  1. May 28, 2017 at 2:24 PM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    I accidentally made it to ardbeg trail south....
    Ironium, kyuss88, llamasmurf and 5 others like this.
  2. May 28, 2017 at 2:25 PM
    CNORRIS13
    CNORRIS13 Well-Known Member
    Corey
    Oak Harbor, WA
    2015 Super White Tacoma base 4x4
    Doug Thorley header, Magnaflow exhaust, K&N air filter, and more to come.
    IMG_4194.jpg I finally got around to installing my @Mobtown Offroad tailgate plate and cap
  3. May 28, 2017 at 2:33 PM
    shanalan
    shanalan Well-Known Member
    Apollo Beach, FL
    '13 MGM DCLB PR
    Bilstein 5100's all around, front@1.75" BFG Rugged Trail 265/75/16 Blacked out badges Anytime fogs UNI filter mod Redline Quicklift Hood Struts
    D-rings done...
    siundon, gabbo2112, IronPeak and 2 others like this.
  4. May 28, 2017 at 2:33 PM
    Kuntrykid
    Kuntrykid Tacoholics R Us
    Jon
    Sharpsburg, MD
    2015 tacoma 5spd access cab 4x4 red
    https://www.tacomaworld.com/threads/kuntykid-builds-a-taco.406341/
    Got one my self & love it! Got that flat so I can put plastic on top.
    gabbo2112 and ChadsPride like this.
  5. May 28, 2017 at 2:36 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Ain't they GREAT??
    gabbo2112, ChadsPride and Kuntrykid like this.
  6. May 28, 2017 at 2:38 PM
    Kuntrykid
    Jon
    Sharpsburg, MD
    Got the tail gate cap but thinking voodoo or something else just cuz of the overhang
  7. May 28, 2017 at 3:10 PM
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    15 TRD Sport (DCLB-BRM) - 88 ///M3 (Zinnoberrot)
    OME 887/Dakars/NV305s/33" Duratracs/+
    I had to muster up a lot of courage to cut them after dropping $800+ with paint job
  8. May 28, 2017 at 3:24 PM
    Kuntrykid
    Jon
    Sharpsburg, MD
    Did I miss something? Paintjob?
  9. May 28, 2017 at 3:27 PM
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    Between the Bushwacker and painting them I am over $800 into them and then had to cut/trim the flares to clear my 285s with LR UCAs adjusted to the max
    ChadsPride likes this.
  10. May 28, 2017 at 3:28 PM
    airwhen
    airwhen "You done messed up A.A.Ron!!!!
    Seattle, WA
    2015 TRD Sport DCSB 4X4
    Too much to list!
    My buddy has a green 99' with a 5-speed and a TRD supercharger. VERY fun truck!
  11. May 28, 2017 at 3:29 PM
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    Added some "color" to my beat up bedmat
    Grumpy, llamasmurf, gabbo2112 and 6 others like this.
  12. May 28, 2017 at 3:40 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Same here, minus the supercharger. This thing is a BEAST. Only paid $1000 for it too and he's now up to almost 350k miles.
    13403952_3255622148091_13868172929903885_9fbe166a0308e42ddaea89c58d2b96c35c221c2b.jpg
    14352334_1440247942671530_12144470255464_ce6108d75dcaaa2b48ade1f42bffc36c0d810d8d.jpg
  13. May 28, 2017 at 3:41 PM
    Sasquatchtaco
    Sasquatchtaco Sasquatch Taco
    Catskills NYS
    09 MGM DCSB 4X4 TRD
    Too many to list.
    exo fishing rod.. no way in hell I'm putting fishing rods inside the truck again.
    Now I just have to get 2 -2in Velcro straps to secure them properly. Although they're pretty tight as they are.
  14. May 28, 2017 at 3:43 PM
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    33.9269893 -118.0185768
    2012 DCLB 4x4 Trd Sport
    Shortened flowmaster exhaust with a turn down pipe, under cowl intake, throttle body spacer, train horn, underhood led lights, hood struts, dual 27f yellow tops. Led ditch lights, led front roof light bar, led fogs and headlights, behind grill mounted piaa dual color driving lights. Aux fuse and relay panel. Pro comp skid plate, bilstein 5100 leveling shocks on a 2in. lift, b110 rear 5100, add a leaf, front superbumps, light racing jounce rear bumpstops, sway bar relocation, brake line bracket extension, driveline carrier bearing drop, front diff drop, on board air compressor, 10 gal pump driven fresh water tank, cb radio, pioneer 4200 hu, infinity reference component front and component rear speakers powered by rockford fosgate 4 channel, jl audio 10TW3-D4 sub powered by kx800.1 amplifier. Big three upgrade, capacitor. Full cab sound deadening and thermal insulation. Led interior including added footwell, courtesy, cupholder, center console, and glovebox lighting, rock lights, bed lights, ring gear armor, under bed ammo can storage, pistol safe, body armor sliders, roof rack, hilift, 285/70 17 nitto rodge grapplers on american racing teflon atx, tailgate strut, and tailgate lock, retrofit projector headlights(home built), rgb halos inside turbine shrouds, black out surround, black chrome reflector and shroud, white halo outside shroud, white led drl, rgb behind grill on rf control. Mods followed from a TW thread: Anytime fogs Anytime rear view camera Anytime 400w inverter Alternating blinker/running lights 110v center console outlet ABS kill switch Engine kill switch (magnetic) 12volt bed socket Rear diff breather relocation Led bed lights Cargo net anchors Grid it center console top Grid it sun visor Locking center console Instrument cluster led swap Map lights on with dome Cigarette lighter add (shifter position) Dtrl kill switch Hilux lighted 4wd selector switch. Vios hvac knobs Hood scoop led bar
    Lol my wife thinks I'm the only one who says that
    twalchlii1 and gabbo2112 like this.
  15. May 28, 2017 at 3:45 PM
    Kuntrykid
    Jon
    Sharpsburg, MD
    Just as nice as a gun rack lol love it taco brother!
  16. May 28, 2017 at 3:47 PM
    Sasquatchtaco
    Catskills NYS
    09 MGM DCSB 4X4 TRD
    Too many to list.
    Some of us can't even see it.
    The gun rack will be done inside the cap :infantry::mudding:
    Kuntrykid[QUOTED] likes this.
  17. May 28, 2017 at 3:49 PM
    Kuntrykid
    Jon
    Sharpsburg, MD
    I don't know it's for outside I was think n inside given the pics!
    gabbo2112 likes this.
  18. May 28, 2017 at 3:53 PM
    jmd025
    jmd025 Well-Known Member
    Louisiana
    2010 TRD double cab 4x4
    Took the time today to install my TRD off-road progressive coils on a set of bilstein 4600s I got from @HeadStrong Off-Road , on my 4Runner . This combo rides really nice and lifts the front a shade over 2 inches IMG_1556.jpgIMG_1559.jpg
  19. May 28, 2017 at 3:56 PM
    stizo
    stizo Well-Known Member
    Roseville, CA
    15 DCSB TRD Sport 4x4
    Waxed that ass. After a couple coats of Maguire's ultimate paste. 20170528_155219.jpg
    De_c3nt, bigfoote13, kyuss88 and 6 others like this.
  20. May 28, 2017 at 3:59 PM
    BR Pipke
    BR Pipke Well-Known Member
    Drayton Valley Canada
    11 TRD short box 6speed std with 3" lift bilstein 5100 struts pro comp UCA AFE air cleaner and throttle spacer ultra rims 265-70/18 dual exhaust
    IMG_9110.jpg IMG_9109.jpg Just picked up some led driving lights and installed themIMG_9108.jpg
