  1. Apr 30, 2017 at 5:01 PM
    Velociraptor4x4
    Velociraptor4x4 Well-Known Member
    Canton, Ohio
    2015 DCSB OR
    Tested out the new 884's while checking on the property for the first time this year. Trails need cleaned up pretty bad. Might've had to drive over a couple downed trees that were in my way :rofl:
    Overall no sway bar and 884's on 5100's makes a pretty nice ride. IMG_0754.jpg
    scott96929 and gabbo2112 like this.
  2. Apr 30, 2017 at 5:06 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Enjoy the dakars!
  3. Apr 30, 2017 at 5:12 PM
    lispnik
    lispnik Active Member
    Austin, TX
    2012 Black Tacoma TRD manual
    Located leak. What's up with adding leak sealer to leak detection refrigerant tho? It probably took way longer to find the leak because of the sealer.
    Next step convince Firestone to evacuate the system for me so I can put in new hose.
    llamasmurf and scott96929 like this.
  4. Apr 30, 2017 at 5:20 PM
    Abragus
    Abragus Well-Known Member
    Adam
    Suffolk, VA
    I made this.
    ChadsPride and gabbo2112 like this.
  5. Apr 30, 2017 at 5:22 PM
    gabbo2112
    gabbo2112 Well-Known Member
    New York
    2020 TRD Off Road
    Thanks man so far so good, Ride is great!
  6. Apr 30, 2017 at 5:31 PM
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    I don't get it
    Jack0928 and ChadsPride like this.
  7. Apr 30, 2017 at 5:33 PM
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    Looks good. Is the front leveled? Can't tell.
    ChadsPride likes this.
  8. Apr 30, 2017 at 5:36 PM
    Abragus
    Adam
    Suffolk, VA
    Got tired of chasing leaks from the cap so I figured I'd make a platform to keep gear off the bed. Cutouts on the side are for gas cans.
  9. Apr 30, 2017 at 5:37 PM
    gabbo2112
    New York
    2020 TRD Off Road
    Thanks! It is billies set at 1.75, looks a little high in the back.
    ChadsPride and Cativelense like this.
  10. Apr 30, 2017 at 5:39 PM
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    Ah! Okay. Are you going to fasten it in a more permanent way or are tie downs there to stay?
    It'd look cooler if you painted the visible parts of the wood black too.
  11. Apr 30, 2017 at 5:41 PM
    mabepossibly
    Andrew
    Albany, NY
    2021 TRD OR Manual
    I had that issue in my older Ranger when it had a cap. The 2" clearance from the lumber is a lot of lost space. I used hollow click together garage flooring and trimmed it to fit he bed profile with tin snips. The bed drained in every direction, so it's not like there was ever ponding water. It just needed a little void space to pass through.
    Edit:
    this stuff:
    https://m.lowes.com/pd/Gladiator-4-Piece-12-in-x-12-in-Charcoal-Garage-Floor-Tile/3117479
  12. Apr 30, 2017 at 5:41 PM
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR/W-UpGrade Package.
    I like the look of the slight rake. :thumbsup:
    ChadsPride and mabepossibly like this.
  13. Apr 30, 2017 at 5:43 PM
    mabepossibly
    Andrew
    Albany, NY
    2021 TRD OR Manual
    It looks more or less like the factory rake.
    ChadsPride and Soul Surfer like this.
  14. Apr 30, 2017 at 5:44 PM
    gabbo2112
    New York
    2020 TRD Off Road
    Thanks man I do to!
  15. Apr 30, 2017 at 5:46 PM
    gabbo2112
    New York
    2020 TRD Off Road
    It does got a little more lift then I expected, I kept the stock springs with the billies, maybe I'll upgrade to the OME 884's in the next few months maybe that will help bring the front back up a bit...
  16. Apr 30, 2017 at 5:51 PM
    mabepossibly
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Don't judge until you have put some miles on them. New springs always come down a little as they break in.
  17. Apr 30, 2017 at 5:53 PM
    gabbo2112
    New York
    2020 TRD Off Road
    Ok I'll give them a few weeks to settle.
    Soul Surfer and ChadsPride like this.
  18. Apr 30, 2017 at 6:00 PM
    Abragus
    Adam
    Suffolk, VA
    Definitely, I consider this "Platform Version 2, Mod 1." Trying to figure out if I want to add the rubber matting to the bottom of the 2x4's or if I'll just paint it. Also going to think a bit more about how I want to mount it more permanently.
    Definitely agree on the lost space. I'd like to eventually try and find trays that I can slide underneath but that's not much room for gear. I'm getting leaks from each forward corner - did you leave room for water to drain down the sides?
  19. Apr 30, 2017 at 6:00 PM
    the glen
    the glen Well-Known Member
    Glen
    penisula
    2012 TRD Off-Road 6SP manual spruce mica Taco
    Icon 2.5 remote res. Coilovers front, icon 2.5 rem res shocks rear, deavers 10 pack leafspring rear. Light racing ouca. Cmc, avid light bar, bamf sliders weld on, grillcraft mx grill, bamf light bracket with lightforce 170's. Uws toolbox, oem bed mat, weathertechs f/r, hella airhorns, trd antenna, talegate mod, Clifford alarm, budbuilt full skid plate set. All pro rear bumper. Superbumps bumpstops. Bulldog lighting reverse led lights in bumper. Trd short throw shifter. Cobra cb, firestick 4' ant. Icon LCA skids. Bamf rear dif skid. Hi lift x-treme mounted with relentless rail mounts in bed. Full size method/bfg in bed. Crown performance ss/Kevlar brake lines. Power tank mounted in bed. Rigid d2s mounted on relentless hood mounts. H3R quick release fire extinguisher mounted to driver's seat. Redline hood struts.
  20. Apr 30, 2017 at 6:00 PM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    My OME 887s dropped an inch over a few weeks.
