt. Rushmore.
