  1. Jan 26, 2018 at 1:16 PM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Cool. Good to know. I may just get it before I get pulled over. :thumbsup:
    Kuntrykid and ACEkraut[QUOTED] like this.
  2. Jan 26, 2018 at 2:10 PM
    Hornedfrog53
    Hornedfrog53 Well-Known Member
    2020 TRD PRO
    885 with wheelers progressive add a leaf and 5100s. Demello flat top will be here next week! Here’s really hoping I won’t need UCAs yet and that the 885 can hold the new front. When I ordered it all I had read enough to think I was ok. But I’ve since read way to much and now a little nervous about it. Here’s hoping it’s all good!
    outxider, dnpbakon, Kuntrykid and 6 others like this.
  3. Jan 26, 2018 at 2:15 PM
    Barbietaco
    Barbietaco Tools are good
    Shane
    2006 Tacoma
    Sas swap with Dana 60 and GM 14 bolt rear on 42" Pitbulls
    No. It's red.
    gabbo2112 and WPNZ[QUOTED] like this.
  4. Jan 26, 2018 at 2:35 PM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Sparkplugs, tire rotation, greased everything an ultimate headlight upgrade an oil change. Driver side upgraded passenger stock that beam difference is emmence.
    sseaman, Kuntrykid and gabbo2112 like this.
  5. Jan 26, 2018 at 2:44 PM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    How many miles on those plugs?
  6. Jan 26, 2018 at 2:46 PM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    12k been running cheap gas these were ngk went denso this time. Just did the plugs last year at 50k had a misfire code.
    gabbo2112 likes this.
  7. Jan 26, 2018 at 2:59 PM
    TacomaJack099
    TacomaJack099 Well-Known Member
    Jack
    Orlando Florida
    Blue 2007 Tacoma 2.7 / 5 speed AC 4x4
  8. Jan 26, 2018 at 3:01 PM
    ellzy_21
    ellzy_21 Well-Known Member
    Fairbanks, AK
    '13 T/X BAJA 6MT
    TRD Supercharger, TRD/URD Exhaust, TRD Quick shifter,
    Warmed up to ~50 degrees in Michigan today so the Taco got a wash.
    Also put the center console organizer in and dig it so far
    325AB05A-0124-4E79-BE14-09E0ADC5AD4D.jpg C7292DAE-EF4B-4F42-BADF-5E72315410A9.jpg
  9. Jan 26, 2018 at 3:01 PM
    WPNZ
    WPNZ Well-Known Member
    Tucson Arizona
    14 DCSB SR5 6MT
    You get the Steel or Aluminum Version? Aluminum weighs 55lbs and Steel is 120lbs. Going to assume Steel and add the weight of a winch another 60-90lbs or so. Yeah you might want to get the 886 springs.
    If you got the Aluminum, after the 885 settle a bit, might want the 887.
    jfraze21 and MattCowsmasher like this.
  10. Jan 26, 2018 at 3:06 PM
    trdsport6
    trdsport6 Well-Known Member
    West NC
    2015 Super White access cab TRD
    bilstein 5100 @2.5 front and rear Method NV BFG KO2 275/70/17
    There it is!!!
    MattCowsmasher likes this.
  11. Jan 26, 2018 at 3:08 PM
    Hornedfrog53
    2020 TRD PRO
    I got steel. They told me it was like 103. I’d like to get some skid plates but prob won’t get a winch until my current toyos go bald. Then I’ll go 886 with 33s. Not looking for 3 inches even. So if it says to 2.5 that’s ok. Right now I have a spacer and block that was On when I bought it. It sits 23 front and 24 rear. I’d like to stay close to that.
    WPNZ[QUOTED] likes this.
  12. Jan 26, 2018 at 3:16 PM
    trdsport6
    West NC
    Difficult??? Looking to do the same thing
  13. Jan 26, 2018 at 3:17 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    Love those headlights. Custom?
    ellzy_21[QUOTED] likes this.
  14. Jan 26, 2018 at 3:22 PM
    WPNZ
    Tucson Arizona
    14 DCSB SR5 6MT
    It's pretty easy, just take your time, and if you go with wheeler's just follow their directions. Hardest part is lining up the leafs to get the bolt back in, and that just takes a little bit of time.
    outxider and trdsport6[QUOTED] like this.
  15. Jan 26, 2018 at 3:31 PM
    schecter517
    schecter517 MX4LYFE
    Richard
    San Diego
    2014 DCSB TRD Sport 4x4
    TRD Pro Wheels Falken WildPeak AT3W 265/70-17 Black Spyder Projector HL w/LED Bar Morimoto XB LED Fog Lights Spec-D Black Tail Lights Truxedo Deuce 2 Tonneau Cover Tinted Windows Bed Mat Debadged Blue LED Interior Lights LED Switchback Turn Signals Led Reverse Lights and License Plate Lights DDM Ultra HID 55W 55K Kit
    Sweet headlights!!
  16. Jan 26, 2018 at 3:59 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    Love the headlights are those retrofits or you just painted the inside?
  17. Jan 26, 2018 at 5:15 PM
    DAHOGGS44
    DAHOGGS44 Well-Known Member
    MARK
    Florida
    2011 DCSB
    3 INCH LIFT, OUTLAW 2 WHEELS, DV8 bumper
    Great idea.. always bitching about not having a place to put my vape without it laying on its side
  18. Jan 26, 2018 at 5:20 PM
    Islandtaco671
    Islandtaco671 Well-Known Member
    Daniel
    San Diego
    2006 Double cab Tacoma TRD O/R
    Got ol Betsy washed today!
  19. Jan 26, 2018 at 5:34 PM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    Had to drive down to the freight company today to pick something up.... then got home and started cutting...Then bolted it up! may have taken 4.5 months but looks pretty sweet, still need to oblong the mount holes a little more to get it to align right where i want but for now i'm happy with it.
    @RelentlessFab
  20. Jan 26, 2018 at 5:37 PM
    ellzy_21
    Fairbanks, AK
    '13 T/X BAJA 6MT
    Thanks! They are retrofits. I wish I could recommend the company that did them but I’ve had a lot of trouble with them over the past 2 years. Still love how they look though.
    Kmac4X4, tn_popo, sseaman and 10 others like this.
