  1. Apr 8, 2017 at 1:20 PM
    fleckosaurus
    fleckosaurus Certified Toyota Enthusiast
    Brian
    Versailles, KY
    2024 Tundra
    Changed diff and transfer case fluids today!
    Found out that Royal Purple is actually purple.
    Also a question for you all. I accidentally used the wrong crush washers on the transfer case and rear diff drain plug. I didn't realize they were different until after I got done with everything. Does it matter?
    gabbo2112 and jmich2001 like this.
  2. Apr 8, 2017 at 1:21 PM
    orezona
    orezona title unspecified
    satan's skillet
    2006 TRD OR DCSB OMGWTFBBQ TL;DR
    WARRANTY VOIDED
    Went with the kidlings out to Bulldog Canyon and got "Taco" (their name for it) dirty-er.
    Also found that the external TPMS I have on the valve caps work awesome to deflate the tires, albeit slowly. Just unscrew them enough that they start letting air out and all 4 tires are deflating at once. Not nearly the hassle I thought they'd be. Definitely would need to take them off for any gnarly wheeling though. Would hate to bust one... but I'd know immediately because the alarm would go nuts.
    Kuntrykid and Soul Surfer like this.
  3. Apr 8, 2017 at 1:35 PM
    loaderman82
    loaderman82 Well-Known Member
    Dalton
    Flippin, AR
    2008 Off-Road
    I just used 1 1/2 pvc. Probably not the best material, but I think it will work fine. I don't plan on being too rough with it.
    Cativelense[QUOTED] likes this.
  4. Apr 8, 2017 at 1:37 PM
    A_Ninja_Racer
    A_Ninja_Racer Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    Yes me and a friend of mine did it together. He worked from the top of the truck and I worked underneath. I don't think we were at it for more than 2 hours. Having a second person to help get the alternator out and guided back in was a big help. Also if you have a harbor freight in your area go there and pick up one of those mechanics stethoscope. It was like 5 bucks and helped me narrow down where the wine was coming from. For me it was the alternator but I wanted to replace those pulleys while I had it apart.
    spilser[QUOTED] likes this.
  5. Apr 8, 2017 at 1:38 PM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Cool. Looks like it came out really well.
  6. Apr 8, 2017 at 1:42 PM
    loaderman82
    Dalton
    Flippin, AR
    2008 Off-Road
    Works perfect. Made it to where it will flip just like the factory ones.
  7. Apr 8, 2017 at 1:51 PM
    Kanebutler13
    Kanebutler13 Well-Known Member
    Kane
    Malibu, California
    2007 Silver Tacoma TRD
    ARB Bumper ARB Snorkel 8000lb Warn Winch Demello R. Bumper ARB OME 2" suspension Bully Dog GT Gas Tuner TEK P2 Brake Controller Heavy Duty Brake Rotors Rock Sliders Grey Man Tactical Panels
    After I stacked off-road adventures between traveling for work, the truck had been neglected, cleaned and scrubbed inside and out, waxed the million new scratches from AZ and have been cleaning the engine bay today.
    Yesterday moved up to 33" BFG KO2's on 16" Methods, loving them
    Kuntrykid, the glen, kyuss88 and 6 others like this.
  8. Apr 8, 2017 at 1:56 PM
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    15 TRD Sport (DCLB-BRM) - 88 ///M3 (Zinnoberrot)
    OME 887/Dakars/NV305s/33" Duratracs/+
    Had about 2 hrs to tinker around.
    -made custom .40 cal valve stem caps
    -washed the NVs
    -washed the weathertech liners (no photo)
    -test cut TRD caps for the NV cap mod (more to come later)
    20170408_145130.jpg 20170408_164430.jpg 20170408_150754.jpg 20170408_150805.jpg 20170408_150802.jpg
    Kuntrykid, the glen, Jack0928 and 7 others like this.
  9. Apr 8, 2017 at 1:57 PM
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
  10. Apr 8, 2017 at 1:59 PM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Added 50+ HP, just saying.CBOY808 he da manIMG_0558.jpgIMG_0560.jpgIMG_0559.jpg
    Kuntrykid, kyuss88, JayRolla and 12 others like this.
  11. Apr 8, 2017 at 2:16 PM
    Garfish307
    Garfish307 Well-Known Member
    Katy, TX
    2014 Tacoma 4x4 Texas Edition
    Flux Capacitor
    Solid Brass -
  12. Apr 8, 2017 at 2:17 PM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    I like the subtle carbon fiber part. I know taking the console off is easy,but does that piece easily unsnap?
  13. Apr 8, 2017 at 2:21 PM
    beetlevegas
    beetlevegas You are no Vader. You are just a child in a mask!
    JP
    Las Vegas NV
    2011 silver Tacoma TRD 6 Speed double cab
    stuff
    so it is not bolted down? Looks like it is just sitting there. Thats really cool and inventive.
  14. Apr 8, 2017 at 2:40 PM
    Cativelense
    Nuno
    CT
    If you're talking about the shifter bezel, yes. Just pull up by grabbing it and it comes right off.
  15. Apr 8, 2017 at 2:49 PM
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    Want!
    Where did you get that?
  16. Apr 8, 2017 at 2:49 PM
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
    Now I'm talking about that center piece that he wrapped
  17. Apr 8, 2017 at 2:53 PM
    BravesRunner
    BravesRunner “Exploration is curiosity put into action”
    Adam
    SC
    2021 GMC Sierra 1500 Denali
    Grandpa steps//Tri-fold Tonneau bed cover
    Gave her a bath today and got my bed rack delivered and put on so now it's time to go kayaking!
    Kuntrykid, kyuss88, JayRolla and 7 others like this.
  18. Apr 8, 2017 at 2:54 PM
    dino41
    dino41 Well-Known Member
    San Diego, California
    2015 Sky Silver Crew Cab V6 SR5 Prerunner
    Went to my local Performance Bike Shop for a new bike chain and found a half price sale on all the Transit Xpress bike mount accessories. $40 for all 4 item, 2 wheel mounts and 2 bike mounts. Got home and rummaged through my aluminum scrap bin and found the perfect 1" x 1" x 1/8" 6061 aluminum square tube since these are made for that size tube. A little design thought in how I was going to put it all together, a little cutting, drilling, tapping and two hours later I came up with this. I wanted it to be easy removal so I incorporated the adjustable rail mounts and even had an extra cam lock (blue lever) left over from a router table clamp system and put that to use.
    Kuntrykid, jeff b, gabbo2112 and 3 others like this.
  19. Apr 8, 2017 at 2:57 PM
    TA 4
    TA 4 Well-Known Member
    Ontario, Canada
    2015 SSM Taco access 4x4 2.7
    Cruisin offroad bumper, RCI front skid, Bakflip Tonneau Cover, Westin Running Boards, door molding, Blazer Led lights, Bed Lights, DIY Bed/rear cab mats, 3M Clear Bra (Hood and Fenders), Husky front floor mats, re diff relocated, Coverking seat covers
    Preventative maintenance day on the taco. Extended the front diif and ADD breather away from the wheel well. Where toyota has the breathers is right where all the dirt gets flung. Had to slip a piece of 1/4in hose over the small breather hose to extend it. Also covered up the cabin air filter opening with some aluminum mesh and some caulking to prevent future mice problems. Mot the prettiest job but does the trick, just have to drive with the windows down till the caulking cures hahaha
  20. Apr 8, 2017 at 3:06 PM
    Silverspool
    Silverspool Come at me Bro!
    Frank
    DFW
    18T4RORP 17GT350
    Anyone seen my wallet?
    If you wanna know what thatll look like... i drilled mine so i could reverse the mod.
