  1. Jul 17, 2017 at 9:17 AM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Would look cool with some of those flat Level 8 style caps!
    ChadsPride[QUOTED] likes this.
  2. Jul 17, 2017 at 9:19 AM
    themanbearpig012
    themanbearpig012 Well-Known Member
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    Fox 2.5 Factory Series Coil-Over Reservoir (Front) Fox 2.0 Performance Series IFP (Rear) Method "Mesh" 17x8.5|6x5.50|0/4.75" wheels
    GG lighting pods mounted on Rago Fabrication brackets. For dust light/work light/bedlight
    Casper66, kiahb12, 02YotaGuy and 6 others like this.
  3. Jul 17, 2017 at 9:20 AM
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    15 TRD Sport (DCLB-BRM) - 88 ///M3 (Zinnoberrot)
    OME 887/Dakars/NV305s/33" Duratracs/+
    After doing the anytime 12V at the cig lighter - Came out this morning and Taco fired up no problem.
    Jack0928 and ChadsPride like this.
  4. Jul 17, 2017 at 9:46 AM
    dino41
    dino41 Well-Known Member
    San Diego, California
    2015 Sky Silver Crew Cab V6 SR5 Prerunner
    I was asked by a member to do a little write up of how I installed my rear flush mount lights. So here is a quick summary. I tried finding a write up about this but could not find one on TW, so I apologize if this has already been done by another member.
    First off, these are the lights I purchased.
    https://www.amazon.com/Rough-Countr...=1500264194&sr=8-4&keywords=rough+country+led
    We don't really have much room on our bumper to work with as there are a lot of obstacles back there mainly brackets. Where you see the placement of my lights is pretty much the best location we have. The good thing about these Rough Country's is that they come with a template and wire harness. I used the Toyota style dash switch everyone is using off of Amazon. The harness wiring is not long enough so you will need to splice more wire (I used 14AWG from West Marine). I also went under the truck and ran the wire along the frame and not inside the cab like most guys do. That involves to much trim removal and if you follow the frame, there is plenty of nooks to run and hide the wire. The scary part is cutting into the bumper and making sure that both sides match dimension wise or they will be not look symmetrical. Measure and measure again, two or three times before cutting. My first side I used a 3" cutting disc with a pneumatic cutter. This took me a while and made my hole too small so I had to keep grinding until the back of the light fit in easily. The second hole went easier as I only used the cutting disc to open a small straight hole and finished it with a bi-metal blade and my Bosch jigsaw. Made for easier cut and better control of the cuts. Don't be afraid to make the hole a little bigger than the light housing as the flange will cover any imperfections, but I don't recommend more than 1/16". By the way, I drilled my mounting holes before making my cuts as the holes I feel are the most important thing that will determine how symmetrical your lights lay out. I strongly recommend a spring loaded center punch first and start with a small drill bit and finish with the proper size drill bit for the fasteners. If your bumper is chrome, it is a hard slippery surface and the drill bit will want to travel all over the place, hence the center punch and small bit.
    By the way, these light do not come with the hardware needed for mounting. I used eight 1/4-20 x 3/4" hex round head (allen wrench style) machine screws with flat washer and nylock nut in 316 stainless steel.
    https://www.mcmaster.com/#98164a213/=18j4zhz
    One thing I should also note is that our bumper is not a flat surface. When laying it out, try to go no greater than 3/4" from the bottom of the plastic bumper cover. Any greater than that and the bottom of the light flange may end up on the slight bend towards the lower part of the bumper. Regardless, the top and bottom of the light flange does not lay flat on the bumper and leaves about a 1/16" gap. I used strips of closed cell foam to fill those gaps and trimmed it with a razor blade. Below is a picture of my light and the bend I am talking about. I am not very learned with using those editing tools so sorry for the not so perfect lettering.
    Here is a good video that pretty much explains how to install.
    https://youtu.be/zxp8FV3WYn4
  5. Jul 17, 2017 at 10:17 AM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    You can post photobucket pics on here like normal. We made a workaround for their issue.
  6. Jul 17, 2017 at 11:10 AM
    Naumoff42
    Naumoff42 Well-Known Member
    Ohio
    2015 TRD Offroad
    Bought a hitch mounted shackle. Then I ripped a tree out! :benchpress::burnrubber:20170717_135706.jpg
    kiahb12, Tacoturtle, FIRE74 and 6 others like this.
  7. Jul 17, 2017 at 12:37 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Almost. Yours is straight. :D
  8. Jul 17, 2017 at 12:47 PM
    Jack0928
    Jack0928 Kind of a Well-Known Member
    Jack
    Huntington Beach, CA
    2013 MGM DCSB 4x4
    IG: Jacksoverland
    Anyone run a 1in body lift? If so any negative impacts on it? Wanting to get more clearance, even with my CMC I rub when flexedpretty badly.
    ChadsPride likes this.
  9. Jul 17, 2017 at 12:49 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Where are you rubbing? I did this on my truck and it helped a lot. Just unbolt the front of the liner, shove it back and ziptie it out of the way.
  10. Jul 17, 2017 at 12:54 PM
    Jack0928
    Jack
    2013 MGM DCSB 4x4
    IG: Jacksoverland
    That's a good idea for the front, I will have to do that. I also rub in the rear, almost ripped the flare off the other day when I was offroading and I feel like an inch would do wonders for that.
  11. Jul 17, 2017 at 12:56 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Ahhh, I gotcha. I rubbed on the rear too with my old set-up of 285s with some low backspaced wheels. Looked great, but damn. As far as the BL goes, people have done it, and I'd do it too if needed. Buy from a reputable place, and get the skirts to cover the gap. You'll be just fine.
  12. Jul 17, 2017 at 12:57 PM
    Jack0928
    Jack
    2013 MGM DCSB 4x4
    IG: Jacksoverland
    Any recommendations? I have never looked into it before
  13. Jul 17, 2017 at 12:59 PM
    Ted Yoder
    Ted Yoder Well that didn't work
    06 DCLB
    In Progress
    About to join the RTT gang...just waiting on the bedrack to show up
    :bananadead:
  14. Jul 17, 2017 at 1:00 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  15. Jul 17, 2017 at 1:04 PM
    Jack0928
    Jack
    2013 MGM DCSB 4x4
    IG: Jacksoverland
  16. Jul 17, 2017 at 1:06 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah, because the bumper mounts to the frame, so there will be an inch gap now. Some companies can tweak it for you though
    Jack0928[QUOTED] and ChadsPride like this.
  17. Jul 17, 2017 at 1:08 PM
    AdventurousTurtle
    AdventurousTurtle Well-Known Member
    2005 Tacoma TRD Off Road
    2 inch leveling kit
    Got body damage on my rear quarter panel... pics to come eventually but does anyone recommend (or better yet, not recommend) any particular rear bumper with quarter panel protection?
  18. Jul 17, 2017 at 1:10 PM
    Ted Yoder
    06 DCLB
    In Progress
    Cant go wrong with Brute Force Fabs high clearance bumper
  19. Jul 17, 2017 at 1:11 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    +1 for BFF
    Ted Yoder[QUOTED] likes this.
  20. Jul 17, 2017 at 1:14 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Where are you located? That plays a big factor for me personally, because you may be able to save on shipping which isn't cheap.
