  1. Mar 10, 2017 at 10:40 AM
    airwhen
    airwhen "You done messed up A.A.Ron!!!!
    Seattle, WA
    2015 TRD Sport DCSB 4X4
    Too much to list!
    LOL!
    ChadsPride and Jonny22r[QUOTED] like this.
  2. Mar 10, 2017 at 10:43 AM
    keith88lx
    keith88lx Well-Known Member
    Mount Prospect
    15 DCSB TRD Sport 4x4
    First of all, I love my truck. But, I will admit, I almost traded it in this morning. Only reason is, I've always wanted a Charger RT Scat Pack. Actually almost bought one rather than buying my Tacoma 2 years ago.
    But, I kept saying in my head, if they offered a good enough trade that would make me happy, then I will trade it. They came close ($500 difference). But, it wasn't enough to let it go. I still love my truck.
  3. Mar 10, 2017 at 10:45 AM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    It's the Lotek pod (http://www.gaugepods.com/toyota_t.html). The fit in the truck itself seems good. There's a slight gap at the very top/bottom of the grab handle. The top gap is visible in my picture. I may take my heat gun to the grab handle to bend those points in to eliminate the gap if it ends up bugging me.
    Guage fitment was a little trickier. The gauge holes are intentionally undersized just slightly for a tight fit. I had to file the top hole to get the gauge to go in. The bottom hole I was able to fit the gauge without filing. Bezel clearance was something entirely different. I'm mounting PLX gauges and maybe they have a slightly larger than normal bezel diameter (i don't know), but I had to do some light sanding with the dremel because the bezels were hitting the pillar and sticking out 1/4"+ from flush. The top gauge took less than the bottom gauge. I was worried about putting a hole in the pillar with the bottom gauge, so I used my heat gun to soften the plastic and reshaped the pillar ever so slightly to get the bottom gauge to seat.
    Kuntrykid and ChadsPride like this.
  4. Mar 10, 2017 at 10:48 AM
    airwhen
    Seattle, WA
    Too much to list!
    I am curious at what ball park price they would offer for a 2015 Sport like yours? If you don't mind sharing. If not, that's OK too.
    ChadsPride likes this.
  5. Mar 10, 2017 at 10:50 AM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    I had their gauge setup in my 03 taco and wasnt happy at all with it, so many gaps and random bumps that were not needed. also looks like they dont have one for the 2014 :(
  6. Mar 10, 2017 at 11:01 AM
    la0d0g
    running for the hills
    For crawling not hauling
    Is all royal purp synthetic? If so save yourself some $$ next time and use dyno Lucas.
    Can't you just tap into the dtrl wiring?
  7. Mar 10, 2017 at 11:02 AM
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    I've read a number of comments about poor fitment, so I either got lucky or they've improved on their quality. If anything, the pods could have done with moving out from the main pillar an extra 1/8" or so to provide bezel clearance. The actual main part of the pillar though seems nearly identical to the factory pillar. As I've seen mentioned before, I had to do some dremeling to the grab handles to make them fit. There's an indexing tab that has to come off. I've also read a lot of complaints about the color not being an exact match. To my eye, it's close enough that I can't tell a difference between the color of the grab handle and the pillar.
    The "05-09" pillar may work on your 14. I don't know if/when Toyota updated them.
  8. Mar 10, 2017 at 11:03 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    I think that's what needs to be done, but not sure what wire that is. Assuming I can/have to use a t-tap, since it came in the kit I received, so it's just a matter of finding the wire.
    A fellow CT member gave me some info that I think will help, so going to attempt it and see what happens. Thinking about doing a "mock up" sort of speak, and connect everything to make sure I know where it all goes and have a visual before I actually put it all on the truck.
  9. Mar 10, 2017 at 11:05 AM
    la0d0g
    Just start cutting wires and when the dtrl turn off you've found the right one :D
    I bet there is a schematic for it somewhere, I'll try to find one.
  10. Mar 10, 2017 at 11:09 AM
    consultadrone
    consultadrone Well-Known Member
    Orange County, CA
    '15 DCLB
    Just remember that the DTRLs are also the turn signals, so if you tap the halos into the DTRLs they will also flash with the turn signals when you use them. Could be a cool effect.
  11. Mar 10, 2017 at 11:11 AM
    Cativelense
    Nuno
    CT
    Didn't even think about that... that would be cool as hell right there!
    consultadrone[QUOTED] likes this.
  12. Mar 10, 2017 at 11:12 AM
    Cativelense
    Nuno
    CT
    Thank you sir!
    That would be cool as hell right there.
  13. Mar 10, 2017 at 11:25 AM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    This was synthetic. Have used before.
    Was on sale.
    T4RFTMFW and ChadsPride like this.
  14. Mar 10, 2017 at 11:26 AM
    la0d0g
    Well as long as you have coupons.
  15. Mar 10, 2017 at 11:36 AM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    I have retros on order (since August!) And have read a few places that the LED halos dont like heat that's generated by the HID. No conclusive data is out there, maybe you lose a week of life out of 5 years, or maybe you lose half who knows. I plan to wire mine with relays that turn the halos off when headlights go on.
  16. Mar 10, 2017 at 11:37 AM
    Cativelense
    Nuno
    CT
    Makes sense.
  17. Mar 10, 2017 at 11:44 AM
    AR15xAR10
    Damn straight. Brother's gotta save that cheese
  18. Mar 10, 2017 at 12:09 PM
    bikeordie1
    bikeordie1 Well-Known Member
    Jeremy
    Bellingham, WA
    '11 Tacoma TRD-OR DCSB AUTO
    5100's in back Braided extended brake lines Pioneer DBL-DIN w/backup cam K&N intake OEM bed mat Window tint Debagged Custom fab 5-bike shuttle rack
    Thank you sir. Traded in my '04 Prerunner for it. Sad to see it go...
  19. Mar 10, 2017 at 12:36 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    @Cativelense depending on how hard it is, have you considered making the halos switchbacks? Like they're white for DRLs, but once you use the turn signal, the respective one starts flashing amber? My buddy has that on his runner and it looks really cool.
    EDIT: Ok nevermind. After some researching, it appears to be a PITA and not something you'd want to tackle alone.
  20. Mar 10, 2017 at 12:41 PM
    Cativelense
    Nuno
    CT
    I thought about the whole color changing thing, but not really into it to be honest. I wanted retros for two reasons basically.
    1) to black out my truck even more
    2) for the better light output because of the type of lights/bulbs you can use, compared to led bulbs or oem bulbs
    The lights are built already without that, which is what I wanted, so I'm pretty sure I'll be super happy with them once I tackle the install.
    ChadsPride and consultadrone like this.
