  1. Aug 15, 2017 at 6:26 AM
    ensaladas
    ensaladas DarthT8er
    ‘23 Trail Edition
    Alignment done. Drives like a dream!
  2. Aug 15, 2017 at 6:27 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Looking good man! :thumbsup:
    gabbo2112 and ensaladas[QUOTED] like this.
  3. Aug 15, 2017 at 6:30 AM
    Slow Internet
    Slow Internet 56k Modem FTW!
    Slow...
    1992 Dial Up Modem...
    Wiper Blades
    I have a chance to buy those same headlights for a very nice price. Any insight on the light output or lack thereof with the tinted lenses??
  4. Aug 15, 2017 at 6:32 AM
    G.T.
    G.T.
    CONUS
    Check the alignment tabs to ensure that they are straight. If they are consider Welding a bead behind each will help it stay aligned, especially if you intend to take it off-road.
  5. Aug 15, 2017 at 6:33 AM
    ensaladas
    ensaladas DarthT8er
    ‘23 Trail Edition
    You sure they're the same? These were built by @kustom54lighting ... Lenses aren't tinted, the insides are painted black. They're very bright, good light output, clean cutoff line, good harnesses and ballasts.
    gabbo2112 and boogie3478 like this.
  6. Aug 15, 2017 at 6:34 AM
    ensaladas
    ensaladas DarthT8er
    ‘23 Trail Edition
    Thanks dude!
    Cativelense[QUOTED] likes this.
  7. Aug 15, 2017 at 6:40 AM
    ensaladas
    ensaladas DarthT8er
    ‘23 Trail Edition
    What's considered straight? Paint lines lined up? Only reason for alignment was because maxtracs went on this past weekend. I don't anticipate it getting knocked out anytime soon
  8. Aug 15, 2017 at 6:43 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
  9. Aug 15, 2017 at 6:45 AM
    ensaladas
    ensaladas DarthT8er
    ‘23 Trail Edition
    :rofl:
    boogie3478[QUOTED] likes this.
  10. Aug 15, 2017 at 6:52 AM
    G.T.
    G.T.
    CONUS
    Next time you get under it check to see if the tabs look bent or crooked. They should look straight in an up and down - vertical - position. Allot of force is applied to them and spirited driving can bend them. Lazy alignment shops have also been know to bend them to get the numbers they want so they can get the next customer on the rack.
    I have aftermarket cam tab gussets from Total Chaos Fab that reinforce that section considerably. They are huge by comparison, but the benefit is that I know they won't move.
  11. Aug 15, 2017 at 6:53 AM
    Slow Internet
    Slow...
    Wiper Blades
    Ok, maybe not the same...retros with black buckets and tinted lens
    ensaladas[QUOTED] likes this.
  12. Aug 15, 2017 at 7:10 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Someday, I'm hoping to get my TW sticker for the back window...
    gabbo2112 and toysrgood like this.
  13. Aug 15, 2017 at 7:15 AM
    ensaladas
    ensaladas DarthT8er
    ‘23 Trail Edition
    Thanks man, they look perfectly straight as of now. I may take your advice so they stay that way. :thumbsup:
    99TacoDriver and G.T.[QUOTED] like this.
  14. Aug 15, 2017 at 7:26 AM
    ensaladas
    ensaladas DarthT8er
    ‘23 Trail Edition
    I thought maybe mine was the only one that dripped all over the place... lol
    JD Hog likes this.
  15. Aug 15, 2017 at 7:52 AM
    trdsport6
    trdsport6 Well-Known Member
    West NC
    2015 Super White access cab TRD
    bilstein 5100 @2.5 front and rear Method NV BFG KO2 275/70/17
    Lacys alignment??
  16. Aug 15, 2017 at 7:55 AM
    ensaladas
    ensaladas DarthT8er
    ‘23 Trail Edition
    Yezzir. He got almost 5+ degrees of caster, which i initially questioned, but doesn't scrub cab mount or fender at all. May have to zip tie front black inner plastic up out of the way though. I've read that i'll get bump-steer with that much caster or fight me to straighten out, but it seemed fine. I guess time will tell.
    trdsport6[QUOTED] likes this.
  17. Aug 15, 2017 at 8:50 AM
    trdsport6
    West NC
    Heck yea!!! He got 4+ on mine and i havent had any trouble out of mine. Drove about 500 miles on it withing two days of getting it aligned and had no issues so you should be good!
  18. Aug 15, 2017 at 8:57 AM
    ensaladas
    ensaladas DarthT8er
    ‘23 Trail Edition
    Nice! Glad to hear it.
  19. Aug 15, 2017 at 9:53 AM
    hunter357mag
    hunter357mag Well-Known Member
    Bruce
    Minnesota
    2011 Black RC 4WD
    3" vertical ascension.....wheels.....tires......stuff
    Reworked my front bumper/hoop. Now it's a proper distance out from the grill.
  20. Aug 15, 2017 at 10:31 AM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    finished up my dual swing out. added the fuel can holder.
    awylie0321, Bebop, Karate1993 and 7 others like this.
