  1. Apr 24, 2018 at 2:43 AM
    NCtaco13
    NCtaco13 Well-Known Member
    North Carolina
    2013 Gray DCSB 4x4 V6
    Question: why do people only do breather relocation on the rear axle and not on the front or the transmission (if it even has one)
  2. Apr 24, 2018 at 2:44 AM
    DrFunker
    DrFunker Well-Known Member
    Front does have one. It is located in the engine bay, up high. The rear is low. That is the reason for the relocate.
    Cheap insurance.
    Kyitty, poziden41, Slashaar and 7 others like this.
  3. Apr 24, 2018 at 3:39 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I was gonna say the same. My 295s barely clear, but they clear. Granted, I'm limiting uptravel by 1" but they're about 1" bigger than 285s, so it's a wash.
    Negative, that'll make rubbing worse. More than likely you're rubbing in this area. A fresh razor blade does the trick.
  4. Apr 24, 2018 at 3:49 AM
    Geoff
    Geoff Well-Known Member
    Adirondack Mountains
    2023 TRD OR
    The letters are stickers, so you can peel them off. You can use a razor blade scraper and/or goo gone to clear up the glass after.
  5. Apr 24, 2018 at 3:52 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Ah ha! Makes sense. I'll have to get mine off then. Not a fan of how the letters are dab smack in the middle of the window, and always seeing them in the rear view mirror.
  6. Apr 24, 2018 at 4:58 AM
    Stryker420
    Stryker420 Well-Known Member
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    Are you traveling south on 81?
  7. Apr 24, 2018 at 6:31 AM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    Truck is about to look alot cooler :D
    BajaAsh, Greg617, gabbo2112 and 14 others like this.
  8. Apr 24, 2018 at 7:13 AM
    Rick_Taco
    Rick_Taco I'll do it myself
    Rick
    Indiana
    '13 DCSB 4WD Limited MGM 110K Miles
    Bird Dog RVM Bracket, Tint 20% all around, Spider Trax 1.250" wheel spacers K&N Drop in air filter Ram Mount A Pillar (And hard wire charging) Dual 2.4amp Charging USB LED Lower Center Dash Light Center Console Light Trailer plug moved to bumper Tonneau Cover Air Pump Filter Upgrade (UNI Filter) Ultimate reverse light upgrade (Phillips 18161) Anytime Fog Lights Blue LED shift light Nitto Ridge Grapplers 265/65/18
    Why would you ever post this without giving us the exact tire size and rim combination??? hahahaha I assume that info will be presented with installed pics.
    TMartATC22, WPNZ, gabbo2112 and 3 others like this.
  9. Apr 24, 2018 at 7:15 AM
    Fatmonk8
    Fatmonk8 Did anyone ever tell you you're my hero?
    Paul
    Delco, PA
    2019 SR5 Barcelona Red Taco 3.5 V6
    Are these A/T3W?
    Slashaar likes this.
  10. Apr 24, 2018 at 7:30 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    Oh yes, there'll definitely be pictures of the final product with specs.
    They sure are, got them from the Direct Tire eBay sales.
  11. Apr 24, 2018 at 7:39 AM
    smcgill
    smcgill Well-Known Member
    Sean
    South Easton Mass. not enough time in Cocagne NB
    Camry and Ram 1500 with a "HEMI "
    Do they glow RED ?
    Cativelense[QUOTED] likes this.
  12. Apr 24, 2018 at 7:39 AM
    smcgill
    Sean
    Morning all ..:pccoffee: ,, I put in a call to the dealer that is doing the frame and told them that I have a problem with my rental ..I can't tow my horse trailer...let's see what happens..:turtleride:
  13. Apr 24, 2018 at 7:39 AM
    Fatmonk8
    Paul
    Delco, PA
    Funny, I just ordered the same tires today. 285?
  14. Apr 24, 2018 at 7:39 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Was also thinking the same
    315s and minimal rub here lol
  15. Apr 24, 2018 at 7:41 AM
    Cativelense
    Nuno
    CT
    LOL! Nope, thank God!
    smcgill[QUOTED] likes this.
  16. Apr 24, 2018 at 7:46 AM
    SilverJack
    SilverJack no one
    New battery. Stock battery failed right when I needed it. Wouldn't start when I was trying to get home, then died within 2 hours of getting home, then totally failed at auto parts store. I have to say the staff at my local Advance Auto were great. Tested the battery, helped me remove and install the new one, even used an OBD thingy to keep my electronics happy while changing the battery. The only glitch was their stupid system wouldn't let me use any discounts (despite the hundred special discount codes they keep sending me). So a big "Thank you" to the local store staff and a big "FU" to Advanced Auto corporate.
    I've never seen a battery die that quickly. It went from fully functional to crap in a few hours. Must have blown a cell or something. Stock crap battery anyway.
  17. Apr 24, 2018 at 8:09 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Minimal in the rear, but the 315's definitely run up front of you get any sort of flexy. Until you go LT that is. Now I only rub at bump because I need to delete my core support
    ChadsPride likes this.
  18. Apr 24, 2018 at 8:20 AM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    I'm curious about that house across the street w/the shake shingle siding. It looks like a new house so did they paint that siding to look aged or not treat it & it aged quickly or ? Looks like a new-old Scottish cottage.
  19. Apr 24, 2018 at 8:25 AM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    Please update us when that battery shits the bed.
    robssol and Rick_Taco like this.
  20. Apr 24, 2018 at 8:31 AM
    la0d0g
    running for the hills
    For crawling not hauling
    Who tows a horse trailer with a Tacoma :der:
