  1. Sep 2, 2017 at 7:46 PM
    saundern
    saundern Swerve for nothing
    Nick
    Simpsonville, SC
    2005 TRD Sport
    Might snag a set now since I know what they look like on the truck :thumbsup:
  2. Sep 2, 2017 at 10:12 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    How about just repainting instead? Or have them powder coated and mall certified.
  3. Sep 2, 2017 at 11:07 PM
    kitsym
    kitsym Well-Known Member
    Portland, OR
    2015 4x4 MGM DCSB TRD Sport
    23,323 miles.
    Changed my rear differential, front differential, and transfer case oil to Mobil 1 75w-90. Front and rear diff oil was very black with very minor/thin shavings on the magnets.
    Transfer case oil was honey-colored (expected).
    Also changed my air filter and cabin filter.
    Summary: change your differential oils earlier than the recommended 30,000 miles.
    Check out the DIYs on here by @chris4x4 and @boogie3478 to save yourself hundreds of dollars (close to $1,000 for all 3 services).
    The dark oils smell like death.
    Drink beer and have fun.
  4. Sep 3, 2017 at 4:17 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Finally finished the front bumper/winch install yesterday. Pelfreybilt aluminum with Warn VR10S winch. With aluminum bumper, winch with synthetic line, all 3 pieces of the skid plates are aluminum, a Pelfreybilt standard (steel) rear bumper and AllPro sliders, the rear didn't drop at all, and I lost 3/16" height in the front. The truck rides BETTER than it did prior with the slight bit of extra weight on the front. Rear is actually LIGHTER than it was since the heavy oem receiver hitch is now stored in the garage.
    Still a bit more work pending; Gotta wire the Baja Designs fogs now that the bumper is finished. I have OME 887 coils on the work bench to replace the 885's currently on the truck, and there's still a bit to do before I can call the t-case skid done. "Quick Fist" tool mounts should be here Tuesday. I'll be mounting a d-handle round point shovel, a mattock, and an axe in the bed. (HiLift already mounted) Waiting on a mobile install window tint guy to show up at work and tint front door windows to match back doors. EBC "yellow" brake upgrade will be on by end of September.
    By spring, she get's an ARB air locker in the front. Toyota "SEMA" wheels stored in garage until it's time for another set of Cooper STT PRO's. (Going to 285/75r17 instead of 285/75r16's....34" instead of 33")
    Looking for a grill surround so I can build my own mesh grill. (Wanting to save the 2011 "one year only" grill)
    Already "trail ready", but NEVER quite "done".
  5. Sep 3, 2017 at 9:31 AM
    beachbum5812
    beachbum5812 Well-Known Member
    Fontana, SoCal
    2011 t/x pro prerunner
    2011 T/X Pro prerunner; icons, dirt king uca, front and rear bumpers (just waiting for the bumpers now)
    New bed bars, all Thanks to @glorifiedwelder for fabricating them. AWESOME JOB MAN :bowdown:
  6. Sep 3, 2017 at 11:58 AM
    weendoggy
    weendoggy Well-Known Member
    Aptos, CA
    2014 TRD ACOR 4x4
    Access Original Tonneau Cover; Toyota Side Tube Steps; Focal ISS690 front speakers; Clarion XC1410 mini amp; Gentex 453 rearview mirror with Homelink, Compass, Temp and Autodim; Prodigy P2 trailer brake controller, Heated Seats from www.cobraheat.com, BriteAss Fogs, Phillips Extreme LED H/L. Heated mirrors from @Up2NoGood. 5100 Bilstein all four corners.
    Finally installed my new 5100 shocks I've had sitting for six months. Took about 2.5hrs and set front to .85. Like the ride and stance. Next is alignment. F / 35 1/4" , R / 36" measured from ground to bottom of fender with C/L hub. All stock springs.
    gabbo2112 and TacomaCody like this.
  7. Sep 3, 2017 at 12:01 PM
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    Which product you use for sound deadening
    kgarrett11 likes this.
