  1. Feb 14, 2018 at 12:13 AM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Welcome back!
  2. Feb 14, 2018 at 12:20 AM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Adding 33s started kicking in my VSC in certain conditions. My VSC light stayed on after the initial procedure, so I went through the steps again, this time very carefully. I used an alligator clip jumper wire. I cut it in half and stripped a half inch off, then taped the ends into/onto the slots to make sure they didn't lose contact during the process. This made it easier to observe the dashboard. Now the VSC light is no longer on. Success!! I think before I jostled the truck or it wasn't perfectly level, or one of my connections at the OBD wasnt good. Either way, it appears to have worked this time.:):):)[​IMG][​IMG]
  3. Feb 14, 2018 at 2:44 AM
    henrilepuf
    henrilepuf Well-Known Member
    henri
    Northwestern Paraguay
    tacoma 2014 4x4 DCLB
    Pipe smoker since 1980.
    This one is a BJARNE (danish)
    have a nice day
  4. Feb 14, 2018 at 3:10 AM
    henrilepuf
    henri
    Instaler REDLINE quick lift for the hood
    works well
  5. Feb 14, 2018 at 4:22 AM
    mojovious
    mojovious Well-Known Member
    PA
    2013 Baja TX
    Changed oil (Mobile 1 5x30) and filter (Toyota OEM), reset maintenance clock, thoroughly cleaned and detailed under the hood and lubed the five driveshaft zerk fittings. It's almost like you can feel the difference.
  6. Feb 14, 2018 at 4:50 AM
    Trouble_The_Tacoma
    Trouble_The_Tacoma Well-Known Member
    Conrad
    What did you go with?
    ChadsPride likes this.
  7. Feb 14, 2018 at 4:52 AM
    Trouble_The_Tacoma
    Conrad
    What lube did you use for the drive shaft?
  8. Feb 14, 2018 at 6:05 AM
    Ras61
    Ras61 Well-Known Member
    Arlington VA
    '12 4wd TRD Sport Dbl Cab
    Icons front, Bilstiens 5125 rear, 35/12.5/17 MT/Rs and some trimming
    New wheels! I hoped this would cure all my rubbing problems. However, sometimes you fix one problem and create another. I used to rub bad on the UCA at full lock reverse, now I rub bad on the fenders and pinch weld (I’ve already hacked them back and pounded the pinch weld, but could do more). At least I can work with that. I don’t really want to cut any of the UCA.
    Right now I’ve got 1.25 inch spacers in the front, and 2.0 inch in the rear, so I plan to remove the rears and put the 1.25s in the front to see if that helps a bit. That’s what’s causing the rub. Plus, I think they are sitting a little too wide.
    The wheels are VTX Vipers in 17x8.5, -10 offset. Tires are 35/12/5/17 MT/Rs.
    VTX doesn’t get a lot of love of this forum, but they were selling these wheels used a smoking good price, and the rep I worked with was a pleasure to work with and very helpful. So, for what’s worth I had a good experience dealing with them!
    Enjoy.
    MVIMG_20180213_142941.jpg MVIMG_20180213_163439.jpg MVIMG_20180214_074831.jpg
  9. Feb 14, 2018 at 6:09 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    guess you need to sell those :boink:
    Ras61[QUOTED] likes this.
  10. Feb 14, 2018 at 6:20 AM
    Ras61
    Arlington VA
    Ha, why, to ensure my tenure as "well-known member" on TW?
    Jokes aside, I'm really happy with the wheels. Don't get me wrong, I think SCS's are the gold standard, but I paid $600 for five wheels shipped. Even with them being a little scratched up, it's hard to beat that price.
    I suppose for me it's like many things in life. I want to support companies I feel align with my values, but end up buying half my stuff from cheap Amazon sellers...
  11. Feb 14, 2018 at 6:23 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    That looks so damn good
  12. Feb 14, 2018 at 6:24 AM
    fatfurious2
    David
    Ashburn, VA
    I want to compare when I get all of my wheels/tires in.. (and hopefully I am still local to you)
    Ras61[QUOTED] and ChadsPride like this.
  13. Feb 14, 2018 at 6:27 AM
    la0d0g
    running for the hills
    For crawling not hauling
    That's about what I paid for my pro comps. Hard for me to pay more when I know they're just going to get scratched to shit anyway.
    Don5352 and Ras61[QUOTED] like this.
  14. Feb 14, 2018 at 6:27 AM
    Ras61
    Arlington VA
    Ya man! Happy to. I'm in Arlington, so relatively close. I've been meaning to make it to a local meet-up and keep failing. I know you guys are pretty active.
    fatfurious2[QUOTED] likes this.
  15. Feb 14, 2018 at 6:29 AM
    fatfurious2
    David
    Ashburn, VA
    those guys dont go off road enough for me. I mostly gave up with them. I would like to see my truck in Arlington. Just way out of place.
    Might be moving to PNW though
  16. Feb 14, 2018 at 6:31 AM
    fatfurious2
    David
    Ashburn, VA
    looks good, and shows they get used. My wheels are scratched to shit. And I know its an upgrade going to dirty5s and F5s :D They will be used
    ChadsPride and la0d0g[QUOTED] like this.
  17. Feb 14, 2018 at 6:35 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Which ones did you get? I'm keeping an eye open for cheap 16s if I make the jump to 315s
  18. Feb 14, 2018 at 6:38 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Looks like your mechanic approves!
    :rofl:
  19. Feb 14, 2018 at 6:47 AM
    Stemmy
    Stemmy Certified Wombat Rancher
    Rob
    Pennsylvania
    2013 Pyrite Mica DCLB
    my '13 hit 48K this morning. I've had it 10 months & have put 13K miles on it so far... sold my beater truck so this is my daily now.
  20. Feb 14, 2018 at 7:08 AM
    Dan H
    Dan H Wife thinks I'm having an affair with my Tacoma
    Daniel
    Glendale AZ
    2006 indigo ink PreRunner DCSB- 2012 Venza AWD
    ProComp Pro Runner shocks n struts Painted engine cover Fog anytime mod Cherrybomb muffler Bestop 3/16 tailgate plate and top cap Where do I begin with all the camo
    You even had the speed to match. :yes:
    Kuntrykid, Atlas86, markelhof and 4 others like this.
