  1. Mar 13, 2017 at 5:21 PM
    Do58
    Do58 Well-Known Member
    2015 white tacoma limited
    Thanks for the response. I ran thru the other threads ( original thread ) and most people that had the cover put it back on. I did too and looks more stock
    Cativelense likes this.
  2. Mar 13, 2017 at 5:22 PM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Agreed. That's probably why peeps did it too. That's the reason why I did.
  3. Mar 13, 2017 at 5:31 PM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Nope. Just memorized them. I had sprayed it one day when I was bored just to see if I liked it.... As you can see, I liked it.
  4. Mar 13, 2017 at 5:39 PM
    mynameisbs
    mynameisbs Active Member
    Central Alabama
    2009 TRD Off Road
    I replaced my old rusted out d-rings with new ones. Took less than 5 minutes, and the d-rings were like $25. The old ones literally just unscrew from the bed with the proper size torx bit (sorry I don't know the exact size, but it's smaller than the T55 the bed bolts use) and the new ones screw right in. I didn't have a torque spec but I didn't want them going anywhere, so I made them tight enough to make me comfortable that they'd be able to stay in place and not rattle loose.
    20170313_165755.jpg 20170313_165804.jpg 20170313_170641.jpg 20170313_170645.jpg
    Since the pieces are meant to be installed on the side of the wheel wells, they come with these plates that are welded to bolts. I didn't use them, so I can keep them around for another project.
  5. Mar 13, 2017 at 5:56 PM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    where did you get those? I tried adding some tie down to my bed bolts last fall but it was pretty cold out and the bolts were too rusted to come out freely haha I'm going to try again this summer with some pb blaster but if all else fails I could resort back to the ones u have. I could just drill a hole in the bed and bolt those on, just wondering if they would be strong enough with just the ring up top and that backing plate down under
  6. Mar 13, 2017 at 6:05 PM
    mynameisbs
    Central Alabama
    2009 TRD Off Road
    I got them here on Amazon, but if you shop around you might be able to find them for cheaper. You could also check at the dealer, as these are OEM parts. As I understand it, they don't keep them in stock, but can have them delivered rather quickly.
    There are many threads on the forums here about putting new rings in the front. I can tell you from experience that the bolts in the bed are pretty damn tight the first time you unscrew them.
  7. Mar 13, 2017 at 6:27 PM
    Homar2394
    Homar2394 Well-Known Member
    Homar
    New york
    2012 tacoma trd sport
    K&n intake trd catback Anzo headlights and tail lights pioneer avic 7000 nex head unit factory backup camera .eliminated jbl.4 beyma 6.5 mids 4 sound stream tweeters 2 4.5 mids
    Yes I actually bought a bypass online it's easy to install here's the link
    https://www.ebay.com/itm/271250716780
    airwhen[QUOTED] and ChadsPride like this.
  8. Mar 13, 2017 at 6:55 PM
    airwhen
    airwhen "You done messed up A.A.Ron!!!!
    Seattle, WA
    2015 TRD Sport DCSB 4X4
    Too much to list!
    Love that color!
  9. Mar 13, 2017 at 6:57 PM
    At The Helm
    At The Helm ATH Fab Vendor
    Morgan
    Gardnerville, NV
    2015 AC 4x4 TRD OR & 2019 T4R
    Kings, TC UCAS, SCS SR8's, ATH bumpers
    Test fit a new product...
    Front bed rail tie downs with built in wheel chocks and of course bottle openers :D
    I'll have a few of these ready soon.
  10. Mar 13, 2017 at 6:57 PM
    airwhen
    Seattle, WA
    Too much to list!
    Those bypasses don't work with AVIC radios, only AVH units. AVIC radios have it built in. Hooking up the wired bypass things should not work properly.
    ChadsPride likes this.
  11. Mar 13, 2017 at 7:03 PM
    Zebinator
    Zebinator Well-Known Member
    Norcal
    06 Tacoma TRD Offroad
    I'm mid way through the same idea - but i started with the panel not the wiring... Hoping to outsource the wiring bit... What are you going to do for switches?
  12. Mar 13, 2017 at 7:03 PM
    Zebinator
    Norcal
    You going to be selling these?
  13. Mar 13, 2017 at 7:05 PM
    Zebinator
    Norcal
    Test fitting... Almost done...
  14. Mar 13, 2017 at 7:09 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    Thats pretty rad!
  15. Mar 13, 2017 at 7:09 PM
    At The Helm
    Morgan
    Gardnerville, NV
    Yes I will. I'll have four of them available soon and will gauge interest from there.
  16. Mar 13, 2017 at 7:12 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Me likes :thumbsup:
  17. Mar 13, 2017 at 7:16 PM
    Homar2394
    Homar
    New york
    It worked on my avic7100 nex maybe not on the 7200 nex and 8200 nex or the newer pioneer HUs. I saw a bypass that's $50 for the avic 5200 6200 7200 8200 nex maybe that's the one you need.
  18. Mar 13, 2017 at 7:18 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Well, a guy at work told me about this, and I was going to get one for my truck, but O'Reilly's site says they're not available.
    O'Reilly's Part#121G
  19. Mar 13, 2017 at 7:26 PM
    GetzPayd
    GetzPayd Well-Known Member
    Kennewick WA
    2014 DCSB Sport
    Total Chaos & Kings
    Mines back ordered as well
    :headbang:
  20. Mar 13, 2017 at 7:28 PM
    cuda2k
    cuda2k Well-Known Member
    Jon
    Allen, TX
    BRM 15 TRD Off Road 4wd
    LVL8 MK6 wheels,SOS Sliders,Smked 3rd Brake,Gibson Exhaust
    otrattw, just haven't decided on upper vs lower independent, and what color to go with. I'm toying with the idea of putting the rock lights down in the center console with an AirOnBoard push button switch, but at the moment I'd have a full 6-pack switch set up top so will probably just go that route and just swap out a rocker if I change it up later. Don't expect to need many more - but then again till about 48hrs ago I wasn't planning to do an in cab winch control either.
