  1. Oct 3, 2017 at 11:51 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    I drove it to lunch. Pretty boring I know. Work is busy otherwise I woult bolt on my Mobtown sliders that are sitting in my garage.
    In related news, I saw a T4R Pro in that new blue color on the way back. I actually thought it looked pretty good with black rims and running boards.
  2. Oct 3, 2017 at 12:14 PM
    the glen
    the glen Well-Known Member
    Glen
    penisula
    2012 TRD Off-Road 6SP manual spruce mica Taco
    Icon 2.5 remote res. Coilovers front, icon 2.5 rem res shocks rear, deavers 10 pack leafspring rear. Light racing ouca. Cmc, avid light bar, bamf sliders weld on, grillcraft mx grill, bamf light bracket with lightforce 170's. Uws toolbox, oem bed mat, weathertechs f/r, hella airhorns, trd antenna, talegate mod, Clifford alarm, budbuilt full skid plate set. All pro rear bumper. Superbumps bumpstops. Bulldog lighting reverse led lights in bumper. Trd short throw shifter. Cobra cb, firestick 4' ant. Icon LCA skids. Bamf rear dif skid. Hi lift x-treme mounted with relentless rail mounts in bed. Full size method/bfg in bed. Crown performance ss/Kevlar brake lines. Power tank mounted in bed. Rigid d2s mounted on relentless hood mounts. H3R quick release fire extinguisher mounted to driver's seat. Redline hood struts.
    Tha
    Thankyou, much appreciated.
  3. Oct 3, 2017 at 12:39 PM
    G's 05taco
    G's 05taco Well-Known Member
    Gunner
    Gilbert, AZ
    2017 Tacoma Limited
    Icon Stage 9 Suspension System with upgraded finned reservoirs and Icon S2 secondary bypass system stage 3, Camburg's Lower Control Arms, Camburg's Performance Spindles, Baja Designs 30" S8 LED Light Bar, Baja Designs 30" OnX6 LED Light Bar, Baja Designs SAE Fog Light Kit, SDHQ Built Behind the Grille Mount, SDHQ Built ABS Guards, SDHQ Built Swith Pros Keypad Mounting Panel and Power Module Mount, SDHQ Built Universal 3-Way Tie Down Strap and Bracket, SDHQ Built Power Steering Reservoir Kit, SDHQ Built Rock Sliders, RCI Off Road's Front Skid Plate, aFe Momentum Intake, Total Chaos Fabrications Bed Stiffeners, Icon Alloy's Six Speed Wheels, and Toyo M/T Tires.
    You guys have any pictures of what the reverse lights look like??
    ChadsPride[QUOTED] likes this.
  4. Oct 3, 2017 at 12:42 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    You re-use your existing reverse lights. In my case I just swapped my LED ones over that I got from @csjumper2003
  5. Oct 3, 2017 at 12:48 PM
    G's 05taco
    Gunner
    Gilbert, AZ
    2017 Tacoma Limited
    Oh nice did you go with the 400 lumen or 700 lumen ones?
  6. Oct 3, 2017 at 12:51 PM
    ChadsPride
    Great question! :oops:
    I went with the lower priced option. These don't have the little mini projector tip.
    Decided to go this route becuase at some point Im going to mount my BFF rear bumper with integrated pod mounts for the RI diffused pods I have collecting dust.
    gabbo2112 likes this.
  7. Oct 3, 2017 at 12:53 PM
    G's 05taco
    Gunner
    Gilbert, AZ
    2017 Tacoma Limited
    Makes sense! Thanks!
  8. Oct 3, 2017 at 12:55 PM
    ChadsPride
    No problem! They are way brighter than stock, I will say that.
    csjumper2003 likes this.
  9. Oct 3, 2017 at 12:59 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Just cut the buckle off the belt and leave it inserted all the time.
    Tacoma HEART and Tacoturtle like this.
  10. Oct 3, 2017 at 1:00 PM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    I could have sworn I've seen that they sell that buckle pc by itself somewhere...
  11. Oct 3, 2017 at 1:02 PM
    la0d0g
    They do. Or cut an old cd/dvd case to shape. But why do that when you have a perfectly good buckle already.
    Cativelense[QUOTED] likes this.
  12. Oct 3, 2017 at 1:06 PM
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
    eBay you can get a pair of the inserts. Like 7-8 bucks.
  13. Oct 3, 2017 at 1:08 PM
    Cativelense
    Nuno
    CT
    That's where I saw it then.
    Thank you sir! :hattip:
    ChadsPride likes this.
  14. Oct 3, 2017 at 1:20 PM
    csjumper2003
    Savannah, GA
    Cativelense and ChadsPride like this.
  15. Oct 3, 2017 at 1:21 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Stick a clothes pin in the buckle upside down like so..
  16. Oct 3, 2017 at 2:10 PM
    omgwtfbbq!
    omgwtfbbq! Well-known Idiot
    Ohio
    2013 X-Runner
    Man I still love those tail lights but at work I always park next to a Ridgeline and they look like aftermarket copies of the OEM ridgeline lights. I'd never hear the end of it if I had those on a Taco lol.
  17. Oct 3, 2017 at 3:45 PM
    Ares
    Ares Well-Known Member
    Darek
    Hamilton , ON
    2015 LTD DCLB
    IMG_1951.jpg IMG_1954.jpgFinally installed door sill protectors from G-Tek Fab that I received about a month ago. Installation was fairly straightforward. Very happy with the product. First real mod officially done. :bananadance:
  18. Oct 3, 2017 at 4:19 PM
    Velociraptor4x4
    Velociraptor4x4 Well-Known Member
    Canton, Ohio
    2015 DCSB OR
    I did nothing to the truck. But I took my brother to pick up his new to him truck. A super clean 1st gen
  19. Oct 3, 2017 at 4:36 PM
    JeffB
    JeffB Well-Known Member
    Jeff
    N.E. CT
    2017 TRD Sport
    Do youse know the manufacturers have to change many things whether a car is sold in the EU or in USA?
    A Couple among them are the directional colors, I think they use white in the EU and we insist on yellow.
    Another is the EU cars need smaller air bags.
    Why, because they use their Fucking seat belts, every time!
    BassAckwards[QUOTED] likes this.
  20. Oct 3, 2017 at 4:40 PM
    BassAckwards
    This i was not aware of, and im not condoning driving around without a seat belt at speed, unless you have a death wish of course. I always buckle up, unless im riding around the ranch at very low speeds:thumbsup:
