  1. Dec 5, 2017 at 1:18 AM
    Uki Monstah
    Uki Monstah Well-Known Member
    Richmond
    Maui 808 state
    2013 pyrite mica 4x4
    Performance: K&N cold air intake Flow master Duel exhaust Looks : Wet okole seat covers N-fab side steps 3" lift -bilsteins all around, OME coils, ICON uca, rear add a leaf spring Stealth custom series sr8 wheels wrapped with BFG Ko2 275/70/17
    Just check if the ground is secure, or the box that connects to the bulb
    . I had mines go out the first night and found that the silver box that u attach to the bulb was not tightened enough.
    Be care!i was taking part couple things before I found it was bad connections. When I did mine I was turning the ring that holds the bulb and the bulb was turning too, literally almost fucked up my bulb
  2. Dec 5, 2017 at 2:46 AM
    Lefkos
    Lefkos Well-Known Member
    Winston
    Las Vegas
    PreRunner
    Yo, your username is the best lmao
  3. Dec 5, 2017 at 3:19 AM
    WetTaco
    WetTaco Well-Known Member
    Louis
    Northern California
    2012 DCLB 4x4
    Installed my ram mount cell phone holder after adding a wireless charging pad to it. Ram mount secures to the dash using the brackets made by @Lostsheep for a super clean and very sturdy install.
    Slashaar, SC2SC, MOBB1N and 4 others like this.
  4. Dec 5, 2017 at 3:29 AM
    fireman903
    fireman903 Well-Known Member
    new jersey
    06 taco
    3 inch lift 33 in tires undercover emergency responder light 30 rigid led light bar bed lights engine compartment lights
    idk about that fairlead has that bulky look but i do like it i would do a different fairlead if i was to do it
  5. Dec 5, 2017 at 3:44 AM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    Yeah I find them more useful for my needs than the sliding windows option. I wish I could've gotten both but that would require having a 6 ft. bed or going out west to get a snugtop rebel.
  6. Dec 5, 2017 at 3:53 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Service today .I was going to spray it down today but rain expected .
    ChadsPride likes this.
  7. Dec 5, 2017 at 3:54 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Raining here also, just washed the truck! :rain: :annoyed:
    gabbo2112 and lynyrd3[QUOTED] like this.
  8. Dec 5, 2017 at 4:01 AM
    lynyrd3
    Bill
    My neighbor always yells at me when I wash the truck ........"Now Its Going To Rain "
  9. Dec 5, 2017 at 4:05 AM
    ChadsPride
    :rofl::rofl::rofl:
    gabbo2112 likes this.
  10. Dec 5, 2017 at 4:22 AM
    ChadsPride
    :woot::woot::woot:
    pat's taco likes this.
  11. Dec 5, 2017 at 5:54 AM
    SilverJack
    SilverJack no one
    I have a few observations about headlight moisture. First off, I believe most modern headlights have vents, so trying to completely seal the unit is counter productive. In theory the unit should be self de-fogging since the hot air will push out moisture through the vents. The vents should keep the water from getting back in, but occasionally they can clog or get saturated. I also think the manufacturers coat the inside of the lens with antifog, and that layer is removed when people clean the lens during a mod. I managed to scrape that layer when trying to retrieve a loose bulb in my headlight so I'm pretty sure it's there. This keeps the water from forming mini droplets which causes the fogging. Even a tiny drop of water can cause a huge amount of fogging and it will keep cycling around in the headlights if it can't vent out. I would suggest any modder to use a plastic safe anti-fog and to make sure the vents are clean.
    Edit - I'm also concerned about "baking" the headlights and what damage this does to the spongy material in the vents. If it's designed as a filter, then perhaps any heat could fuse it into a solid plug.
    Cativelense likes this.
  12. Dec 5, 2017 at 6:22 AM
    la0d0g
    running for the hills
    For crawling not hauling
    Called Toyota to see how much the 30k maintenance is for our T4R. Was quoted $322. I told them I would call back and schedule an appointment but I was lying :anonymous::D
    Manfred, R242, Harry2015 and 7 others like this.
  13. Dec 5, 2017 at 6:28 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    What all is in the 30k maintenance? Oil, filters and maybe plugs?!
    la0d0g[QUOTED] and ChadsPride like this.
  14. Dec 5, 2017 at 6:30 AM
    la0d0g
    That and diffs and tcase. She also said the inspect the exhaust and take it for a drive to make sure everything is good :laughing:
  15. Dec 5, 2017 at 6:31 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'll do all that for you for $150 :D
  16. Dec 5, 2017 at 6:42 AM
    SilverJack
    SilverJack no one
  17. Dec 5, 2017 at 7:04 AM
    Naumoff42
    Naumoff42 Well-Known Member
    Ohio
    2015 TRD Offroad
    Those who changed out the climate control knobs, have you noticed that since it's been getting colder they slide off with ease, or is that just me? :rofl:
    gabbo2112, Earlious and ChadsPride like this.
  18. Dec 5, 2017 at 7:21 AM
    TRlPPlN
    TRlPPlN Pavement Cruiser
    Bay Area, CA South SF to be precise
    MGM DCSB 09 DC TRD Sport 4x4 - Family Hauler
    thank you. that was probably it. after swapping out the ballasts and making sure they're tight all is good. hopefully it stays that way.
  19. Dec 5, 2017 at 7:51 AM
    wade9986
    wade9986 Well-Known Member
    Ross
    Stuart, Florida
    2020 TRD Sport 4x4 Supercharged
    Magnuson Supercharger OTT Tune TRD Pro Front End Conversion Old Man Emu Lift 285/70/17 Nitto Trail Grapplers 17x8.5 Black Rhino Duggers Fab Fours Front Bumper Smittybilt X20 Winch Rigid Industries Lightbar
    To get the flush mount fairlead you would have to go with the synthetic rope instead of the cable. When I respool in the future I will probably go that route.
  20. Dec 5, 2017 at 7:57 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    They make steel fairleads designed for steel cable line. The ones for synthetic are aluminum.
    wade9986[QUOTED] and ChadsPride like this.
