  1. Mar 18, 2017 at 10:27 AM
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR
    Correct. Had mike autograph my TW calendar!! :D
    Kuntrykid likes this.
  2. Mar 18, 2017 at 10:44 AM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    h that's funny! Mike's a good dude. We sepeak often through PM. Rick Idk really but seems like good dude. I need to get with you later about details on the catch can. I still don't competely understand the benefit. I did finalyy get the uni-filter mod done the other day.
    Soul Surfer[QUOTED] likes this.
  3. Mar 18, 2017 at 10:45 AM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Got my little show pony all shined up for our first meet. So of course it'll probably rain.
    kyuss88, Ret CB, Kuntrykid and 4 others like this.
  4. Mar 18, 2017 at 10:59 AM
    M21henry
    M21henry Well-Known Member
    Henry Morgan
    Taco 4x4 12 reg cab
    3inch lift bumpers 6matching wheels Waterproof winch LED light all pro rack
    Sadly I posted mine for sale on craigslist
  5. Mar 18, 2017 at 11:00 AM
    02YotaGuy
    02YotaGuy Guy With A Red 80 Series
    Matthew
    Springfield, VA
    94 FZJ80
    Bumper, Winch, 315s, Sliders, OME HD lift, Custom rear swingout, roof rack, drawers, way too much to list.
    That is sad :(
  6. Mar 18, 2017 at 11:23 AM
    JaxJim
    JaxJim Well-Known Member
    Jim
    Jacksonville, FL
    13 TRD Sport, DCSB, 4x4, JBL, NAV
    Exterior: Duratrac 265/70/17, SpiderTrax 1.25" wheel spacers, BAMF sliders, DiamondBack SE Tonneau Cover, Pop&Lock, Tail Gate guard, Bed Mat, Bullaculla Trailer Harness bracket, Front Side Windows tinted to match rear, Removed all chrome and dealer badges, Toyota OEM Roof Rack/Rails, SOS Concepts Front Recovery bracket Under Hood: Redline Tuning Quicklift Hood Struts, Foglight anytime mod, UniFilter for Secondary Air Pump Interior: Seat bell Chime disable (TechStream), WeatherTech floor liners, ImMrYo rearview mirror relocation bracket, 12v Always-on Power port in console Radios/Comms: AntennaX 14", Escort Passport MAX Radar Detector, Yaesu 2900 Ham Radio, Uniden 980SSB CB Radio, Relentless Fabrication hood antenna mount, BAMF tailgate antenna mount, FireStik 2m and CB antennas, FireRing coax
    I did this yesterday but ran out of time for pictures. Installed the CB radio and antenna. I previously had mounted a 2m ham rig and that is what I use 90% of the time and this is an additional radio install for when hunting and offroading, the CB comes in really handy. I previously was running a Wilson Lil-Wi mag mount with a Midland 75-822 CB because it could be removed easily when not in use. BUT, the antenna on the roof hit everything and I have scratches on the roof where it grabbed a limb and slid back about a foot. I also couldn't run both a CB and the 2m HAM rig since the antennas would conflict and mess up SWR.
    So, here is the new and improved install. Still can be pulled out easily when not needed, but a much more robust installation. I live about 4 miles from 295 and about 6 miles west of 95 and can hit truckers on both roads with ease. I'm pleased with the install and the antenna SWR (1.2:1 or less across band).
    One thing to note and is probably a big part of the great SWR is my tonneau cover is aluminum and I bonded all three pieces to each other, then bonded the center section to ground of the truck. That's a big slab of flat ground plane for the antenna!
    Radio: Uniden Bearcat 988SS
    Antenna: Firestik II 4'
    Coax: Firestik FireRing with EZ connector
    Mount: BAMF tailgate/fender mount on passenger side. Purchased bare, sprayed with Rustoleum Bedliner.
    I ran the coax along an existing wire harness along right-side frame rail. I entered the cab through a grommet that is about in the middle of the passenger rear floor and came through the carpet under the passenger seat. The 18' cable was just right in length, very little extra length.
    I'm not 100% convinced that the mount is all that sturdy. It moves around by hand pretty easily. I'm thinking about how I can make it stiffer but for now it'll do.
    I already had power coming out the center console for the HAM rig and a second feed line to a power port. I tapped into the power port feed and attached a quick connect. Then attached the opposite side of the quick connect to the radio's power cable. All connections are soldered and shrink wrapped. No twist nuts or tape used!
    I used industrial Velcro, 2" wide and attached two strips of the loop (smooth) side to the center console. I'm not sure how the glue is going to hold up in Florida, but I can use a better glue if it doesn't stay. The radio got two strips of the hook (the prickly part) attached and the radio is SOLID. I did use a right angle PL-259 connector on the coax line to relieve any strain on the cable.
    I tuned everything up using an antenna analyzer, then a final check with the radio. So far, I'm happy with the install. To remove all I need it unscrew the antenna from the mount, pull coax, power and speaker connections from radio and it's out. Takes maybe 5 minutes to install and 2 minutes to remove. I do put a bolt into the antenna base to keep moisture out when not in use.
    Antenna:
    Mount:
    Radio:
    Speaker:
    Velcro:
    Coax entry point:
    Kuntrykid, stbear, Thyces and 2 others like this.
  7. Mar 18, 2017 at 11:34 AM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    The whole truck? If you say sadly it doesn't appear to be by choice.
  8. Mar 18, 2017 at 11:47 AM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    There is a technique where you can win every time..... Don't play! I had a freezer with $300 worth of meat die suddenly about a month ago.... I feel your pain.
    Kuntrykid and NordidiroN[QUOTED] like this.
  9. Mar 18, 2017 at 11:55 AM
    Yota831
    Yota831 Well-Known Member
    Santa Cruz
    2024 Tacoma SR5 4x4
    new all weather floor mats
  10. Mar 18, 2017 at 11:57 AM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    Nice first post, and welcome
  11. Mar 18, 2017 at 12:01 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Welcome to TW
  12. Mar 18, 2017 at 12:07 PM
    Soul Surfer
    Jimi
    ‘25 TRD OR
    Here's some info.
    https://www.tacomaworld.com/threads/oil-catch-can.312623/
  13. Mar 18, 2017 at 12:11 PM
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    I used a $4 one from harbor freight
    airwhen[QUOTED] likes this.
  14. Mar 18, 2017 at 12:17 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I used the same radio/entry point. But chose this install location20170313_123934.jpg
    I grabbed the Bluetooth mic. I think it's worth the $40.
    gabbo2112, Kuntrykid and Soul Surfer like this.
  15. Mar 18, 2017 at 12:18 PM
    ManBeast
    Zach
    Orange Park FL
    Blacked out knobs?
  16. Mar 18, 2017 at 12:21 PM
    M21henry
    Henry Morgan
    Taco 4x4 12 reg cab
    Have 4 cars. And am going g to buy back my old FJ60 so have to part with one
  17. Mar 18, 2017 at 12:27 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Black out ehrryting... Derp to be exact
  18. Mar 18, 2017 at 12:29 PM
    Karate1993
    Karate1993 Well-Known Member
    coloRADo
    '14 TRD Off-road DCSB
    Just gave both cars a bath! 80 degrees in Colorado today!
  19. Mar 18, 2017 at 12:30 PM
    Naumoff42
    Naumoff42 Well-Known Member
    Ohio
    2015 TRD Offroad
    Need to get my frame coated. Ideal way to do it? [​IMG]
    Hootney, gabbo2112 and Kuntrykid like this.
  20. Mar 18, 2017 at 12:40 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    jpereira2 and ManBeast like this.
