  1. Sep 29, 2017 at 10:44 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Split yours open and slap those puppies in there dude!
    gabbo2112 and NKYTaco like this.
  2. Sep 29, 2017 at 10:47 AM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Oh...That makes sense. I thought it was because he was looking at manufacturers specs on rim width or something like that.
    Greg617 and ChadsPride[QUOTED] like this.
  3. Sep 29, 2017 at 10:51 AM
    cproc
    cproc Member
    Kelowna BC Canada
    2014 White Tacoma TRD
    Had those in my jeep, loved them. 5 min install too.
    Waiting for the exact same thing :fingerscrossed:
    ChadsPride likes this.
  4. Sep 29, 2017 at 11:01 AM
    Sasquatchtaco
    Sasquatchtaco Sasquatch Taco
    Catskills NYS
    09 MGM DCSB 4X4 TRD
    Too many to list.
    Finally got to use this little guy today. Money well spent.
  5. Sep 29, 2017 at 11:03 AM
    Tacoturtle
    Tacoturtle Well-Known Member
    Trey
    Athens, Ga
    2015 red dcsb sport
    Ordered all my parts for the ECGS bushing install. Gonna change all the diff/transfer case oils while I'm at it.
    Little nervous to do the ECGS install - trying it on my own and hoping for the best. I've also driven about 7500 miles with a vibe, so really hoping the CV is still in okay shape.:fingerscrossed:
    08TRDOFFROAD likes this.
  6. Sep 29, 2017 at 11:05 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Try cleaning the throttle body also.
    wheeliest[QUOTED] likes this.
  7. Sep 29, 2017 at 11:11 AM
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    Picked up a set of OEM headlights just now for $100. Retrofits in the spring!
  8. Sep 29, 2017 at 12:01 PM
    ChadsPride
    Cant wait to see that man! :jellydance:
  9. Sep 29, 2017 at 12:01 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Have the right tools and take your time and you'll be fine. It's a straightforward install.
    Tacoturtle[QUOTED] likes this.
  10. Sep 29, 2017 at 12:17 PM
    Rabbidllamas
    Rabbidllamas Well-Known Member
    Phil
    Tri-Cities WA
    11 DCSB Stormtrooper
    Like. Do you have info on that by chance? Brand/cost?
  11. Sep 29, 2017 at 12:18 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    So I have been dealing with a mild clunk for a couple of years just as I start and stop. After my T-bone wreck (which should have totaled the truck if they knew about the axle) I had the entire axle replaced. Later I got the 4 leaf TSB done. My truck is stock height so nothing was changed from the suspension. I replaced the shocks since one side wore out early probably due to the wreck. I've tightened down all the U-bolts to factory torque as found in the manual. After all this I still had the "clunk".
    After painting line up marks on the drive shaft, yesterday I decided that the play in my carrier bearing was more than I wanted and replaced it. I have about 115K miles. At the same time I carefully cut off the metal straps on the slip yoke cover and took that apart. I cleaned out all the old grease and replaced it with new grease. I put everything back together and attached the cover with 2 heavy duty about 3/8" wide zip ties. I put one connector on the right side of the shaft and the other on the left just opposite of each other thinking the it would help with the balance.
    That did the trick. No more "clunk" and at 1-85mph it has no vibration - it never did. My biggest worry is the zip ties. I've only driven it maybe 25 miles but the zip ties are still tight. In 2 weeks I'll be heading back up to the Madison River so that should hopefully cause them to fail if the are going to. I'll pack extra ties with me for a bush fix if needed.
    Has anyone tried something like a CVT boot strap on the slip yoke cover?
  12. Sep 29, 2017 at 12:40 PM
    15TRDSport
    15TRDSport Well-Known Member
    Larry
    QC, AZ
    2019 Toyota Tacoma Trd Sport
    Work in progress
    I finally got a tonneau cover for my street queen. BAKFLIP F1IMG_1242.jpgIMG_1243.jpgIMG_1244.jpgIMG_1245.jpg
  13. Sep 29, 2017 at 12:58 PM
    DC-USAF
    DC-USAF Well-Known Member
    Dale
    WNC
    2015 SR5 Access Cab 4x4 V6
    TRD PRO Grill, mobtown offroad recovery bar, SCS Ray 10's
    Looks like you got your LIKES button back. @ChadsPride
  14. Sep 29, 2017 at 1:01 PM
    ChadsPride
    Sure did!!! Took a pic of my mall crawler to celebrate.
    :cheers:
  15. Sep 29, 2017 at 1:05 PM
    Rabbidllamas
    Phil
    Tri-Cities WA
    Sorry about that. I was specifically looking at your front bumper. What a tool I can be.
  16. Sep 29, 2017 at 1:38 PM
    Rabbidllamas
    Phil
    Tri-Cities WA
    Thanks. Thought so after reviewing your build.
    jeff b[QUOTED] likes this.
  17. Sep 29, 2017 at 3:59 PM
    TacoTacoma97
    TacoTacoma97 Eagle Scout
    Scott
    Waco TX
    I think it's a Tacoma, let me go check again...
    *Cracks knuckles* Where do I begin?
    I've got night photos coming later so brace yourselves:
  18. Sep 29, 2017 at 4:25 PM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    no link, local through special pricing on a long time shelved unit ;)
    Justanotherhemi likes this.
  19. Sep 29, 2017 at 4:35 PM
    DC-USAF
    Dale
    WNC
    scleaf, smcgill, jeff b and 6 others like this.
  20. Sep 29, 2017 at 4:37 PM
    WhiskeyTaco
    WhiskeyTaco Well-Known Member
    Zach
    Denver, CO
    2011 White Tacoma Access Cab TRD Off Road
    Ultragauge finally arrived!
