  1. Apr 2, 2018 at 1:53 PM
    Trouble_The_Tacoma
    Trouble_The_Tacoma Well-Known Member
    Conrad
    Gunna do probably another with a Bluetooth amp and rechargeable battery. But here’s current parts list.
    Any ammo can (Walmart $8)
    Walmart 4” speakers $19
    Amp https://www.amazon.com/dp/B0077IA57Q/ref=cm_sw_r_cp_api_2EPWAb0ZPCCGR
    Input wire - https://www.google.com/aclk?sa=L&ai...ahUKEwixyM-evJzaAhWDTN8KHcuiDc8Qwg8IJg&adurl=
    Basically measure and cut holes for speakers, amp to speakers, input to amp, amp power to 12v.
    I’ll do a detailed rewrite on the Bluetooth with battery pack. But all in all I’m in it MAYBE $50?
    ACEkraut[QUOTED] likes this.
  2. Apr 2, 2018 at 2:55 PM
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    1st and 2nd coats respectively
    sseaman, outxider, kimo and 4 others like this.
  3. Apr 2, 2018 at 3:10 PM
    Heffery5000
    Heffery5000 Well-Known Member
    Jeff
    Haverhill, MA
    2014 tacoma trd offroad access cab blue ribbon metallic
    Urd short shifter Changed out grill Method wheels
    Got my tires swapped over to the new methodIMG_20180402_180456.jpg NVs
  4. Apr 2, 2018 at 3:13 PM
    86scirocco16v
    86scirocco16v Mack of all trades
    Leavenworth, Washington
    '05 4.0 6sp overland
    Black this black that , 315-75r16 pro-comp A/T's , 285-75-r-16 treadwright gaurd dogs full OME lift with Dakar leaf spring pack, boss airbags, 4.88 nitro gears, dakota digital speedometer calibrator, tjm air locker, arb onboard air, spider tracks 1.25" wheel spacer, sport headlights, brute force fab hybrid front bumper, 6000k 4" led fog lights, 24" double row led reverse light, storm trooper shift knob, rebadged badg-less black mesh grill, Kenwood double din stereo, 400w Rockford 12” sub . Anytime fog lights. Oh yeah almost forgot the 2016 FourWheel camper fleet model for extra traction and a place to crash if you do get stuck or broke down. 2x160watt solar, mppt charge controller by blue sky energy. 3 deep cycle batteries 20gallons water, 6gal hot water, 3.5cf 2way fridge/freezer, 6gallon propane... just getting warmed up.
    I painted the trim rings black Honestly since I look at them all the time it was super satisfying. The stereo bezel is next I think. 3EB54544-956C-4BA4-A0C6-76D168622FA5.jpg726A63F4-82D5-4D86-9997-FA82AE755A23.jpg
    kgarrett11, msnk2u2, siundon and 9 others like this.
  5. Apr 2, 2018 at 3:22 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Did you sand them before painting? I took mine out just need to paint them now. They look good!
    Kuntrykid likes this.
  6. Apr 2, 2018 at 3:25 PM
    Z7Xtreme
    Z7Xtreme Always Overestimated
    Chuck
    In a tree somewhere
    2015 trd Black Ops edition
    884's and 5100's with HS 1/4" taco lean spacer,1 inch toytec block and 5100's,SPC uca's,SCS Ray 10 wheels,265/75/16 Falken Wildpeak AT3,oem running boards,oem skid plate,WeatherTech floor liners,WeatherTech window deflectors,Access tonneau cover,WeatherTech stone and bug shield ,BPF tow hook,oem bed mat,pro grill,tacomabeast headlights,cali raised ditch brackets with Rigid lights,Rough country 30” lightbar on Rigid brackets RCI bedrack, KC rear lights,maxtrax,dual rotopax.
    Used ALL my saved up mod money to buy my daughter a 2006 Toyota Corolla.Guess it’s back to looking at stuff online and dreaming :(B8EDDE2C-7208-43FD-B23D-59CAE2213A7B.jpg
  7. Apr 2, 2018 at 3:41 PM
    Greg617
    Greg617 Well-Known Member
    Greg
    New England
    2010 5-speed 4x4
    Dents and scratches... Fox 2.5 Factory
    Solid mod for under $10. On my list.
    Great use for a beer box right there.
    :cheers:
  8. Apr 2, 2018 at 3:42 PM
    Morgan Freeman
    Morgan Freeman Well-Known Member
    Christian
    Miami
    '11 X-Runner S/C
    TRD Supercharged JBL LT's Cat-delete URD Spec-U Volant Ram-Air URD Short Throw
    Finally I can now be reminded what kind of truck I drive when I get in.IMG_7399.jpg
    sseaman, kgarrett11, msnk2u2 and 6 others like this.
  9. Apr 2, 2018 at 3:43 PM
    86scirocco16v
    I did a real quick 1200 grit and then a alcohol wipe down then rustoleum BBQ black as it dries mad quick and the rest of my truck is covered in it. Also did the center console cup holder thing the same way. It dries with a great matte finish. I use it on my rims as well seeing as there is no need to mask a flat black tire from flat black paint, touch ups are quick and easy.
  10. Apr 2, 2018 at 3:50 PM
    poseytaco
    poseytaco Well-Known Member
    Nicholas
    Indiana
    2012 Off-road
    I’ll be in the same boat in 2 years.
  11. Apr 2, 2018 at 3:55 PM
    HFDane
    HFDane Well-Known Member
    Dane
    Griffin, GA
    It was actually very easy. Disassemble the leaf packs, cut off the rear alignment wrap tab and install the new leafs. I used a 6” Irwin C-clamp which worked great.
  12. Apr 2, 2018 at 4:04 PM
    86scirocco16v
    Forgot to install this ADD shaft in the clamshell swap... noticed right away when I didn’t have 4wd any more. On the plus side I am super good at removing the entire front end now.754338DC-CEC1-4944-8742-CCEB23A96F39.jpg
  13. Apr 2, 2018 at 4:21 PM
    JeffB
    JeffB Well-Known Member
    Jeff
    N.E. CT
    2017 TRD Sport
    So, who screwed up? Us or You?
    ChadsPride likes this.
  14. Apr 2, 2018 at 4:26 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    no one did. I bought a bronze single. SCS most recent shipement did not include bronze, and I was not going to wait until mid may to get a whole matching set. Im not worried about the off color. They kind of look bronze if I dont wash the truck..
  15. Apr 2, 2018 at 4:28 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    PC them GOOOOOOLD!!!!
    They're all the 3.5 bs right?
    kgarrett11 likes this.
  16. Apr 2, 2018 at 4:29 PM
    JeffB
    Jeff
    N.E. CT
    2017 TRD Sport
    Nice Rig!
  17. Apr 2, 2018 at 4:30 PM
    fatfurious2
    David
    Ashburn, VA
    yes. But the truck looks badass on matte gunmetal. Cant even see the bronze because my trasharoo covers it..
  18. Apr 2, 2018 at 4:30 PM
    fatfurious2
    David
    Ashburn, VA
    Thanks!
    kgarrett11, gabbo2112 and ChadsPride like this.
  19. Apr 2, 2018 at 4:33 PM
    ChadsPride
    I agree, it looks bad ass!!! Makes we want the dirty fives soooooo bad.
    :militarypress: :jellydance:
  20. Apr 2, 2018 at 4:43 PM
    Cody23
    Cody23 Well-Known Member
    Cody
    probably hunting or camping
    2022 TRDOR 6MT
    6112/5160 SCS 285s GFC
    Got a new camp kitchen!
