  1. Mar 15, 2018 at 7:28 PM
    Ted Yoder
    Ted Yoder Well that didn't work
    06 DCLB
    In Progress
    Engine bay is empty. I ditched that weight so its just the 2 in the bed now
    I married my tacoma likes this.
  2. Mar 15, 2018 at 7:32 PM
    15TacoBase
    15TacoBase Well-Known Member
    2023 TRD PRO
    Finally put the bed mat in that I got from Amazon.
  3. Mar 15, 2018 at 7:37 PM
    Trey5150
    Trey5150 Well-Known Member
    2015 Black Taco DCSB TRD
    Leveling kit, Flowmaster exhaust, Warrior Front Bumper, Warrior Roof Rack, Ram Mount A-Pillar, Weather Tech mats, Pro grill, Rigid ditch lights, Rigid backup lights, Spod
    I don’t know what this means but i feel a vibration in the pedal while going 20-25 mph is this the cause?
  4. Mar 15, 2018 at 7:37 PM
    dustin912
    dustin912 Well-Known Member
    Dustin
    2005 Toyota Tacoma OR
    5100s ECGS Front Diff Bushing
    Simple Mods today.
    Shorty antenna.
    Craptastic AC knobs.
    Short usb charger.
    gabbo2112, Kuntrykid and 15TacoBase like this.
  5. Mar 15, 2018 at 7:37 PM
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    ... I never thought of this. I have a shell and bed tray system with my extra battery in the back but not connected to my main. I have a 2013 sport so very little if any room in the engine bay for another battery..
    I guess my question is there is no trouble starting with running your starter battery in the back? This changes my whole plan for solar charging and a dual battery setup...
  6. Mar 15, 2018 at 7:53 PM
    4T3Underhill
    4T3Underhill Well-Known Member
    Dustin
    smogland
    2012 Tacoma TRD Pyrite Mica
    Mounted the Frontrunner slimline II rack a Pelfreybilt brackets for access cab!
  7. Mar 15, 2018 at 8:02 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Looks like they do Volume pricing so could probably get a GB together if they are quality.
  8. Mar 15, 2018 at 8:02 PM
    Dan H
    Dan H Wife thinks I'm having an affair with my Tacoma
    Daniel
    Glendale AZ
    2006 indigo ink PreRunner DCSB- 2012 Venza AWD
    ProComp Pro Runner shocks n struts Painted engine cover Fog anytime mod Cherrybomb muffler Bestop 3/16 tailgate plate and top cap Where do I begin with all the camo
    I got the same notice a few days ago. To bad a few months ago I changed them.
    ACEkraut likes this.
  9. Mar 15, 2018 at 8:35 PM
    jtrue
    jtrue Well-Known Member
    SLC, UT
    2014 Super White Tacoma TRD
    SOS Slimline, Smittybilt X20, interested to see how the winch holds up. If it shits the bed I'll go warn, but had to try it.
  10. Mar 15, 2018 at 9:47 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    LED light rack with 22 pods is operational. Rather than building a switch circuit, i standardized all connectors by converting all lights to DTP connectors, then used the DTP Rigid harness to power the lights.
    I invested in a quality DC linear high precision bench top power supply to run more controlled tests outside the truck, which has the added advantage of easy current draw readings from the lights... and me not looking like a crazy person putting on a light show for the street. But I’ll still do beam pattern tests outside.
    This is testing the setup with Rigid. Draw 3.5A which calculates to 22.5w. Spec is 22w. This is going to be interesting.
    Edit: This is going to be even more interesting than I thought, as some claiming J583 patterns have poor beam control. Both these lights *should* not produce glare, clearly not the case, the right light has excessive glare.
  11. Mar 15, 2018 at 9:49 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Awesome work. Can’t wait to see the results!
    crashnburn80[QUOTED] likes this.
  12. Mar 15, 2018 at 11:30 PM
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    Is there a thread for just this? Extremely interested
  13. Mar 15, 2018 at 11:35 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    There will be a dedicated thread with very extensive testing coming soon. This was just the initial test of the rack, wiring and and power supply. Any specific questions feel free to PM me as I’ve already run through some preliminary tests and had some very interesting results.
  14. Mar 16, 2018 at 3:34 AM
    Ted Yoder
    06 DCLB
    In Progress
    Its been under 30 degrees over the last week. My truck isnt garaged. Not a single issue. Cranks hard just like it did before the relocate. 2/0 cable is the helping factor.
    Kuntrykid likes this.
  15. Mar 16, 2018 at 5:09 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    How’s the reception with that antenna? Where did you get it from.
    ChadsPride likes this.
  16. Mar 16, 2018 at 5:15 AM
    fshams
    fshams Well-Known Member
    Columbus, OH
    2012 Tacoma V6 4x4 TRD/TX PRO - DCSB
    Is that no rubbing with stock suspension?
  17. Mar 16, 2018 at 5:19 AM
    Ted Yoder
    06 DCLB
    In Progress
    Also, Im going to run the Blue Seas ML ACR. That along with the sPOD will be mounted on the back cab wall. I still need to upgrade the alternator to the 200amp version though just to be sure. Lots of heat shrink in my near future to extend some harnesses :bananadead:
    TomTwo likes this.
  18. Mar 16, 2018 at 5:35 AM
    Hupernikao7
    Hupernikao7 Well-Known Member
    Tallahassee, FL
    13' Trd Off Road 4x4
    MB Wheels "352" 16 X 8.5 6-139.70 -6 BFG Load Range E 33's Rugged Premium Tri-Fold Tonneau Cover 25 inch LED offroad light bar Ditch Lights
    One of my favorite mods so far. Thank you TW for the idea! Now to stock it up with all the useful items I have.
  19. Mar 16, 2018 at 5:39 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    What's with the socks on the mat??!! :rofl::rofl::rofl:
  20. Mar 16, 2018 at 5:40 AM
    Hupernikao7
    Tallahassee, FL
    You can blame the fiance for those lol
