  1. Sep 27, 2017 at 1:14 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    I might have to get the net now too.
    Dan H[QUOTED] and uurx like this.
  2. Sep 27, 2017 at 1:14 PM
    nazlax10
    nazlax10 Check out my build thread for any products used!
    David
    Woodstock, GA
    '21 Toyota Rav4 LE... At least it's a Toyota
    https://www.tacomaworld.com/threads/nazlax10s-build.408318/
    Add a fuse! Come on man!! hahaha:D
  3. Sep 27, 2017 at 1:15 PM
    SoCalTbird
    SoCalTbird Well-Known Member
    South OC
    06 PreRunner DCSB 05 AC 4X4
    Add A Fuse?:confused:
  4. Sep 27, 2017 at 1:15 PM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    :rofl::rofl::rofl:
    :anonymous:
  5. Sep 27, 2017 at 1:16 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Nope many cams are 5v you will need an inline buck converter or just buy a cheap wiring kit made for a dashcam from Amazon they are around 10$, there is one in the list at bottom of page
  6. Sep 27, 2017 at 1:18 PM
    Cativelense
    Nuno
    CT
    Been looking into that already actually. Spy Tec makes one, cheap, so might go that route, and get another AAF :)D) since I already have one, but guessing "tapping" into the existing one is not a good idea.
    ChadsPride likes this.
  7. Sep 27, 2017 at 1:19 PM
    nazlax10
    David
    Woodstock, GA
    I think I have it linked in my build thread, but I bought the blackvue b-112. It's essentially a battery pack that charges only while the vehicle is on. Then once you turn the vehicle off the camera switches from car power to the battery to conserve your car battery power. The battery pack gets powered the same as the camera would. Positive to AAF that in a switched power slot and a ground. It's a little more expensive of a set up but allows the dash cam to run up to 12 hours while the car is off and not use the car battery power.
  8. Sep 27, 2017 at 1:21 PM
    Cativelense
    Nuno
    CT
    We'll see what I end up doing. First gotta MAN UP to do the install myself, and connect wires and stuff. But gotta buy the right stuff for that first.
  9. Sep 27, 2017 at 1:24 PM
    nazlax10
    David
    Woodstock, GA
    Shouldn't be too bad you got it!! Also I just remembered the b-112 gets powered by plugging into the 12v socket so I just wired in a socket behind my dash to plug it in. Same way though. Positive to an AAF and a ground. You can find 12v sockets meant for hard wiring at any auto parts store or walmart.
    Cativelense[QUOTED] likes this.
  10. Sep 27, 2017 at 1:25 PM
    BigMacMcCoy
    BigMacMcCoy Cajun In Vienna
    Braedon
    Vienna, VA
    Silver 2010 Tacoma Access Cab
    All the dumb choices in one vehicle
    I'll install it for you in exchange for those retros... :spy:
    Those retros make me so :jellydance:
  11. Sep 27, 2017 at 1:26 PM
    Cativelense
    Nuno
    CT
    No dice man, SORRY!
    BigMacMcCoy[QUOTED] likes this.
  12. Sep 27, 2017 at 1:33 PM
    Doogz
    Doogz Well-Known Member
    Bryce
    Western MA
    2009 MGM AC
    yep..
    I thought the net came standard with the truck. Guess not..
  13. Sep 27, 2017 at 2:21 PM
    la0d0g
    running for the hills
    For crawling not hauling
    The dealer I bought my truck from used to give them away. I'm still convinced they just took them off all the new trucks that came on the lot and re-gifted them.
    Casper66 and SoCalTbird like this.
  14. Sep 27, 2017 at 4:56 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
  15. Sep 27, 2017 at 5:51 PM
    Strxn
    Strxn Active Member
    PA
    '10 BSP DCSB 4x4
    Can anyone help me find a part # to this shield or it’s actual name? Having the hardest time finding it. I snapped the bolt to the bracket holding it while greasing the driveshaft, it’s all pretty rusted would like to replace it
  16. Sep 27, 2017 at 6:10 PM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    This took alot longer than I thought it would but it's much cleaner/safer.
    Custom made 5/32" aluminum plate that my friend had lying around. Pain in the ass to make more custom cables (0/2 welding cable big 4 upgrade) but I needed all my wiring cleaned up and a breaker on my 3000w inverter.
    Theloraxcross and Tacoturtle like this.
  17. Sep 27, 2017 at 7:16 PM
    Sprocket
    Sprocket Well-Known Member
    Said-a-Give!?
  18. Sep 27, 2017 at 7:18 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    my only issue is all the red wires on the ground lol. at least wire loom it to cover the red :D
  19. Sep 27, 2017 at 7:23 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    That's a good idea.
  20. Sep 27, 2017 at 7:30 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    I'm usually in the turd gen section, but I've always wanted to do some 2nd gen BTLM. Here we go