  8. Sep 3, 2017 at 12:14 PM
    dustin19d
    dustin19d Well-Known Member
    Dustin
    Washington
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
    Cut fenders back 2".
    Step 1. Tape fender
    2. Measure, mark and draw your cut line
    3. Set air output psi where the wheel on your die grinder remains in motion under slight pressure. You want to minimize heat during the cutting process so go as low as you can. For me 55psi was the sweet spot
    4. Cut
    5. Trim painters tape back 1/4" and primer all bare metal. Let dry
    6. Instal Trail Toys fender trim
    7. Rinse and repeat on the other side
    8. Drink beer
  9. Sep 3, 2017 at 12:23 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Was this to fit 35s?
  10. Sep 3, 2017 at 12:25 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    gabbo2112 likes this.
  11. Sep 3, 2017 at 12:45 PM
    dustin19d
    Dustin
    Washington
    Yeah, just gotta shave down the cab mounts a little more and weld them up and I'll be done
    boogie3478[QUOTED] likes this.
  12. Sep 3, 2017 at 1:15 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Finally bit the bullet and cleaned my throttle body and MAF with 110,194 miles on the clock!
    Throttle body before
    Throttle body after (took 20 minutes, a tooth brush, and almost a full can of TB cleaner to get it clean)
    MAF before
    MAF after, I cleaned the wire up inside the shaft as well, but that is impossible to get a good pic of.
    Put a fresh air filter in once I was done too.
  13. Sep 3, 2017 at 1:25 PM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    Not a busy day on here it seems lol
    Kemosabe and 08TRDOFFROAD like this.
  14. Sep 3, 2017 at 1:55 PM
    08TRDOFFROAD
    Dan
    Every body is probably out recreating enjoying the last 3 day weekend before the weather starts to turn (for those of us in 4 season areas).
  15. Sep 3, 2017 at 2:08 PM
    ManBeast
    Zach
    Orange Park FL
    Troof lol i am fortunate enough to have a 3 day weekend 52 times a year #410hourshifts
  16. Sep 3, 2017 at 2:11 PM
    ToyodaSun
    ToyodaSun Well-Known Member
    Parts Unknown
    17' DCLB TRD OR
    2005 Tacoma PreRunner TRD Off-Road 4.0V6, AT, ~90,000miles. Rebuilt the front brakes. Everything was shot on the previous setup.
    [​IMG] [​IMG]
    Parts used: Raybestos Coated Calipers; Raybestos HD Long Life Rotors; Akebono Premium Pads;
    [​IMG] [​IMG]
    The job was easy, but it is not complete as the driver side brake line that feeds the caliper cracked and was leaking. I have ordered replacements for left and right as the other one is close to shot as well. An extra 6 bucks spent to avoid catastrophic brake failure is well worth the money.
    Only the dealer has the proper fitting brake line which is a 10mm bolt on each side. Aftermarkets at NAPA, Advance, and Auto Zone all had different sized bolts on each end of the line. The truck is out of service until Tuesday when the parts arrive at the dealership.
    Can't wait to feel the bite of fresh brakes.
  17. Sep 3, 2017 at 2:32 PM
    ElectricDoozer
    ElectricDoozer Well-Known Member
    NJ
    2010 Tacoma Sport
    I went with Damplifier Pro 13sq ft from Second Skin and ended up with 2 12x18" sheets left over. Went on really nice and easy to work with.
  18. Sep 3, 2017 at 5:14 PM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Added rear spoiler . :facepalm:
    :rofl:
    Kuntrykid likes this.
  19. Sep 3, 2017 at 5:36 PM
    AugustaTaco
    AugustaTaco Well-Known Member
    Josh
    Augusta, GA
    2015 DCSBXSPX4X4 2017 GX460
    "Getting out of hand" - Wife
    Mounted and wired up my new lights :D
    Pic of the rear view doesn't do it justice, there is light everywhere you'd want without blinding you through the camera
    No light
    New lights
  20. Sep 3, 2017 at 6:06 PM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    ...and @AugustaTaco said "Let there be light" and there was light, a ton of it in fact, and it was GOOD. :D
