  1. Mar 7, 2017 at 11:22 AM
    tacabode
    tacabode Well-Known Member
    Ohio
    '14 MGM DCSB TRD OR
    had two TSB's done today under warranty
    T-SB-0026-15 (driver needle bearing). If it doesn't work i'll replace it myself with the ECGS bushing
    and
    T-SB-0044-14 (Engine knock)
    these were done no questions asked, even though i have a lift, tires, electrical mods, etc.... good day. :cool:
    kyuss88, woodydog and jpereira2 like this.
  2. Mar 7, 2017 at 11:22 AM
    G.T.
    G.T.
    CONUS
  3. Mar 7, 2017 at 11:33 AM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    Amazon box was flawless, you can just tell orderfiller threw that shit in the box to make productiom, i work in a distribution center for walmart, i understand the way it works when you have a qouta to fill, however, i need it fixed now.
    ChadsPride[QUOTED] likes this.
  4. Mar 7, 2017 at 11:34 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    FUCK. Well, that blows to say the least.
    ChadsPride likes this.
  5. Mar 7, 2017 at 11:34 AM
    ManBeast
    Zach
    Orange Park FL
    Elaborate on the engine knock, how loud is it?
    airwhen and ChadsPride like this.
  6. Mar 7, 2017 at 11:35 AM
    ManBeast
    Zach
    Orange Park FL
    Yep. This set my install back to next tuesday probably.
  7. Mar 7, 2017 at 11:35 AM
    Cativelense
    Nuno
    CT
    DISLIKE.
  8. Mar 7, 2017 at 11:48 AM
    tacabode
    Ohio
    '14 MGM DCSB TRD OR
    depends on the outside conditions. its caused by toyota trying to meet emissions/efficiency standards and leaning the truck out too much on the low end. if the cylinder gets too hot the air/fuel mixture will detonate before the piston gets to the top of the cylinder (that's the knock). the tsb is a simple ecu reflash that adjusts the mapping ever so slightly
    conditions that make it worse/noticeable:
    1) higher engine bay temps (hot outside, moving slowly)
    2) steep hills
    3) low rpm
    our engines have a normal "tick" that can be heard even at idle (variable valve timing). this is NOT that. when you hear it knock... you'll know it
  9. Mar 7, 2017 at 11:50 AM
    Cativelense
    Nuno
    CT
    That sounds exactly like what I had a while back, and took it in to get looked at and fixed, and got taken care of.
    They didn't give me any info though, like what you have... but still fixed nonetheless.
    Kuntrykid and ChadsPride like this.
  10. Mar 7, 2017 at 11:56 AM
    tacabode
    Ohio
    '14 MGM DCSB TRD OR
    according to the TSB they should have put a sticker on the lower right (driver side) inside your hood
    T-SB-0044-14 Feedback: Engine ECM Reprogram [Pinging]
  11. Mar 7, 2017 at 11:57 AM
    Cativelense
    Nuno
    CT
    HMM... Never really looked for anything, but I'll check it out after work then. Thanks for that tidbit!
  12. Mar 7, 2017 at 12:09 PM
    la0d0g
    running for the hills
    For crawling not hauling
    What's the urgency?
  13. Mar 7, 2017 at 12:10 PM
    ManBeast
    Zach
    Orange Park FL
    Because.
    Kuntrykid, ChadsPride and Cativelense like this.
  14. Mar 7, 2017 at 12:12 PM
    la0d0g
    Huh?
  15. Mar 7, 2017 at 12:22 PM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    OCD man! Look it up!
    ChadsPride, floodedkiwi and ManBeast like this.
  16. Mar 7, 2017 at 12:23 PM
    ManBeast
    Zach
    Orange Park FL
    I ordered it. I shouldnt have to return for a new one. Its the principal of the matter. I have been waiting on it. It shows up and im let down.
  17. Mar 7, 2017 at 12:24 PM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    Got the TRED boards mounted to the bed rail! T-Slot nut, 5" bolts, and stacked two washers. Had a cute little helper too
    Kuntrykid, T4RFTMFW, smcgill and 11 others like this.
  18. Mar 7, 2017 at 12:25 PM
    Cativelense
    Nuno
    CT
    Admit it... you didn't to jack shit and your helper did all the work. :D
  19. Mar 7, 2017 at 12:26 PM
    la0d0g
    Agreed on your points. I was just curious if there was urgency like your shit was all torn out and waiting for this to go in prior to putting it all back together.
  20. Mar 7, 2017 at 12:27 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    :D
