  1. Mar 27, 2017 at 3:00 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    The 885's will provide around 2.5" of lift on a stock weight 05-15 4wd 4dr so if you are at the top notch setting on the 5100's that will be comparable. :)
  2. Mar 27, 2017 at 3:03 PM
    HeadStrong Off-Road
    Working on PM now. :)
    foxrcing07[QUOTED] likes this.
  3. Mar 27, 2017 at 3:13 PM
    ecgreen
    ecgreen overeducated redneck
    Sean
    2015 4x4 4-banger Access
    The girl knows here stuff!
  4. Mar 27, 2017 at 3:21 PM
    TRlPPlN
    TRlPPlN Pavement Cruiser
    Bay Area, CA South SF to be precise
    MGM DCSB 09 DC TRD Sport 4x4 - Family Hauler
    Get your priorities and time management worked out slacker!! TW>ALL
  5. Mar 27, 2017 at 3:22 PM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    hahaha I was thinking the exact same thing! :rofl:
    I was legit checking each post to see if it had been liked
  6. Mar 27, 2017 at 3:52 PM
    BravesRunner
    BravesRunner “Exploration is curiosity put into action”
    Adam
    SC
    2021 GMC Sierra 1500 Denali
    Grandpa steps//Tri-fold Tonneau bed cover
    Question about lift. I have two 5100s for the front and l was planning to set them @1.75. My question is if I wanted to go ahead and get a 3in lift all the way around without any rake what would I need? Thinking either Eibach or OME coils and maybe an AAL but aren't sure what size. Any help would be appreciated.
    Kuntrykid likes this.
  7. Mar 27, 2017 at 4:03 PM
    Zredwards
    Zredwards Well-Known Member
    Zach
    Ludowici GA
    2011 Toyota Tacoma Trd
    3 inch lift. 285/70
    20% percent all the way around(over factory) and 5% across the top.
  8. Mar 27, 2017 at 4:09 PM
    ERMB
    ERMB Well-Known Member
    2002 Land Cruiser
    Depends on what you plan to do with it. If your going wheeling you may want to replace rear Springs if you just want level an add a leaf or set will get you there. If your adding new front coils there's no need to set your bilstein above 0. The coil provides the lift based on the spring rate you choose.
    kyuss88 and BravesRunner[QUOTED] like this.
  9. Mar 27, 2017 at 4:13 PM
    BravesRunner
    Adam
    SC
    Don't do a whole lot of wheelin' honestly so I figure an AAL would be fine
  10. Mar 27, 2017 at 4:14 PM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    so your rear end sits 2'' higher then the front. if you lift your front up 3'' and dont want any rake then u have to lift the rear 1''. the recommended rear lift option would be an AAL. if you plan on adding coils then you can set your billys at 0. check this out to figure out what coils you need for your set up and go from there
    http://www.headstrongoffroad.com/uploads/1/1/8/4/11846658/lift_guide_shock_and_coil_selection.pdf
  11. Mar 27, 2017 at 4:16 PM
    BravesRunner
    Adam
    SC
    Bocsy44[QUOTED] likes this.
  12. Mar 27, 2017 at 4:22 PM
    88nitro305
    88nitro305 Well-Known Member
    Tom
    Vermont
    2012 white DCSB TRD OR
    I hate my Method center caps!! Always falling off when storing them..
  13. Mar 27, 2017 at 4:31 PM
    PNW BlueReaper
    PNW BlueReaper Slowly but Surely
    Aaron
    Kent, WA
    05 DCSB Indigo Ink Tacoma
    Recently broke the latch of my center console. Don't know how to fix it, because i lost the spring, haha.
    99TacoDriver likes this.
  14. Mar 27, 2017 at 4:39 PM
    Do58
    Do58 Well-Known Member
    2015 white tacoma limited
    Received my hood struts today.... bonus
  15. Mar 27, 2017 at 4:54 PM
    Naumoff42
    Naumoff42 Well-Known Member
    Ohio
    2015 TRD Offroad
    Greased my U-joints today at 20,000
    Also installed a little badge
  16. Mar 27, 2017 at 5:00 PM
    Sasquatchtaco
    Sasquatchtaco Sasquatch Taco
    Catskills NYS
    09 MGM DCSB 4X4 TRD
    Too many to list.
    Coincidentally a friend of mine has someone that can spray paint the cap for 125.00 I just have to prep it for him. I just bought the paint for it.
    Who wants to buy four cans of dupli-Color BTY1619 Magnetic Gray Metallic :D
    airwhen[QUOTED] likes this.
  17. Mar 27, 2017 at 5:14 PM
    Fish12South
    Fish12South Well-Known Member
    Steven
    Ruther Glen, VA
    2008 Indigo Ink AC SR5 6 Speed V6
    Not Enough.
    That doesn't bother me as much as the fact that they stuck out to almost the lip of the wheel. And they're ugly as sin on top of that. I ordered those TRD caps from Amazon, unbolted the plastic piece from the metal, and they actually snapped in. Used the wire ring on the outside of the tabs to keep them from pulling back out. Works pretty well. I'll probably epoxy them when I get around to pulling the wheels off again to rotate them, but for now, they're just fine.
    88nitro305[QUOTED] likes this.
  18. Mar 27, 2017 at 5:16 PM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Love WV! Drive through Morgantown on the way to Teays Valley to visit my bro in law in Hurricane.
    You're right. My bad. Should've known better.
  19. Mar 27, 2017 at 5:17 PM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    Yeeeeeeeeeeeeeeeeessssssssssssssssssssssssssssssssssssssssssssssssss!
  20. Mar 27, 2017 at 5:29 PM
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR
