  1. Mar 10, 2018 at 8:35 PM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Reach out to @CBoy808
    He makes some sick stuff
  2. Mar 10, 2018 at 8:37 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    You aren't going to get anything with a zerk fitting you could always buy a zerk tap and drill and tap a hole and install your own if you really want a grease fitting, but they aren't designed to be greased if they don't come with it already done.
    boogie3478 likes this.
  3. Mar 10, 2018 at 8:39 PM
    j_sav115
    j_sav115 Well-Known Member
    SC
    07 Silver TURD SPRT
    Getting to start all over :)
    That's the thing. If I replace them the boots will rip in less than 10k miles but if I have something that's made to be greased I can just keep a few pumps in it every couple thousand after the boot rips for way cheaper.
  4. Mar 10, 2018 at 8:40 PM
    ReconDoc718
    ReconDoc718 Member
    2010 Tacoma
    Mild Suspension upgrade Tires Electrical upgrades
    Hey Fox2011pm, just replaced my marker / fog light housing after I misjudged and bumped into a light barer so I wanted to replace the plastic with metal and found some from Slee Offroad bolt right up . . . give'm a look see, I really like mine.
    Kuntrykid likes this.
  5. Mar 10, 2018 at 8:41 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Why do you think the boots will rip in 10k. My truck has almost 200k I am not easy on it the tie rods are tight no ripped boots or anything. You can just buy boots as well.
  6. Mar 10, 2018 at 8:41 PM
    ReconDoc718
    ReconDoc718 Member
    2010 Tacoma
  7. Mar 10, 2018 at 8:42 PM
    j_sav115
    SC
    07 Silver TURD SPRT
    Because my boots were near new and I put a lift on... Within less than 1k the are all ripped. LCA tie rod and sway bar boots that is
  8. Mar 10, 2018 at 8:42 PM
    ReconDoc718
    ReconDoc718 Member
    2010 Tacoma
  9. Mar 10, 2018 at 8:45 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    You'll be fine with just replacing them with something like a MOOG don't over think things. Boots being torn on a greasable one isn't good either. You can get MOOG joints with urethane boots that will be much tougher than typical rubber and hold up to more abuse. If you can't find them then energy suspension or prothane make urethane boots just gotta figure out some that'll fit it may be for a chevy truck or something
  10. Mar 10, 2018 at 8:45 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    What are you trying to do?????
  11. Mar 10, 2018 at 8:48 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Thanks. I had to get crafty setting it to measure for the final cut since I was working solo. Fortunately I have a bunch of scrap wood from a fence project I'm wrapping up.
    ovrlndkull[QUOTED] likes this.
  12. Mar 10, 2018 at 8:48 PM
    j_sav115
    SC
    07 Silver TURD SPRT
    I'm not sure about the Chevy to Toyota compatibility so I'm completely blind on that if you have any info that helps allot man. Thanks for the info!
  13. Mar 10, 2018 at 8:48 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Scrap wood is always useful.
  14. Mar 10, 2018 at 8:49 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Just for the urethane tie rod boots not the tie rod themselves. Hold tight.
  15. Mar 10, 2018 at 8:52 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
  16. Mar 10, 2018 at 9:02 PM
    Fox2011PM
    Fox2011PM "The Mountains are calling"
    '13 DCSB 4X4 TRD OR
    ADS 2.5" CO's w/adj, ADS 2.5" Rears w/ piggybacks, Firestone air bags and 1.5" AAL, SCS SR8s, Tom Woods custom one piece drive shaft....more to come
    Man that's awesome! Thanks! I'll check em out
  17. Mar 10, 2018 at 9:05 PM
    j_sav115
    SC
    07 Silver TURD SPRT
  18. Mar 10, 2018 at 9:05 PM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
  19. Mar 10, 2018 at 9:08 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    This past week -
    Picked up an Ipad Mini 3 to use for navigating off road on fishing/camping/hunting trips.
    Remounted my Ultragauge using the window mount
    Today -
    Finally addressed my bent fuel filler door. Apparently this is a common thing with these trucks??
    Catch can install. Mounting bracket needs painted once its gets warmer out. The rubber hose will get replaced with some new stuff soon. Didnt realize I the stuff I had laying around I planned on using was starting to crack.
  20. Mar 10, 2018 at 11:07 PM
    dschlecht
    dschlecht Well-Known Member
    San Jose
    05 TRD Sport 4X4
    Painted a few things dark gunmetal - hood scoop and mesh insert, grill mesh inserts including triangles, front bumper insert, and skid plate. (Sanded and primered everything behind the mesh grill insert, still need to paint that all black and relocate the horn)
    (Paint is nice and even on scoop, lighting/flash looks weird in this pic)
    Added TRD emblem to grill ( I now have a total of 1 emblem on the truck lol)
    Wired up some blue LED's behind the mesh in hood scoop and down by opening in the front bumper insert.
    20180310_202637.jpg 20180310_204515.jpg 20180310_203732.jpg 20180310_203615.jpg
    Installed LED (RGB with tons of colors and modes with remote control) underneath entire length of bed railing. All wired up and tested, but waiting on an additional switch to arrive so I can complete.
    Jckdnls, msnk2u2, TRlPPlN and 2 others like this.
