  1. Jun 1, 2017 at 5:51 AM
    ensaladas
    ensaladas DarthT8er
    ‘23 Trail Edition
    nice rim choice ;)
    great truck.
    gabbo2112 and MO Tacoma[QUOTED] like this.
  2. Jun 1, 2017 at 7:17 AM
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    Yeah, these are my stock shocks before we even got to Teakettle Junction. Made it down Lippencott fully loaded and no rear shocks.
    ChadsPride, gabbo2112, LOLLY and 4 others like this.
  3. Jun 1, 2017 at 7:19 AM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    :eek::eek:
    ChadsPride and gabbo2112 like this.
  4. Jun 1, 2017 at 7:24 AM
    orezona
    orezona title unspecified
    satan's skillet
    2006 TRD OR DCSB OMGWTFBBQ TL;DR
    WARRANTY VOIDED
    :itllbuffout:
    /probably not
    ChadsPride, gabbo2112 and sapperguy like this.
  5. Jun 1, 2017 at 7:30 AM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    Holy mother of God.... :puke:
    ChadsPride, gabbo2112 and Casper66 like this.
  6. Jun 1, 2017 at 7:32 AM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    WHOA! Not a good look for the 4600 Billies. What did you upgrade to?
    ChadsPride likes this.
  7. Jun 1, 2017 at 7:42 AM
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    I know a guy at the local stealership and he had a set of 5100's that were takeoffs. Next month I'm going to redo the rear suspension, icons, allpro expo leafs, ubolt flip etc.
  8. Jun 1, 2017 at 7:49 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Hit a surprise pot hole at 45 mph this morning. 5100s took it like a champ.
  9. Jun 1, 2017 at 7:52 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Come around here and you'll be surprised to hit a smooth road!
  10. Jun 1, 2017 at 7:54 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    The surprise around here is to NOT find a pot hole.
  11. Jun 1, 2017 at 7:55 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Correct!
  12. Jun 1, 2017 at 8:12 AM
    Jack0928
    Jack0928 Kind of a Well-Known Member
    Jack
    Huntington Beach, CA
    2013 MGM DCSB 4x4
    IG: Jacksoverland
    I believe the name is a Gimbal, you can get a solid 3 axis gimbal that will change the quality 10 fold for around $300~
    Edit: Not sure what you film with but this is an affordable one.
    ChadsPride and LivinLoud like this.
  13. Jun 1, 2017 at 8:19 AM
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    Got my shipment from Retrofit Source! 2 days, perks of being close by.
    Now just need to decide how I'm going to paint. Should I paint the DRL reflector bowl or leave chrome? I don't want to severely limit the DRL output... I think I will VHT the side reflector.
    Otherwise everything black inside including shroud, or should shroud be red to match badges?
    I will have inner and outer RGB halos. So I think there will be a white ring around the end of the shroud. Also have RGB demon eyes.
  14. Jun 1, 2017 at 8:20 AM
    99TacoDriver
    South Louisiana
    freddy2923, stbear and Kuntrykid like this.
  15. Jun 1, 2017 at 8:24 AM
    txtaco87
    txtaco87 Budget Travel Hard AF
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    Those are pretty sweet! Good job:thumbsup:
  16. Jun 1, 2017 at 8:35 AM
    Fox2011PM
    Fox2011PM "The Mountains are calling"
    '13 DCSB 4X4 TRD OR
    ADS 2.5" CO's w/adj, ADS 2.5" Rears w/ piggybacks, Firestone air bags and 1.5" AAL, SCS SR8s, Tom Woods custom one piece drive shaft....more to come
    Just placed my order for ADS ext travel 2.5" w/ 700# coils and compression adjusters and ADS 2.5" ext travel piggyback reservoir rears. Read great things and spoke with Headstrong and they gave high marks. 100% Locally made in house in Tuscon, so I liked that part too. I'll post my results after install
    Kuntrykid likes this.
  17. Jun 1, 2017 at 8:36 AM
    G.T.
    G.T.
    CONUS
  18. Jun 1, 2017 at 9:23 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    wtf?
  19. Jun 1, 2017 at 9:34 AM
    Sasquatchtaco
    Sasquatchtaco Sasquatch Taco
    Catskills NYS
    09 MGM DCSB 4X4 TRD
    Too many to list.
    Ok I'll bite..what do you do for a living? Insurance?
    gabbo2112 and BassAckwards like this.
  20. Jun 1, 2017 at 9:48 AM
    tacoroy2390
    tacoroy2390 Active Member
    roy
    Costa Rica
    07blackDCSB4wd
    In process
    New battery, battery clamps , emblems, switch mirror , oil change, air filter,oil filter, spark plugs, windshield reservoir, new coolant, new floor mats, looking for a v6 engine cover, lower dash fusible cover. If u got any of this parts PM
    Thanks
    gabbo2112 and Cativelense like this.
