  1. Apr 29, 2017 at 9:31 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    No problem. I have an easy solution for that!
    You can simply add what this guy wants to remove. :rolleyes: https://www.tacomaworld.com/threads/cant-get-this-sticker-off.258047/
    gabbo2112 likes this.
  2. Apr 29, 2017 at 9:39 PM
    scott96929
    scott96929 IRoniK
    Scott
    Phoenix, Az
    2007 Tocoma PreRunner (Ironik)
    All Pro Front Plate Bumper, MaxTrac 4" Spindles, Light Racing Upper Control Arms, BOSS Leaf Springs, Toytec Adjustable Coilovers, Fox 2.0 Rear shocks, 17" Raceline Assault Wheels, Toyo RT 285 70R17, AFE Stg II Cold Air Intake, Prinsu Cabrack, Prinsu Bedrack, 10K Kensun HID Headlights, Avec 20" Optic LED Light Bar, Avec LED Fog Lights, Heretic 30" Combo LED Light Bar, Viper Max 12000 Winch, Quick Fist, Tepui Kukeman Ruggerized RTT, Smittybilt Awning, Relentless Fab Tailgate Reinforcement, Anti-Dark Hood Lighting Kit, Fog Lights Anytime Mod, Rear Differential Breather Mod, P&L Tailgate Lock, KMFAB Rock Sliders, KMFAB Rock Light Kit, KMFAB Bed Light Kit, KMFAB RTT Light Kit, KMFAB 12 VDC Outlet Kit,Optima Dual Battery, SSCS Kit, Switch Pro 8100 Kit, Cali Raised Ditch Light Kit
    https://www.amazon.com/dp/B01HP5UZIO/_encoding=UTF8?coliid=I35RMR7BKZ0AV5&colid=FC3PYQJCG0WN
  3. Apr 29, 2017 at 9:40 PM
    Silverspool
    Silverspool Come at me Bro!
    Frank
    DFW
    18T4RORP 17GT350
    Anyone seen my wallet?
    F103, if you want the nipple to connect a hose, F103N
  4. Apr 29, 2017 at 10:14 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    got my locking hubs installed :D
    also welded up some spindle gussets.
  5. Apr 29, 2017 at 10:25 PM
    airwhen
    airwhen "You done messed up A.A.Ron!!!!
    Seattle, WA
    2015 TRD Sport DCSB 4X4
    Too much to list!
    Boo f**king Hoo to all of you. My 2015 has 21K on it and I have two other daily drivers and another Tacoma. Plus my commute is going down one flight of stairs.
  6. Apr 29, 2017 at 10:45 PM
    Grumpy
    Grumpy My 1st Tacoma
    Maurice
    Oahu, Hawaii
    14/DCLB/V6/4x4/SR5
    17" Method Grid Titanium rims w/ Pro Comp Sport A/T 265/70/17 tires, Mobtown Offroad ribbed Tailgate skin, installed LED lights in painted rear bumper black, faux TRD grill, color match grill surround. LEDs in map, license plate, center console, and dome lights. Anytime driving lite mod, debadged, vent visors, AA Maglite mounted under center console armrest. Antitheft hose clamp on tailgate, LED bed lighting kit. LED spot lights in lower front bumper. Weathertech floor mats. Painted various interior parts black, homemade 7 pin relocation bracket, Valet under door LEDS, CMC, SPC UCA, Bilstein 5100, OME 885, Headstrong AAL. Pop&Lock.
    @paranoid56 Do you have the part numbers or location you got those locking hubs from?
  7. Apr 29, 2017 at 11:09 PM
    airwhen
    Seattle, WA
    Too much to list!
    Damn, $8 is barely half of the minimum wage around here, but even at $15 an hour, you can barely get a one bedroom apartment. We own a duplex next door that has 2 two bed, two baths. We easily get $3k per unit.
  8. Apr 29, 2017 at 11:52 PM
    09BlueBeast
    09BlueBeast Well-Known Member
    Cody
    Denver
    09 Speedway Blue TRD Sport 4x4
    What all did u have to do to get it to fit?
    kgarrett11 and fleckosaurus like this.
  9. Apr 30, 2017 at 3:38 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Gains, if any, won't be significant.
  10. Apr 30, 2017 at 3:38 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Heading to my first "Cars and Coffee" in a minute.
  11. Apr 30, 2017 at 4:06 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Cleaned up the wiring for the compressor, me and my buddy rushed it and used *gasp* white zip ties. Redone with black for amazingness.
    Modified my Slee off road ARB twin mount, so that it will allow me to run an airline to the back of the truck.
    Installed the Slee mount after modification.
    Ran an airline from the compressor to the rear bed box, same spot my diff breather is mounted.
    Running that airline, WITHOUT cleaning the underside of the truck 1st was not the right idea. My eyes ate like 3 lbs of dirt. Even with a full face mask on. :crapstorm:
    siundon, ChadsPride, PaulK and 10 others like this.
  12. Apr 30, 2017 at 4:09 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Swapped stock 3.73 gears for Motive Gear 4.10's. With 33"'s, just a tic lower gearing than stock with stock rubber. Hopefully a decent compromise when the day comes I put 35's on 'er. All checks OK. 125 mile road test! Probably 30 miles of that on dirt/gravel roads in 4wd to check front end. Low range and locker AOK!
  13. Apr 30, 2017 at 4:21 AM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Thing is still apart waiting for a bolt to come in.
    Replaced the stock rear leafs, added a pro comp AAL this time to try, replaced the U bolts, replaced the 5100 rears with new ones, changed the rear diff fluid using 75w-90 Amsoil, changed the winters with summers, painted all the parts with black rust paint and a bunch of clear coat. Then added a bunch of fluid film to the parts to keep them from rusting
  14. Apr 30, 2017 at 6:13 AM
    ecotecin
    ecotecin Wait, whut........
    WV
    2014 DCSB sold (2020 Chevy Silverado Crew Cab)
    I bet some joy dishwashing liquid would do the trick, just wash the area thouroughly with it, rinse it good, then wax it really good. Joy is a degreaser, but is also great for contaminent issue, sticker residue, grease or oil thrown up on a vehicle, but its important to wax it afterwards.
    ChadsPride likes this.
  15. Apr 30, 2017 at 6:13 AM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Finished installing my SCS F5 17x9 with Toyo M/T 35x12.5R17
    Had to hammer the pinch weld back and cut more of the cab mount. Also trimmed the fenders and bedsides
    Smtaco89, kyuss88, Tacoturtle and 8 others like this.
  16. Apr 30, 2017 at 6:27 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    I'm editing the video now, but here is a quick tease for what I saw today at Cars & Coffee:
  17. Apr 30, 2017 at 6:31 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    That ain't mud. o_O
  18. Apr 30, 2017 at 6:45 AM
    Rogelio22
    Rogelio22 Get him a body bag! [TTC #030]
    Roger
    Sioux City, IA
    2018 Chevy Silverado 1500 Z71 Texas Edition
    Blank slate, ready to start
    Swapped out the plain Toyota emblem with a sweet Model T emblem. Also last look of truck before leveling kit goes in this week
    kyuss88, siundon, Tacoturtle and 5 others like this.
  19. Apr 30, 2017 at 6:46 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Modified the seat bracket, then bolted to a new custom racing seat bracket. Had to transfer over stock seat harness/seatbelt socket/rail position sensor to FRS seat, as well as stock airbag connector. And fabricate a new seat position sensor rail out of some steel sheet.
  20. Apr 30, 2017 at 8:22 AM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
