  1. May 15, 2017 at 7:39 AM
    smcgill
    smcgill Well-Known Member
    Sean
    South Easton Mass. not enough time in Cocagne NB
    Camry and Ram 1500 with a "HEMI "
    Love the Red Solo cup Mod!
  2. May 15, 2017 at 7:59 AM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    Save 15% on Huskey Products!
    Code: SAVE15
  3. May 15, 2017 at 8:00 AM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
  4. May 15, 2017 at 8:01 AM
    LastShot457
    LastShot457 Well-Known Member
    Aaron
    Ohio
    2012 Magnetic Gun Metallic V6 TRD 4x4
    Window Tint (35% front, 15% Rear), K&N Short Ram Intake, Bushwacker Fender Flares, Fab Four Vengeance Front Bumper, 20" BlackOak Light Bar
    I'm just spraying it on.
  5. May 15, 2017 at 8:17 AM
    Doughnut Spaghetti
    Doughnut Spaghetti Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    5100 installed, leveled, new rims and tires, no rub, and an alignment. Finally done.....for now!
  6. May 15, 2017 at 8:22 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
  7. May 15, 2017 at 8:39 AM
    Z7Xtreme
    Z7Xtreme Always Overestimated
    Chuck
    In a tree somewhere
    2015 trd Black Ops edition
    884's and 5100's with HS 1/4" taco lean spacer,1 inch toytec block and 5100's,SPC uca's,SCS Ray 10 wheels,265/75/16 Falken Wildpeak AT3,oem running boards,oem skid plate,WeatherTech floor liners,WeatherTech window deflectors,Access tonneau cover,WeatherTech stone and bug shield ,BPF tow hook,oem bed mat,pro grill,tacomabeast headlights,cali raised ditch brackets with Rigid lights,Rough country 30” lightbar on Rigid brackets RCI bedrack, KC rear lights,maxtrax,dual rotopax.
    IMG_0183.jpg Got my lift today...Just need to decide on tires now.
  8. May 15, 2017 at 8:55 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Oh hell yes! You gonna do the work yourself? Make sure you check out your alignment cams and bolts. Theyre very prone to seizing. If you havent get them out and grease them up sooner than later.
    My front LCA cams were both seized, but I had enough wiggle room with the rears to get them into alignment spec. Will be replacing my bushings and cams down the road. Bushings will be Energy Suspension poly. Haven't decided on cams. Would love to see someone produce some stainless steel options. Sick of dealing with the rust and it doesn't take much for them to start seizing.
  9. May 15, 2017 at 9:18 AM
    Z7Xtreme
    Chuck
    In a tree somewhere
    I'm gonna leave it to a professional:/ Thank you for the tips tho,hopefully it goes smooth..
    gabbo2112, bigfoote13 and ChadsPride like this.
  10. May 15, 2017 at 9:21 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Tell them to check those cams them. If they're already free, have them take them out and put a liberal coat of anti-seize on them. You'll have to get an alignment anyway, so it's not much more work, to have them serviced.
    Z7Xtreme[QUOTED] and ChadsPride like this.
  11. May 15, 2017 at 9:37 AM
    bikeordie1
    bikeordie1 Well-Known Member
    Jeremy
    Bellingham, WA
    '11 Tacoma TRD-OR DCSB AUTO
    5100's in back Braided extended brake lines Pioneer DBL-DIN w/backup cam K&N intake OEM bed mat Window tint Debagged Custom fab 5-bike shuttle rack
    Which wheels ya got there?
    gabbo2112 and ChadsPride like this.
  12. May 15, 2017 at 9:45 AM
    Jack0928
    Jack0928 Kind of a Well-Known Member
    Jack
    Huntington Beach, CA
    2013 MGM DCSB 4x4
    IG: Jacksoverland
    What was the process like?
    ChadsPride and bikeordie1 like this.
  13. May 15, 2017 at 9:47 AM
    bikeordie1
    Jeremy
    Bellingham, WA
    Yes i'm interested in the tight spots like in the door jams and cracks. How does that work with the wrap?
    Jack0928[QUOTED] and ChadsPride like this.
  14. May 15, 2017 at 10:10 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    KMC XD301 paired with Falken Wildpeak A/T tires.
  15. May 15, 2017 at 10:47 AM
    bikeordie1
    Jeremy
    Bellingham, WA
    To further pry into your setup... i assume 265/75 r16? any chance you'd have a pic down the side to show how far this is sticking out? I REALLY like the look man!
  16. May 15, 2017 at 10:54 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Tires are 265 70 17. I believe the rims have -6mm offset.
  17. May 15, 2017 at 10:58 AM
    SliMbo4.0
    SliMbo4.0 Well-Known Member
    Rick
    Colorado Front Range
    07 Tacoma DCSB TRD offroad
    BP51, BAMF hangers, BruteForce HC, SCS, Vagabond Drifter
    I had the e-brake engage on me one day while I was backing out of a parking spot so it had to come apart this past weekend. Ended up replacing the driver side rear drum cylinder, along with all rest of the crap in there while I was at it. Also bled all the brakes.
  18. May 15, 2017 at 10:58 AM
    bikeordie1
    Jeremy
    Bellingham, WA
    Ok so these are the 17x8.5 rims then. I was wondering about that rim width, quite a bit more than the stock 7". looks great though
    gabbo2112, Kuntrykid and ChadsPride like this.
  19. May 15, 2017 at 11:00 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Indeed.
    Thanks, I'm pretty happy with them. Looked at a ton of rims before I decided on these.
  20. May 15, 2017 at 11:52 AM
    Lou Slink
    Lou Slink I like daags...
    Catskill, NY
    2013 TRD OR DCSB
    OME 886's, Total Chaos UCA's, Dakar's, BFG KO2's on Method Race Mesh Wheels, Bunch of All-Pro Goodies, Warn Zeon 10S Winch
    I'm digging those headlights! How's the light output?
