  1. Jun 21, 2018 at 9:09 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  2. Jun 21, 2018 at 9:28 AM
    ProfHobbit
    ProfHobbit Well-Known Member
    North Shore, MA
    2007 Tacoma 4WD, 5 SPD, 2.7L, Access Cab, Base
    Minor Stuff
    Just updated the build thread with a project I had completed a while ago: adding keyless entry for an Access Cab.
    ChadsPride likes this.
  3. Jun 21, 2018 at 9:59 AM
    Don5352
    Don5352 Liberty or Death
    Don
    Oakland, CA
    2014 AC TRD OR
    Some really cool shit
    Sounds like a loose plug.
  4. Jun 21, 2018 at 10:02 AM
    motionridr8
    motionridr8 Well-Known Member
    Drew
    Greenville, SC
    2012 Tacoma 4x4 DCSB
    5100's/886's/JBA UCAs, ICON RXT Rears, US Offroad Winch Front Bumper, BAMF Rear Bumper, 235/85r16 Skinnies
    That's what I was checking for last time I pulled the dash apart to install accessory switches. Didn't find any loose plugs, but figured it was a loose wire terminal in one of the plugs. Only happens like 3 times a year so I'll live...
  5. Jun 21, 2018 at 10:05 AM
    henrilepuf
    henrilepuf Well-Known Member
    henri
    Northwestern Paraguay
    tacoma 2014 4x4 DCLB
    It's the first thing I did when I got my Taco
    gabbo2112 likes this.
  6. Jun 21, 2018 at 10:17 AM
    theox26
    theox26 Well-Known Member
    '11 DCLB Sport
    I added tie down points in the bed using the bed bolts. It ended up much harder than I had anticipated but I should have known better.
    I used these and I knew I'd need to bore the hole wider, no problem. That was done in a few minutes. I also soaked the bed bolts in PB Blaster knowing the seven years they had been on the truck would make them more difficult to remove. That was an understatement apparently.
    The middle two bolts were not bad, I did them with a breaker bar and socket, when I then found the first time consuming part. The washer won't come off without removing the rings on the bolt. If you don't need to ever remove the washer I suppose this is a good design. I, however, needed to put the tie down ring above the washer. So I filed the rings down and got the washers off.
    Those re-torqued down fine too. The real issue ended up being the front two bolts, the drain holes seem to drip in a way that all water coming out of the bed runs down those bolts and really rusts them. If you attempt this, I recommend getting under there and using a wire brush on those bolts before trying to remove them. I still ended up needing my impact gun to remove them and it was hitting the whole way out. It took me about 1.5 hours for something that should have been much faster.
    olecoot, gabbo2112, Grumpy and 4 others like this.
  7. Jun 21, 2018 at 10:23 AM
    shabbs
    shabbs Well-Known Member
    Mark
    Toronto, Canada
    2014 Tacoma 4x4 V6 DCLB TRD Sport
    Skid plate - added 2014/10/23, Bed extender - added 2014/10/25, Tonneau Cover - added 2014/10/31, OEM Bed Mat - added 2014/11/12, AM/FM/CB AntennaX - added 2014/11/16, Smittybilt 27046B Beaver Step for 2" Hitch - added 2015/01/22, Trimax SXT3 Premium 5/8" Key Receiver Lock - added 2015/01/22, 2 x Grip 30' x 4" Heavy Duty Tow Straps - added 2015/01/23
    My thoughts: keep the emblem, get the black dust caps.
  8. Jun 21, 2018 at 10:30 AM
    Scooter WCT
    Scooter WCT Well-Known Member
    Scott
    Wesley Chapel, FL.
    2014 DCSB TRD Sport 4x4 w/ 6speed Manual
    3" Lift using Bilstein 5100 Height Adjustable front shocks and complete rear Old Man Emu Dakar springs from Toytec, 17" 4Runner TRD Pro Series w/ 32" BF ATs, Tint and much more to come
    Out w/ the beat up old stock skid, and in w/ the TRD Pro Skid from a Turd Gen.
  9. Jun 21, 2018 at 10:37 AM
    knifer
    knifer Well-Known Member
    Yellowknife,NT
    2013 Spruce Mica TRD SPORT
    Finally got around to installing the cali raised grille.
    Joeyp55, Nickkos taco, lo2hi and 13 others like this.
  10. Jun 21, 2018 at 11:45 AM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    For $99 dollars i think i would dip the dust caps myself and the Tacoma badge.
    Bagman, kgarrett11, Grumpy and 3 others like this.
  11. Jun 21, 2018 at 12:07 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Nice job. I think all those items are touched on in the how-to thread as well.
    theox26[QUOTED] likes this.
  12. Jun 21, 2018 at 12:25 PM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    put 34-ish inch tires are on! (285/75/17)
    lo2hi, Corny Taco, Rick_Taco and 11 others like this.
  13. Jun 21, 2018 at 12:31 PM
    TheDude94
    TheDude94 Basement Operator
    Mom's basement
    2008 TRD Sport 4x4
    Workin progress...
    Went on a much needed “spur of the moment” camping trips yesterday. It’s nice to have all your camping gear consolidated so you can just throw it in and go.
    MY50cal, lo2hi, srspicer and 10 others like this.
  14. Jun 21, 2018 at 12:43 PM
    mtmudrunner
    mtmudrunner Well-Known Member
    Wes
    Tomcreek corner, MT
    1985 Toyota 4x4 p/u
    Rust
    x2
    taco2010trd[QUOTED] likes this.
  15. Jun 21, 2018 at 12:45 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    I'd be more scared about snapping the door lug off and taking a dirt nap. No way that thing is rated for people weight.
    *PING*...*HAPPY BIRTHDAY TO THE GROUND!*
  16. Jun 21, 2018 at 1:41 PM
    keith88lx
    keith88lx Well-Known Member
    Mount Prospect
    15 DCSB TRD Sport 4x4
    pretty rare day. let me wife take my Tacoma to work so she can bring home our bag set (or corn hole depending on what region you are from) that she let her co-workers borrow almost a year ago. She parked in a corner spot and took this picture to let me know. ha-ha. And she didn't park like an asshole which was nice to see.
    Bagman, kgarrett11, lo2hi and 7 others like this.
  17. Jun 21, 2018 at 1:42 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    Would you know if this is longer and extends further back (protecting more) than the TRD 2nd gen skid?
    Scooter WCT[QUOTED] likes this.
  18. Jun 21, 2018 at 1:42 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    They way they are made, I'd imagine the bolts would shear before the actual base cracked in a way that would cut you. If it did fail, it would fail around the bolt holes first since all the weight is being transferred to the bolts and around.
    My fear would be my weight would bend the door latch and then no more shutting door.
  19. Jun 21, 2018 at 1:44 PM
    Slashaar
    Josh
    Kansas City, MO
    It provides a seamless skid to past the oil pan. However, the oil drain plugs are in different spots so that skid would have to come off in order to change oil on a 2nd gen. But to answer your question, I don't believe its any longer.
    Musubi3[QUOTED] likes this.
  20. Jun 21, 2018 at 1:45 PM
    Musubi3
    Big Island
    Gotcha, thanks.
