  1. Dec 3, 2017 at 9:05 AM
    zh137dz
    zh137dz Well-Known Member
    Nashville, TN
    2012 Tacoma Prerunner TRD Sport
    too many lights
    Debadged the tailgate and washed and waxed. Leaving the Tacoma badges on the doors because it looks cool with the puddle lights I installed under the mirrors. Eventually I want to remove that plastidip and paint them to match my graphite wheels.
    20171203_103753.jpg 20171203_104322.jpg 20171203_104356.jpg 20171203_103837.jpg
    FangBeast, siundon, Ramelli11 and 6 others like this.
  2. Dec 3, 2017 at 9:38 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Where'd you read that?
    Casper66 likes this.
  3. Dec 3, 2017 at 9:44 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    need to get/make one of these. Backup cam is almost useless with sun on the display. Probably be okay only half as deep. Fits in CD slot?
  4. Dec 3, 2017 at 9:58 AM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    Got an ARE CX series the other day. Favorite mod by far :D
    Holloman, BajaAsh, FangBeast and 7 others like this.
  5. Dec 3, 2017 at 10:25 AM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    By someone else who has them
    TacoZim likes this.
  6. Dec 3, 2017 at 10:31 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Ah. I'm pretty sure they can be if you wire them in right. Our switches are weird though, and dim off of the ground circuit so I'm unsure how exactly they'd be wired up.
    What I'm saying is I'm unsure what I'm saying :wink:
    hunter357mag and TacoZim like this.
  7. Dec 3, 2017 at 10:32 AM
    TacoZim
    TacoZim Well-Known Member
    Bay Area, CA
    2008 DCLB
    I have several switches just like the one in the picture, all dim with the other interior lights as long as they're all tapped into the same wire.
  8. Dec 3, 2017 at 11:08 AM
    jjustjjosh137
    jjustjjosh137 Well-Known Member
    Josh
    Pensacola
    2010 taco 5speed 2.7l 4wd
    None yet
    Threw a missfire code on me after the movies last night says it's the number four cylinder. Soooo I got new plugs and installing them now. Anyone know off hand the cylinder numbers for the 2.7l?
    ChadsPride likes this.
  9. Dec 3, 2017 at 11:12 AM
    AR15xAR10
    Likely story.
  10. Dec 3, 2017 at 11:12 AM
    Earlious
    Earlious I'm here cause you broke it.
    Ernesto
    Chico, CA.
    2010 Red Demon DCLB TRD Sport
    Map light mod,A/C knobs,Weather-Tech,Console & Glovebox Organizer's
    Front of the engine is #1 then 2 and so on.
    jjustjjosh137[QUOTED] likes this.
  11. Dec 3, 2017 at 12:24 PM
    nazlax10
    nazlax10 Check out my build thread for any products used!
    David
    Woodstock, GA
    '21 Toyota Rav4 LE... At least it's a Toyota
    https://www.tacomaworld.com/threads/nazlax10s-build.408318/
    Took the headlights out for a little project!!
  12. Dec 3, 2017 at 2:21 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    To get them to dim wouldn't you have to pull power for them off the dash light dimmer switch? I would think they'd dim then rt along with the dash lights
  13. Dec 3, 2017 at 2:48 PM
    Cory07TRD
    Cory07TRD Well-Known Member
    Cory
    Sacramento, CA
    07 Tacoma TRD
    Body Armor Rock Slider/Step, 5100's, Falken Wildpeak AT3W's
    Light up 4x4 selector mod thanks to @rcbs204
    Musubi3, FangBeast, JayRayger and 7 others like this.
  14. Dec 3, 2017 at 2:58 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    I need to do this it's stupid it isn't lighted already
  15. Dec 3, 2017 at 3:05 PM
    Dan H
    Dan H Wife thinks I'm having an affair with my Tacoma
    Daniel
    Glendale AZ
    2006 indigo ink PreRunner DCSB- 2012 Venza AWD
    ProComp Pro Runner shocks n struts Painted engine cover Fog anytime mod Cherrybomb muffler Bestop 3/16 tailgate plate and top cap Where do I begin with all the camo
    When I wired mine in it dims but it's backwards. I dim the lights the switch gets brighter and vis versa. 20170112_184159.jpg
    ChadsPride and Casper66[QUOTED] like this.
  16. Dec 3, 2017 at 3:20 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If the dash lights are like the down light, they dim off the ground, not positive.
    Im pretty sure the switches gets a constant hot, and is switched/dimmed via the ground circuit which is weird.
    Casper66[QUOTED] likes this.
  17. Dec 3, 2017 at 3:26 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    I used th ch4x4 switches I know for illumination they use a keyed hot so I just used an add a fuse and tapped into the dash light circuit so they come on when the lights are turned on. When you push the switch the second light in the switch comes on. I'm not sure about these other switches but would imagine they're similar
  18. Dec 3, 2017 at 3:37 PM
    schecter517
    schecter517 MX4LYFE
    Richard
    San Diego
    2014 DCSB TRD Sport 4x4
    TRD Pro Wheels Falken WildPeak AT3W 265/70-17 Black Spyder Projector HL w/LED Bar Morimoto XB LED Fog Lights Spec-D Black Tail Lights Truxedo Deuce 2 Tonneau Cover Tinted Windows Bed Mat Debadged Blue LED Interior Lights LED Switchback Turn Signals Led Reverse Lights and License Plate Lights DDM Ultra HID 55W 55K Kit
    How do you do that? I want mine lit up
    JayRayger, gabbo2112 and DaveInDenver like this.
  19. Dec 3, 2017 at 3:38 PM
    RDO
    RDO Member
    2012 White Tacoma Base 5 lugger
    Started some easy mods to my little 2Gen 5lugger...
    Before
    After
    Tires and wheels: 235/75 r15s, painted grill and emblem, cleaned and renewed front bumper, polished headlights, added toolbox for storage. A good weekend...
  20. Dec 3, 2017 at 3:49 PM
    Dan H
    Daniel
    Glendale AZ
    Mine is also a CH4x4 switch.
