  1. Mar 21, 2017 at 11:26 AM
    airwhen
    airwhen "You done messed up A.A.Ron!!!!
    Seattle, WA
    2015 TRD Sport DCSB 4X4
    Too much to list!
    Nope, not legit one bit.
  2. Mar 21, 2017 at 11:29 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Question for peeps with retros... adjusting them. Hard? Easy?
    What's the best way to do it? I've read to park 25 ft from a wall, 40 ft from a wall... which one?
    And, when aimed at the wall, how high up should the light "cut off" line be? Make sense?!
    Kuntrykid, airwhen and ChadsPride like this.
  3. Mar 21, 2017 at 11:29 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    This should catch you up.
    https://www.tacomaworld.com/threads...differential-bearing-vibration-thread.152173/
  4. Mar 21, 2017 at 11:51 AM
    G.T.
    G.T.
    CONUS
    Get in the regional section of the forums and post up. They will turn up.
    Kuntrykid[QUOTED] and ChadsPride like this.
  5. Mar 21, 2017 at 11:53 AM
    airwhen
    Seattle, WA
    Too much to list!
    I put my truck right up against a level underground garage wall (1/2 inch from the bumper). I marked the step downs with tape on the wall (horizontal, vertical angle, then horizontal - Looks sort of like backwards Z). I also measured three feet out each side from the ground with a horizontal strip of tape to get the balance of the horizon. (Left of right tilt) Then measured the distance between the centers of the headlights (the little dots on the lens) which is 55 inches and the distance between the step downs (also 55 inches.). Finally I measure the distance from the base of the headlights to the ground, then subtracted 2 inches and taped those lines right below the step downs. I then backed up 25 feet within 1 inch of deviation. Right and left centered the step downs to match the tape marks, aligned the horizon to the outer tape marks and the vertical adjustment to the tape marks two inches below. If yours are already built, you may not have the ability to do the horizon tilt.
    Kuntrykid and ChadsPride like this.
  6. Mar 21, 2017 at 11:56 AM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    If you feel like coming to the beach, I'll put you up. We can knock em out at the same time.
  7. Mar 21, 2017 at 11:57 AM
    Cativelense
    Nuno
    CT
    DAUYM!!!!!!!!!!! Talk about technical. GEEZ! Yeah, mine are built already, it's a matter of possibly adjust the light output per say, to "raise it" if that makes sense. Meaning. The retros are built, mounted on the truck, but I think the light is aiming "down" too much as not "high" enough to light it "down the road".
    airwhen[QUOTED] likes this.
  8. Mar 21, 2017 at 12:00 PM
    outlawtacoma
    W. TN
    2018 T4RTRDOR
    Great offer! Wish I could make it this weekend! I sure do appreciate it!!
    ChadsPride likes this.
  9. Mar 21, 2017 at 12:06 PM
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    Not positive but I don't think they will fit. The body is so much shorter on the 1st gen.
  10. Mar 21, 2017 at 12:07 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Not at all. It's just that more people bitch about things that are broken than things that work right.
  11. Mar 21, 2017 at 12:07 PM
    airwhen
    Seattle, WA
    Too much to list!
    Yeah, that's the engineer in me leaking out. So just do everything the same minus the horizon tilt.
  12. Mar 21, 2017 at 12:10 PM
    Cativelense
    Nuno
    CT
    So, to make sure I follow...
    Measure how high the bottom of the headlight is from the ground. Subtract two inches from that, and mark that as the height on the wall (??).
    Then back up 25 FT and adjust the lights up or down so that the "cut off" is at the bottom, or the top of that?
    And I have to adjust both the drivers and passengers lights, correct?
    airwhen[QUOTED] and ChadsPride like this.
  13. Mar 21, 2017 at 12:20 PM
    UncommonLife
    UncommonLife Well-Known Member
    Alan
    Salida, CO
    2009 TRD Sport DCSB
    Got my camp table installed. Finally got to play with my pop rivet gun! Alaska here we comeIMG_3942.jpgIMG_3943.jpg
  14. Mar 21, 2017 at 12:21 PM
    airwhen
    Seattle, WA
    Too much to list!
    Two inches below align with the top part of the tape and the top part of the light horizon.
    If I recall correctly, I was at 38 inches at my light bottom. I marked 36 inches up on the wall and put the one inch thick tape top at 36, the bottom would be at 35 inches. Backed up and adjusted the horizon right at the top of the tape, right at 36 inches. For 99.9% of all cars, my light are below the rear windows, thus no shine in the car, however there are Miatas, and I light those mother}%£+S! like a Christmas tree.
  15. Mar 21, 2017 at 12:26 PM
    tacticaltaco85
    tacticaltaco85 Well-Known Member
    blake
    Dinwiddie va
    2008 TacomaTRD OR dcsb
    Replaced both lower control arms and alignment. Maybe I'll be able to start doing some stuff to it soon one I get all the maintenance out the way.
    gabbo2112, Kuntrykid and ChadsPride like this.
  16. Mar 21, 2017 at 12:34 PM
    Cativelense
    Nuno
    CT
    Gotcha. And you adjusted both lights, correct? Meaning the drivers side and the passenger side. And the "screw" to adjust that is on the back of the headlight housing, right?!
  17. Mar 21, 2017 at 12:52 PM
    kiahb12
    kiahb12 Well-Known Member
    Kiah
    Western North Carolina, attend WCU
    2007 Access Cab PreRunner
    Couple mods down, many mods to go
    Yeah buddy! You'll catch me on here more than you will see me studying. not sure if that's good or bad. Holler, We'll have to meet up sometime.
    trdsport6[QUOTED] and ChadsPride like this.
  18. Mar 21, 2017 at 1:11 PM
    kiahb12
    Kiah
    I think i will be in the market to replace mine soon as well due to rust, havent looked at them closley to see how bad they are but just glancing when iger into the truck, theres visible rust. the toyota frame recall replaced them too but from my understanding, they have canceled the recall and therefore i have to get my own LCA now. Toyota is "Revising" the recall :annoyed:
  19. Mar 21, 2017 at 1:14 PM
    kiahb12
    Kiah
    Question: My buddy has a 2012 with a 6" and says he has bad axel wrap and can't pull anything because of it. with a 3" on my truck (spacer in front and AAL's in the back) will I have this problem? I do a lot of hauling and do not wanna jeopardize my trucks capability of doing so.
  20. Mar 21, 2017 at 1:21 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    No, you'll be fine. More than likely your buddy has large blocks in the rear which exacerbates axle wrap. If you're doing an AAL, you'll be alright.
