  1. Jun 16, 2017 at 11:53 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    looking good bro!
    gabbo2112 and ensaladas[QUOTED] like this.
  2. Jun 16, 2017 at 11:57 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    I had some on my last Tacoma, been meaning to get some for this one.
    I had the back driver side fall out driving down the highway when I cracked the window! :eek:
  3. Jun 16, 2017 at 11:58 AM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    If you can get to them with a Dremel you can cut a slot in them and use a screw driver to remove them. You can use a bolt extractor. You can drill them out, using a small drill bit and then stepping up gradually so you don't drill into the captive nut. Regardless of which method you choose, some heat will do wonders so if you have some MAPP gas heat the captive nut up before trying to remove what is left with the bolts.
    Edit: Sometimes a picture helps to understand what might work best.
  4. Jun 16, 2017 at 12:08 PM
    Lefkos
    Lefkos Well-Known Member
    Winston
    Las Vegas
    PreRunner
    Thanks man. Yeah I was looking at different variations and a candy blue came up. It's crazy how much it pops
    ChadsPride likes this.
  5. Jun 16, 2017 at 12:08 PM
    TacomaCody
    TacomaCody STOAA VIP Platinum Member
    Cody
    Iowa City, Iowa
    2012 Tacoma silver SR5 Off Road 4x4
    Body Armor 4x4 front bumper, running boards, cherry bomb vortex, 2" supreme suspension wheel spacers, Pro comp rock crawler wheels, 2017 off road full suspension, leer camper shell
    Possibly but that requires taking off my 200 lb bumper... Really trying to not do that haha. Thanks for the help!
  6. Jun 16, 2017 at 12:10 PM
    TacomaCody
    Cody
    Iowa City, Iowa
    Thanks! I'll try the dremel technique! And yeah I meant to snap a photo before I cleaned up.
  7. Jun 16, 2017 at 12:25 PM
    stbear
    stbear Well-Known Member
    SE PA
    2015 DCSB TRD Sport MGM
    Had AVS on my 2002 for 13 years. Stick on type. They lasted so well I went with AVS again for my 2015. Got the in channel this time. No problems. Great addition to the truck.
  8. Jun 16, 2017 at 12:49 PM
    la0d0g
    running for the hills
    For crawling not hauling
    As others said, drill it and tap it. Or weld on another piece of hardware to it.
  9. Jun 16, 2017 at 12:51 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Don't forget to bop it, pull it, twist it.
  10. Jun 16, 2017 at 1:04 PM
    JBecker
    JBecker Well-Known Member
    Virginia
    2015 AC SR 4X4 2.7 Manual
    I should have done this the week I got my truck. But, better late than never.
  11. Jun 16, 2017 at 1:09 PM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    The short bed has always fit whatever I've needed.
    Loaded it up last night with a bedroom set of furniture & drove across town.
    All those hours playing Tetris paid off...
  12. Jun 16, 2017 at 1:33 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    I had the same thing happen. I was able to get one of them out from the top by using vise grips. The other I had to drill out and use a tap to clean up the threads. If you go the drilling route my advice is to get the initial drill as close to center on the bolt as possible, and start smaller than the bit for the tap and work up to the right size. If you do it this way, you have a far better chance of getting the hole centered. I just had to use the tap to clean the old bolt threads out of the welded nut. After that I replaced all the skid plate bolts with 10.9 grade hardware (grade 8 metric equivalent).
  13. Jun 16, 2017 at 2:00 PM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    Thinking about putting these seat heaters under my wet okoles.. Figured this would be a nice to have in the winter, anyone done anything similar? Worried these wont make much of a difference since I dont have leather seats...
  14. Jun 16, 2017 at 2:04 PM
    ChadsPride
    I know @Unchained 5150 has some, not sure which ones.
  15. Jun 16, 2017 at 2:12 PM
    RyanL
    Indiana
    I've seen worse
  16. Jun 16, 2017 at 2:14 PM
    RyanL
    Indiana
    @ChadsPride the speed with which my post traveled across the internet, you hit like, then it traveled back and notified me is mind boggling. Bravo, sir.
  17. Jun 16, 2017 at 2:15 PM
    ChadsPride
    Haha!!! :transformer:
    RyanL[QUOTED] likes this.
  18. Jun 16, 2017 at 2:19 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    gabbo2112 and ChadsPride like this.
  19. Jun 16, 2017 at 2:21 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    sway bar delete kit :D
    gabbo2112, TacomaCody and ChadsPride like this.
  20. Jun 16, 2017 at 2:29 PM
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
